Question about Pramac 5000 Watt Generator
Jak demontovat motor Honda GX270 ze stroje - Pramac 5000 Watt Generator
    Top Expert:
  • 1,144 Answers
Honda gx270
Check that the gas cap vent is not blocked and is working properly for one thing. Also check the oil level most honda engines have a low oil shut down feature.
May 27, 2014 | Honda Gx270 9.0
My dell gx270 turns on by itself
Ignition solenoid, Get a new one, and replace your ground! You all set! might want to look at the main switch.
Sounds like the solenoid is getting old and current is getting to it, if that No work.. Call a priest! lol
Good luck and let me know how it turns out!
Oct 02, 2013 | Norwood Industries LumberMate Personal...
Hunter cieling fan replacement zing ear switch ze-268s5
I never could find the 5 wire 4 speed replacement. I did however find a solution.
4-speed (five-wire) pull-chain ceiling fan speed switch--Use 3-speed ZE-208S6-A09.
How to use the 3-speed ZE-208S-A09 to replace a 4-speed switch:
old ZE-208S5-1T or ZE-268S5: . . . . . for ZE-208S6-A09 use:
L=Black . . . . . . . . . . . . . . . . . . . . . . . . L=Black
1=Gray . . . . . . . . . . . . . . . . . . . . . . . . 1=Gray
2=Brown . . . . . . . . . . . . . . . . . . . . . . . . (Don't use Brown)
3=Purple . . . . . . . . . . . . . . . . . . . . . . . 2=Purple
4=Green . . . . . . . . . . . . . . . . . . . . . . . . 3=Green
old ZE-208S5-1T or ZE-268S5: . . . . . For ZE-208S6-A09 use:
2=Green . . . . . . . . . . . . . . . . . . . . . . . . (don't use Green)
3=Brown . . . . . . . . . . . . . . . . . . . . . . . . 2=Brown
4=Purple . . . . . . . . . . . . . . . . . . . . . . . 3=Purple
Feb 18, 2013 | Hampton Bay 24750 Huntington III Ceiling...
Generator runs for about 10 minutes and then stops like it is running out of fuel. 5500 NorthStar with Honda motor. Waned fuel tank and lines, had carb. Rebuilt and cleaned all out with carburetor cleaner....
It appears you have eliminated all of the fuel related issues. That would leave the generatoor safety circuits as a possible reason for the unit shutting down.
The Low Oil Level Sensor is the major reason that generators shut down when your sure there is not a fuel supply problem. Make sure the unit is fully servied with OIL. If the problem persists disconnect ONE wire from the low oil level sensor and see if the problem persists. If you still have the problem inspect the black or green wire from the Start run switch all the way to the Air shroud on the engine looking for signs of chaffing.
If you can not find anything then you will have to re-focus your attention on the fuel system once again. If you have a solenoid on the base of the carb.. the solenoid can be WEAK and stop remaining open once hot. This will cause the engine to lean out and die.
You should also check fuel flow to the carb. The flow should fill a spary paint can lid in under 10 seconds to the point your worried about it overflowing. Most honda engines have a metal sediment bowl under the fuel selector. Remove the sediment bowl and dump the contents. Check fuel flow again.
- Carb. With the float bowl removed fuel selector ON check fuel flow again by holding a spray paint can lid under the float. It must fill up in about 10 seconds to the point your worried about over-filling the lid. If you do not have a good flow rate here the float needle float needle rubber seat and the fuel manifold are the prime suspects.
I know this generator has the Honda GX270 engine. Some have solenoids (Item 49 this link)
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE,%20JPN,%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CARBURETOR%20(2)/parts.html
^- No details!
Honda engines by model and VIN can be found here:
http://www.boats.net/parts/search/Honda/Engine/0/parts.html
At this time I think the low oil level sensor (sending uint) may be the culprit causing your problem.
Item 2 this link:
http://www.boats.net/parts/search/Honda/Engine/0/GX270%20VPX5%20ENGINE%2C%20JPN%2C%20VIN%23%20GCAB-2000001%20TO%20GCAB-9999999/CYLINDER/parts.html
Thanks for choosing FixYa,
Kelly
Sep 16, 2011 | Electrical Supplies
Jak mam wymienic baterie w sluchawkach sony mdr -rf 800r jak odkrecic ,??
Feb 10, 2011 | Sony MDR-RF960RK Consumer Headset
Does jak 2, renegade game on play station 2 come with a booklet?
Yes it does. Click on the link below and then click on the PDF link towards the bottom right side of the page to download the Jak 2 renegade owners manual for the PlayStation 2:
http://safemanuals.com/user-guide-instructions-owner-manual/GAMES%20PS2/JAK%20II%20-%20EL%20RENEGADO-_S
Feb 04, 2011 | Sony Jak and Daxter: The Precursor Legacy...
Factoy tire size
The factory size is P185/65R14.
I have a Honda Civic and i cold Wisconsin winter use a set of Blizzak winter tires P185/65R14 on steel rims.
If ambient temperature warms up above 45F degree, I use a set of tires P205/45R16 Falken Ziex Ze-912, mounted on 16 inches aluminum rims.
Using all season tires is a good compromise too.
Nov 04, 2010 | 1997 Honda Civic
Pramac 5000 Watt  Generator Logo
105 people viewed this question
Top Pramac Electrical Supplies Experts
RSole
Are you a Pramac Electrical Supply Expert? Answer questions, earn points and help others
