Question about Zanussi Washing Machines
Zanussi ZWF1221W washing machine keeps tripping the electric ?
    Top Expert:
  • Zanussi Master
  • 46,475 Answers
Look for a short circuit someplace ,
Posted on Apr 11, 2015
  • 74 Answers
SOURCE: Washing machine keeps stopping
pull the machine out and put the drain hose into a bowl to empty the water out when you have emptied it try cleaning the pump filter and check the drain system for blockages if that is ok then it looks very much like your door interlock is duff good luck and rate me.....
Posted on Feb 17, 2008
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Posted on Feb 08, 2009
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
Posted on Mar 14, 2010
MakeupWizard
  • 39 Answers
SOURCE: washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Posted on Apr 22, 2010
How do I tighten the belt on a zanussi zwf1221w washing machine?
not sure about ur model but the the motor usually bhas an area where the belt connects that can be adjusted by loosening and tightening thebolts
Feb 28, 2015 | Zanussi Washing Machines
Can you tighten the belt on a zanussi zwf1221w?
rarely does the belt come loose due to the bracket needing tightning? ur belt may have grown old and loose and needs replacing
My zanussi washer dryer keeps tripping the electrics
check ground wire for tightness on plug in and on breaker box.
Mar 31, 2012 | Zanussi ZWD12270 Front Load Washer / Dryer
My zanussi zwf1221w won't stop spinning. Any ideas
Check for a blocked filter. Or it could be your pump thats failed.
Mar 30, 2012 | Zanussi Washing Machines
My Zanussi zwd 1270s washer dryer keeps tripping the MCB and i have no idea why, any help?
Washers take alot of power to run. In the instlation manuel they say to have a dedicated electric line .
i had a problem with mine i had a sump pump and the dryer and washer on the same line and would trip my breakers.
You can run it off another line or extention cord as long as its rated for the needed amps.
Sep 24, 2011 | Zanussi Washing Machines
ZANUSSI ZWF1221W LIGHTS FLASHING UNABLE TO START PROGRAM
zanussi zwf12270
hi, my machine does not take the the fabric softener from the top tray.
this happened for about two weeks.Does anyone know the reason. thanks for your time
Apr 30, 2011 | Zanussi ZWD12270 Front Load Washer / Dryer
HI, My zanussi zwf1221w Washing Machine doesn't heat the water. I have replaced the heating element but this has hasn't solved the problem. Can Anyone help??
You need to check to see if you are gettring a supply to the element when it is at the heating stage, you will need a meter to do this.
If no supply, then could be a faulty thermostat or thermistor, other wise it could be a faulty programmer or control unit.
Hope this helps
Feb 11, 2010 | Washing Machines
Washing Machines Logo
47 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
