Question about Whirlpool Dishwashers
Dishwasher slowly fills after cycle
Hi, I have a Whirlpool ADP 262 Dishwasher that all works fine but after a cycle it will slowly fill with water from the bottom over the next few days. It's was fitted before i moved in 18 mths ago with no problems and nothing has changed in the install so something must of failed? I have checked the drain pipe is still fixed high and OK giving the loop above the sink level, again nothing has changed here. Is there a drain valve that fails i can replace? Maybe the inlet can leak and fill from the bottom? Thanks in advance Dan
    Scholar:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 123 Answers
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Posted on Apr 25, 2015
  • 18 Answers
SOURCE: whirlpool dishwasher leaks everywhere
your tub seal needs to be replaced. you might have damaged it when you moved it
Posted on Feb 04, 2007
  • 7 Answers
SOURCE: another inlet / drain light cycle interruption problem!
When the water stops too soon, it could be the "over flow" is stuck in the downward position, therefore the dishwasher thinks it's going to over flow. Check that out. Otherwise I'm afraid this sounds like the circuit board is shot.
Miss Midget
Posted on Nov 02, 2007
  • 1073 Answers
SOURCE: whirlpool adp 8540 - 7 flashes
replace the control board in the console
Posted on Apr 10, 2008
SolutionGuy
  • 331 Answers
SOURCE: KitchenAid Dishwasher fill up with water after use
Hi BB,
There are only 2 places the DW can get water from. One is the drain line and the other is the supply line. We need to eliminate one to diagnose the problem, OK?
The first picture is a drain hose gone wrong...
Inspect your drain hose. If it looks like the pic above, you gotta fix that. Even IF that's not the problem right now... it will be in the future (and MAY be contributing to the problem now). You'll need to loosen the clamp, remove the drain hose from its' fitting, pull as much slack as you can get from the DW and then make a "loop" in it before reconnecting it. Like this...
The DW drain loop should be as high as the highest part of the sink...
I know that you have done a lot of experimenting in an attempt to figure this out. Just make sure that the drain hose is installed properly to eliminate it as the cause of the flood issue.
After you've made sure about the drain hose, leave the DW alone overnight. If you see water in the tub the next morning, you definitely have a failed valve on your DW. Since it's new (less than a year?) the valve is under warranty and will be replaced at no charge.
Hope this helps. If it's out of warranty let me know and I'll do the part look up for you and provide detailed replacement instructions, OK?
SG
Posted on Apr 14, 2009
SOURCE: Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Posted on May 29, 2010
Whirlpool ADP 4404/5 when left unused but connected to water supply it slowly fills up until it overflows and runs onto kitch floor, i.e while on holiday. I reckon it slowly fills to overflow in about...
Hello there and thank you for choosing fixya
Yes you are about right normally when the unit fills with water and you dont want it to this means that the water inlet supply valve has seals that are weak in it and the water is leaking bye it or the valve itself is failing or may even have debris in the valve keeping it from fully closing so you may want to pull the unit out and inspect the valve and you may even have to remove the outer panels to get to the valve to inspect it and some of them are even located under the left side as you look from the front of the machine ok so check these and if you need more help please post me a comment and i can further instruct you on repair procedures ok?
Hope htis is very help ful for you
Best regards fMike
May 25, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
We have an ADP 262 dishwasher and won't release some of the water
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 28, 2010 | Whirlpool Dishwashers
Will not fill with water during cycle on my whirlpool adp 262 dishwasher
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 22, 2010 | Whirlpool Dishwashers
KUDS01FLSS0 Dishwasher - tub slwoly filling with
Slow fill of water is due to the strainer clogging. Strainer is located on the body of the machine where the inlet water hose is connected.
Clean all the water flow tubes in the machine.Clean the solenoid valve opening also.
May 26, 2010 | KitchenAid 24 in. KUDS01FLSS Built-In...
Dishwasher not working
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 13, 2010 | Whirlpool 24 in. ADP5740 Free-standing...
No water coming into dishwasher
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
Jun 06, 2009 | Whirlpool Dishwashers
Dishwasher slowly fills up with water after wash cycle completed
Inside the bottom of the dishwasher under the lower rack to the side there is a float that regulates water level. jiggle it up and down a few times , it will be OK. Vitally
May 12, 2009 | Dishwashers
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp 8540 - 7 flashes
Apr 10, 2008 | Dishwashers
Dishwashers Logo
125 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
