Question about Whirlpool WDE350LVS Stainless Steel Electric Range
I am trying to find the wiring diagram of the WDE350-LVS range in order to fix it.
The oven elements are not working, and I need to locate which part I should replace. How can I obtain the wiring diagram for the Whilpool WDE350LVS range? I should add here that the oven control is not locked. It is just that no power is reaching the heating elements. My suspicion is that the relay control in the control board has failed, however it would be useful to have the wiring diagram in order to ascertain that I must change the control board.
    Top Expert:
  • Whirlpool Master
  • 10,875 Answers
Http://www.whirlpool.com/digitalassets/WDE350LVS/Use%20and%20Care_EN.pdf
To Lock/Unlock Control: Press and hold CANCEL and COOK & HOLD for 3 seconds (press the CANCEL pad first). Repeat to unlock.
Posted on Apr 11, 2015
Testimonial: "Thanks for the use & care manual."
I need a parts diagram to replace the right front surface heating element of a Kenmore range, Model 629-45775
Does the element have continuity? if so, it will be the element switch that needs replacement... Generally, the radiant element will be held on by two screws and a steel plate, note the wiring before removing the old part. Definitely remove power to the machine before doing anything inside of it... Kenmore Range Stove Oven Surface Element Switch WP7403P239 60
Kenmore Range Stove Oven Radiant Surface Element 12002141
May 25, 2016 | Kenmore Kitchen Ranges
Bottom oven bottom element doesn't heat
Phil. If you do not have voltage at the element, then the Electronic Oven Control ( EOC ) has failed. Part number # 5701M403-60
In order to check for the correct voltage at the element you will need to remove power and pull the range out of its installed location and remove the back panel of the range to gain access to the wiring and element. CAUTION ! I cannot stress this enough ! There are dangerous voltages in this area!! After the panel has been removed, return power to the range,set the lower oven to bake, and check the voltage at the element. You should find 220-240 volts between the element terminals with them connected to the element. If you do not have the proper voltage then you will need to replaced the EOC.
Apr 18, 2014 | Maytag MER6772 Gemini Electric Kitchen...
I have a GE range in which the baking element cracked in one place and needed replaced. I removed the old baking element and was getting ready to install the new one when I noticed that there were not 2...
Hello, welcome to Fixya.
I understand you are replacing your bake element and are uncertain of wire placement, correct ? My first suggestion would be to locate the tech sheet/wiring diagram, or tracing the yellow wire. I suspect the 2 black are "hot" and the yellow (maybe with a green tracer on it?) is ground/earth...though I don't have a diagram either. Let me know what you find and I'll try to help you going forward. Good luck and thanks for choosing FixYa today.
Regards,
Macmarkus :)
Jul 09, 2011 | GE JBP65 Electric Kitchen Range
KitchenAid Model KESC307 has a broken oven heating element. Can you fix this yourself? How? How much is part?
Hello Tgilreath,
I understand that you are having a problem with you KitchenAid range. The oven element is broken and needs replaced and you would like to know the cost of the element.
I can instruct you on how to change the element in your range. However, I do not know if it is the top of bottom element and the change procedure is the same on both of them. However, when looking up the element to tell you where you can purchase and the cost I came across many different KitchenAid models that contained the numbers you gave. There should be more letters and numbers on your tag for the model.
The following is steps are how you change out your element:
1. Disconnect the power to the unit
2. Remove the lower back cover on your range (the one that sits directly behind your oven)
3. Locate the two prongs on the bad element sticking thru the oven wall and remove the wires
4. In the oven remove the racks
5. In the oven remove the two screws holding the element in place
6. Remove the element by pulling in forward
7. Install new element in Reverse
You can locate the element on Sears Parts Direct at the following web-page, however you will need the full model number http://www.searspartsdirect.com/partsdirect/part-model/kesc307?pathTaken=modelSearch&prst=0&shdMod=kesc307 You may also reply to this thread and I will get you a part number and the exact page you need to order the part.
Thank you for choosing FixYa.com
Justin
Mar 27, 2011 | KitchenAid KESC307 Electric Kitchen Range
I HAVE A WHIRLPOOL ACCUBAKE RANGE, THE OVEN AND BROILER DOES NOT WORK. CHANGED SPARK MODULE AND STILL DOESN'T WORK. ANY SOLUTIONS?????
There are four other things to check on the oven, you will have to run a test on the broiler element, oven thermostat, selector switch and the oven cycling relay.
To test the broiler element, To access the broil element located on the roof of the oven cavity, first open the oven and remove the oven racks. Remove the screws that secure the element to the oven, remove the holding brackets from the element and slide the element forward.
There is normally a small amount of excess wiring attached to the terminals on the element that allow a little room for maneuverability (you may have to tilt the element to get the terminals through the holes). Look for loose or disconnected wires and if there is no sign of burning; reconnect the wiring to the back of the terminal. If a terminal end is damaged, replace it with a terminal end designed specifically for oven use only.
To test the broil element, remove the wires from the broil element terminals by removing the screws from the terminal or pulling the wires off the broil element terminal. Remember to label the wires for reinstallation.
Visually check the entire element for signs of burn.
Test the broiler element for continuity. Using the ohmmeter, set the range scale on R x 1 and place the probes on the element terminals. There should be continuity, with readings ranging from 19 to 115 ohms, however readings will vary from manufacturer to manufacturer and according to unit size and the wattage, be sure to check your manual for the manufacturer's specifications.
If there are any signs of element burning, or if there is no continuity, replace the element.
To test for a grounded broil element, place one probe on the element outer surface and the other on the element terminal as in the ground test for the baking element. If continuity exists, the element has shorted and should be replaced. Be sure to test both terminals.
To test a dual broil element, remove the wires from their terminals. Using the ohmmeter, set the range on R x 1. Place the probes on terminals A and C to check for continuity, followed by terminals B and C. To test for a grounded element, place one probe on the element outer surface. With the other probe, touch terminal A, followed by B and then C. If continuity exists, the element has shorted and should be replaced.
To install a new broil element, simply reverse the disassembly procedures and reassemble, being sure to follow the wiring diagram and install the wires to the correct terminals
To test the oven thermostat: Access the oven thermostat, which is located in different places depending on the make and model: On freestanding ranges, access the thermostat by removing the screws that hold the back panel in place at both ends. On models with front-loading controls, remove the panel and tilt it for access. Be careful not to let the wires disconnect from their components. Some built-in models have a removable backsplash. Lift the backsplash, rest it on the cook top and remove the screws from the backsplash, which holds the rear panel. On wall ovens or eye-level ranges, access the control panel by opening the door and removing the screws that secure it. The screws may be under the exhaust hood or below the control panel. If the control panel is hinged, simply tilt it towards you. On some models both the rear and front control panels must be removed. The screws may be found on the trim and occasionally the trim must be removed.
When testing the thermostat switch contacts for continuity, refer to the wiring diagram and remove only those wires being tested - and only one pair at a time. Test switch contact terminals as per your wiring diagram. If the switch lacks continuity at any of the contact terminal points then the entire thermostat switch needs to be replaced. Adjusting the thermostat: Test the oven temperature by placing the tester in the oven's center and leaving it for 30 minutes at 350 degrees. Record the minimum and maximum temperatures of three cycles, then add those figures together, divide the result by six and you have the oven's average temperature.
If the average temperature is more than 25 degrees off, try calibrating the thermostat by following your appliance manual instructions for thermostat calibration.
Normally, thermostats are calibrated by pulling the oven's thermostat knob off, turning the knob over and adjusting the calibration ring on the back. If your oven doesn't have a calibration ring you may need to replace the thermostat.
To remove the thermostat: Disconnect the capillary tube and push it through the back oven wall, being careful not to break the flammable capillary tube wire. Remove the screws that secure the thermostat to the control panel and gently pull the thermostat out, leaving the wires in place. To install a new thermostat, reverse the disassembly procedures (Step 7 above), transferring the wires individually from the old unit to the new.
To test the selector switch: In order to gain access to the oven selector dial, first move the range away from the wall and remove the back cover panel by undoing the retaining screws. This will expose the back of the oven selector dial. Note: There are many styles of ranges. If this does not describe your range, refer to your owner's manual for instructions on gaining access to your oven selector dial. Now you can begin to test each pair of switch contacts for continuity with your VOM. Using the ohmmeter function, set the range scale to R x 1, and touch one test lead to each terminal of the switch contacts to be tested. There will be several pairs of contacts, one pair for each setting (eg. broil, bake, etc.). Refer carefully to your wiring diagram (often placed on the inside of the access panel) when testing. It is a good idea to label the wires as you test and only remove one pair of wires at a time. If there is no continuity between any pair of contacts, the switch is defective and must be replaced. To install a new oven selector dial switch, remove the old switch from the control panel by undoing the nut or screws holding the switch in place, leaving all wires attached. Transfer the wires one at a time from the old switch to the correct terminal of the new switch. Check your wiring diagram to make sure all wires are on the correct terminals. Now mount the new switch to the back of the control panel and replace the cover.
To test the oven cycling relay: In order to gain access to the oven cycling relay, refer to your owner's manual. Removing the back panel of the range accesses most relays, but some ranges locate the relay under the oven compartment where the utility drawer is usually located. Now you can test the relay using your VOM. First, label each wire attached to the relay and remove them from the relay terminals. Using your VOM's ohmmeter function, set the range to R x 1 and touch one test lead to the terminal marked L and the other test lead to terminal H2. There should be NO continuity. Next, test the terminals marked H1 and H2. Again, there should be NO continuity. Finally, test the S and R terminals. Continuity should exist between these two terminals. If your relay does not pass all these tests, it is defective and should be replaced. To remove the relay, undo the two screws securing it to the range and replace with the correct new relay. Refer to your wiring diagram and labeled wires to ensure that the wires are on the correct terminals. Now replace the back panel or drawer and test the oven.
Hope this was helpful to you. Thanks for using fixya.
Jan 27, 2011 | Whirlpool Kitchen Ranges
The left side cartridge/elements do not work. I've tried swapping it with the right side cartridge, but it still doesn't work. Both cartridges will work properly when used on the right side, so it is not...
The symptoms provided makes it clear that the cartridge is not the problem. Its the elements. Please find bellow the link from where you can order fresh ones. There is no troubleshooting that can be done to rectify it. You need to replace them.
http://www.partselect.com/PartDetail.aspx?inventory=2162190
Thank You
Oct 22, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Oven elements do not heat?
The oven bake element has burnt out and needs replacing. Shut the power off to the range. Remove the element mounting screws located inside the oven above or below each end of the element. Carefully slide the element out, disconnect electrical wiring. Install new element.
Mar 28, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
JBP66G W1AD Oven won't get hot enough
the yellow may be the oven temp sensor?
May 25, 2008 | GE JBP66 Electric Kitchen Range
Oven bottom wont heat
can you seee the lower bake element? usualy when bad it will be apparent with a visual inspection of the element.if there is damage to the element order a replacement . 2 screws and 2 wires . no problemTURN OFF POWER ITS A LIVE ELEMENT AT ALL TIMES!!!!!!!
Mar 16, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven not heating
if that hi limit is bad or tripped you wont get heat.the hi limit should sit near the heater if not in it.if you find this is tripped your thermostat could be faulty.from the schematic try to trace the wires from the heater to the hi limit and then jump it out.let me know.
Dec 11, 2007 | Maytag MER5755QAS CleanDesign Electric...
Whirlpool WDE350LVS Stainless Steel Electric Range Logo
131 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
