Question about Sony Televison & Video
How di i remove the battery from a Sony remote control RM S78T
  • 68 Answers
The user manual for your Sony remote is available on the link provided. It does recommend that you use their own brand CR2032 batteries but any other brand will do. www.esupport.sony.com
https://docs.sony.com/release/RMV30.PDF
Posted on Apr 11, 2015
    Top Expert:
  • Sony Master
  • 10,875 Answers
Pop the back off
Necesito configurar un control remoto para TV Sony RM-Y135A
If the Sony remote is the one that came with your Sony TV, try removing the batteries, pushing all the buttons to fix a "stuck" button, reinstalling or replacing the batteries, and testing operation. If no results the remote will have to be replaced.
Apr 19, 2014 | Sony Televison & Video
How do you Open Sony rm-yd059
SONY RM-YD059 remote is easier to disassemble then other models. Slide battery cover open 1 inch or half open. Using a plastic toothpick or similar device pop cover using the groove. There are three sliding locks on each side. You will now see six screws holding halves together - remove. There are six more clips holding remote together. Starting at the top working towards the bottom, there are three per side, location of clips at red and blue buttons, at between 4&7 and 6&9 rows, and finally at muting and jump buttons. Voila - Happy cleaning. Note: directional ring is keyed with thin and fat tabs, fat tabs are positioned towards the bottom.
Feb 04, 2013 | Sony RM-YD059 Remote Control 148947911
Sony Remote RM-YD035 does not change channels or turn off TV
You have worn those buttons on your remote out. Those are you most used buttons. You can have you remote repaired by pros here. You can buy a new Sony RM-YD035 here. Or you can purchase the keypad repair kit here and fix it yourself.
Oct 05, 2012 | Sony Rm-yd035 Remote Control
Change batteries in remote control and can not remote open
The sliding bottom must be placed exactly in its middle position so that the clips can more easily allow the bottom to be removed.
Aug 15, 2012 | Sony 1-487-700-11 Remote Control RM-ED035
My Sony RM V301 remote control code for my panasonic tv/vcr combo isn't working i've tried 018, 016, 017, 007, 049, 067 are there any others?
go www.fitness.manualsonline.com or www.remotecodelist.com
and follow the instruction manual procedure
1) tight the spring contacts with pliers
2) clean the batteries contacts
3) change new batteries
4) Resolder wires contact batteries and proof again. Otherwise you must go to repair shop
God bless you
May 10, 2012 | Sony (RM-V301) Remote Control
Disassemble or open the remote control Sony RM-YD035
if Sony Remote RM-YD035 does not change channels or turn off TV, the buttons got dirty coz those are you most used buttons.
You can repair Sony Remote RM-YD035 yourself. It's quite easy and fast, with perfect result!
To disassemble or open the remote control Sony RM-YD035, first remove a single screw in the battery compartment. Then use a very thin but strong screwdriver and insert it between top cover and the body at the back part of the battery compartment. Move the screwdriver up and down and slowly move it to the left and to the right and continue along the perimeter. Use two or three such screwdrivers and in 2-4 minutes the top cover plate with buttons will separate from the body/bottom/casing.
Clean both parts thoroughly. And then gently put them back together in the opposite order. The parts will snap closing.
You are done.
Mine is now working perfectly
Apr 01, 2012 | Sony Rm-yd035 Remote Control
Sony RM-X151 remote control battery change. I cannot find out how to change the battery and what sort of battery it requires.
If you look on the bottom edge of your remote you should see a little compartment that can slide out,then replace the battery(making sure it goes in the same way it came out!) slide the compartment back in the same way it came out and there you go!!!new battery,Good Luck!!
Sep 20, 2011 | Sony RM-X151 Remote Control
My RM-YD028 Sony BRAVIA Remote Control has stopped working, how do I reset?
Remove the batteries from the remote and wait 5 minutes or more. After waiting, insert the batteries again. The remote should now work. If it's still not working, the remote is probably defective. If that is the case, please contact Sony Customer Support, which will be able to assist you in getting a replacement issued.
Jun 01, 2011 | Sony Bravia Remote Control 148016611
How can i open my sony rm-ed009 remote control
insert wide flat blade (such as a wide flat bladed screw driver) into seam along one side. Twist carefully until seam starts to prise apart - carry on until you hear the "crack" of the press-tabs coming apart and repeat along the the length of the seam until you can carefully pull it apart.
Feb 11, 2010 | Sony Televison & Video
Sony RM-Y180 remote control
Did you install the batteries correctly?
Some remotes (Universal) need to be re-programed when you install new batteries.
Go to remotefinder.rca.com/default.aspx?site=rca for proper codes.
Oct 30, 2008 | Sony RM-Y180 Remote Control
Televison & Video Logo
77 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
