Question about Craftsman Garden
Will a craftsman ezwalk, B and S 190cc, 2012 yr model lawn mower run without a blade
    Top Expert:
  • Craftsman Master
  • 50,527 Answers
Yes. It has flywheel where the inertia needed is stored
it will run better if the cutter disc without the blades is
still attached as it acts as a bigger fly wheel
Posted on Apr 11, 2015
  • 7 Answers
SOURCE: Craftsman lawn mower can not run without pumping the red button
The fact you need to keep pushing the RED or "Primer" button says that your engine is running too lean ie. not getting enough gas.
You probably have a carburator problem due to the old gas gumming up the inside of the carb. The gum and dirt is clogging some of the internal passages of the carburator. It will need to removed from the engine and cleaned. The carburator is held to the engine by 2 bolts and is simple inside. Carefully clean the carb. with either carb. cleaner or laquer thinner or similar good solvant. Reinstall and you should be fine.
Also be sure to check your air filter and replace if dirty.
The red button is a "primer" that pumps extra gas into the engine. It is normally used only only for statrup so if need to use it while the engine's running, you're running too lean.
Dr of Motors
Posted on Mar 22, 2009
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
mowerman1857
  • 389 Answers
SOURCE: Does Not drive, belt position not sure is correct,
"belt position not sure is correct," from your description above
The first thing to do would be make sure belt position is correct, connected and tight.
This system is quite simple, the belt goes in the pulley on the engine shaft and the pulley on the transaxle only, nothing else. Using a short piece of rope or anything else readily available, temporarily tie down the safety bail (handle) and engage the drive handle. Now check your belt, it should be fairly tight and you should not be able to turn the transaxle pulley without considerable effort, if it is easy to turn, replace the belt. Now release the safety bail (handle)
If the drive belt seems to be working okay as above, remove the front wheels and inspect the gear teeth in them. If the outer half of the teeth are worn down more than 1/2 the original size as compared to the inner half, replace the wheels.
While you have the wheels off, if you have a couple of blocks of wood or similar items, set one under each corner of the front of the main frame outside the arch of the blade and start the engine, engage the drive and observe the pinion gears, they should both be turning. If they are not, then you have a bad transaxle and are going to have to either replace it , use it strictly as a push mower, or replace the mower.
Posted on Oct 31, 2009
Testimonial: "Thank you for your time to help me. I am very much appreciated. Tony"
hunter19_46m
  • 7482 Answers
SOURCE: craftsman briggs and stratton 6.50 190cc lawn
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this helped
Posted on May 26, 2010
  • 38 Answers
SOURCE: RE: Lawn mower blades will not engage
This sounds like a faulty ground condition, the PTO clutch requires a ground provided by the chassis wiring harness to function and a ground for the ignition switch to kill fire to the coils. The other components work as they should because the voltage regulator, fuel shutoff solenoid and starting interlock system have their own grounds. The ignition switch in these mowers is a large round plastic switch not capable of grounding itself, it should have a black wire leading from the terminal marked "G" on the backside of the switch.
to diagnose a faulty ground you'll need a basic 12V test lamp:
Unplug the switch and and install a the test light clip on the positive terminal of the battery, probe the ground wire in the unplugged harness that corresponds with the "G" terminal only. If the ground is good the lamp in the test light will illuminate brightly, if poor or faulty the lamp will not light or be noticeably dim.
Further verification of a faulty ground or failed PTO switch can be tested at the PTO Clutch harness, turn the key on, engine NOT running, and pull the PTO Switch to the engage position, with the test light clipped onto the Negative Battery terminal or chassis, back probe the connected PTO clutch terminals. If the PTO switch is good and the ground is good then Only one terminal will illuminate the lamp, if both wires illuminate the lamp then the ground is faulty, if no lamp illumination then a loss of power is suspected, check the terminals on the PTO switch and Ignition switch for power.
Typical Ground termination locations are on the frame near the rear of the tractor frame, above the transmission, in the steering column area and near the solenoid, check for a loose or corroded eyelet terminal, broken wire, or a missing fastener in these areas.
Posted on Jul 04, 2010
How can i fix my slow running lawnmower
Sounds like the air/fuel mix is off.. there should be a adjustment screw on the side of the carburator use a screw driver and turn it slowly one way or the other till it starts running right
Jun 22, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman excessive vibration lawn mowers problems
vibration in a walk behind mower is most always a imbalance in the blade , there lots of things that cause this , from loose blade , to bent blades
remove blade and test with blade balance , there not expensive ive seen them with a sharping stone for less than ten dollars before
pull spark plug before you remove blade 4 safety
Jun 07, 2014 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman excessive vibration problems 625 series
probably a bent crank shaft or blade is out of balance
Craftsman 675 21" rear self-propelled not pulling
Remove blade and loosen tension system slide belt over transmission and off of the engine
Apr 17, 2013 | Craftsman 675 Torque 190cc 21" RearBag...
Craftsman with 190cc only idles
remove the top cover from the engine and see if there is a nest stopping the governor linkage from moving
Aug 10, 2012 | Craftsman 675 Torque 190cc 21" Briggs ...
Craftsman 6.5,22 inch cut. model# 917.379470
does not sound good the off balance of a loose blade could have caused the rod to break inside the engine the age of mower and how much use it has had could be a factor only way to really know it to look inside the crankcase.
Jun 06, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
I changed the oil in my self propelled mower and now it wont start
If the blade control is disengaged, it will not start, engage control. Also check spark plug is connected.
May 20, 2012 | Craftsman Garden
Loud noise metal against metal sound
Check under your mower and see if the blade sheild has bent in towards the blade. This could be your problem. If so take a hammer and tap the sheild back in place. GOOD LUCK.
Sep 24, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
Garden Logo
51 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
