Question about Refrigerators
How do you attach the doors to the carcass doors to make it integrated?
    Top Expert:
  • Refrigerators Master
  • 52,099 Answers
One might think with screws
Posted on Apr 11, 2015
Hi, this is an integrated dishwasher and with the kitchen door attached won't open fully.
Maria, adding the door to the front of machine has increased over all thickness to what was existing, washer was not designed for the extra thickness and will catch on lower part of washer.
You may have a few choices, shorten added door panel, taper bottom of panel to allow operation, or remove added panel.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
May 04, 2016 | Dishwashers
Put thule hinge back on
Hi Jonathan, based on the date of your Q, you may have already moved on. For what it's worth... I have the Atlantis 1600, structure is identical, cubic feet size is different. When you state "put Thule hinge back on" I am presuming you're referring to the entire upper segment of the carrier as the hinges are only pins riveted to the upper carcass. These pins seat in the lower carcass latches (also riveted) when the lid is closed. If the lower latches are obstructing the pins from seating, it means the latches are locked -- simply insert your key and unlock them. The pins (hinges) will function normally again.
If you're referring to actually attaching the pins to the upper carcass, then I would use a 3/16" medium length rivet ensuring that you use a washer on the inside (where the rivet expands) to add the binding power that the carcass body will not.
Aug 03, 2012 | Thule Atlantis 1200
I would like help refitting my oven door
Not being able to see the problem, may I suggest you beg, borrow or steal a couple of strong magnets to hold the plate in place while you attempt to re-attach the doors.
Once you got one more or less in place you can use a nail or small screw driver maintain or adjust position.
Jan 30, 2012 | Ovens
Neff dishwasher removal
this may work - if it is an integrated dishwasher you should have a star shaped screw attaching the door to the machine on either side (about half way down). try pulling the machine out - and then looking for the holes on either side at the front. insert a star screw driver (may not work with other screwdrivers) and release the bolts (screws) then slide the door upwards.
Jan 17, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Top oven door glass has smashed
Usually, u open the door as far as possible and at the lower end of the hinges you shoud find what look like 2 small catches, pull these up and latch them on to a hook or something similar on the main part of the hinges, this compresses the springs, and then lft up the door and pull towards u, this should release the door, and then change the glass, then offer the hinges into the slots, and pull the door back down, then release the catches.
Plz rate my solution.
Thanks.
Jan 01, 2009 | Fagor Ovens
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
My Frigidaire front load washer won't start
A year later! I experienced the same problem this morning - exactly as you, Bessie24, stated. I could hear a faint humming sound and thought the lock mechanism was still trying to complete its locking function. It would know the lock function was completed when the lock trips the wee (micro) switch. I reckoned if the female portion (with switch) were a tiny bit loose, the switch might not trip, so I loosened then tightened the two screws attaching it to the carcass of the washer (as opposed to the door part) while pushing upward on the same part. This fixed my problem and i hope many others find this procedure useful.
Sep 09, 2008 | Frigidaire GLTR1670A Front Load Washer
Refrigerators Logo
44 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
