Question about Ovens
I was cooking tea tonight with my parmco oven i open the door to look at tea but when i close the door the oven stop working
The gas hobs are still going all good
    Top Expert:
  • Ovens Master
  • 43,064 Answers
Not a clue but why do that in oven when gas on top works better
Posted on Apr 11, 2015
Knobs on hob above the oven getting very hot. Guess heat must be escaping from the oven. Any suggestions?
Try putting a layer of insulating materials between the Knob and the oven. That should help.
Aug 10, 2015 | Ovens
I have a parmco ar900leg gas stove with a multi function oven power. Its been cooking a treat for the last six months when we bought it. was installed by a gasfitter and correctly. Now, the bottom...
u say element not working? so its a gas and electric? If so check the element with a multi meter for continuity. I would say check ur gas safety valve also but u say it does work in grill?
Mar 08, 2015 | Ovens
How do I stop my parmco wall oven from turning off doing cooking
I am having the same issue. I can only cook in it for an hour to two hours at 180 deg and after that it keeps turning itself off
Feb 19, 2015 | Ovens
Gas hob Luce(hotpoint) gas on glass 5ring burners keeps going out on low flame when pull pan drawer beneath out
Same problem with my hob. I adjusted the small jets to their lowest setting in order to be able to simmer -impossible on the bigger jets. The problem is the vents underneath the hob. These can't be closed off so the problem appears to be in the design. The solution I have to use while I save up to by a decent German model is to open and close the cupboard doors underneath the hob very, very slowly.
Nov 19, 2013 | Ovens
Hi I have a Bosch Double Oven/convection Oven I
Don't know but have you tried the old tea towel in the corners trick to see if its the hinge alignment and not the seal? Put two tea towels in the lower corners sticking out of the oven part way and push the oven door closed a few times. Saved me from trying to replace the seal.
Oct 04, 2013 | Ovens
I Have a Whirpool Microwave Oven Combo Model RMC305PDQ1 sometime when the oven is cooking the oven latch closed and we can;t open
Despite what the owner's manual says, you should not open a microwave door when it's cooking. You should press the Pause or Stop pad first. Otherwise, you will shorten the life of your door switches.
If you're ever unable to pen the door, then you have a problem with the door latch, spring, etc. that needs to be investigted and corrected.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Feb 27, 2013 | Whirlpool RBS275PD Electric Single Oven
Diplomat Softline ADP0300 Gas-just not cooking ...anything!
Hi there..
I Just recently had the same problem, also with a diplomat gas oven..
The problem I found was down to a small resetable component under the main cover. ..
It took me ages to find the problem and I had taken the whole electical parts of the oven to bits before 'accidentaly' coming across this 'thermal switch' (located inside the main cover, at the top, behind the display module).. - to reset this there is a tiny red button between the connectors.. press this - and it should all be fine again... : One importnat note is that this may be tripping as a consequence of the fan not running or by my thinking not running on after the oven is switched off, leaving the casing to heat up and then trip this switch component.. - if this component is faulty it can be found in RS components or Farnell components.. look for Thermal swich manual reset part no: L100C 9082 470.
Nov 29, 2009 | Ovens
Trouble lighting gas oven. Brand is a Chef
your thermocouple needs replacement
Aug 31, 2009 | Ovens
Oven door staying open about 1 inch
your going to have to replace both the door hinges, since they have been over extended past ninety degrees they are not able to close to ninety degrees. that is the only repair, i would also look closely at the inner door panel and make sure that is not "crowned" or bent from the force that might also need replacing
Nov 19, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Broiling
it really doesnt matter because the heat transfers directly onto the food therefore you can leave the door open or shut.
Jan 05, 2008 | Equipex PZ-330 Electric Single Oven
Ovens Logo
187 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
