Question about Soyo Computers & Internet
MY SOYO MONITOR BLINKING AND SHOW NOTHING THAN THAT I DONT KNOW EXACTLY THE PROBLEM
I have a Soyo 19" TFT LCD Monitor MT-NI-DYLM1998 when i power on the computer the monitor come on then after a very short time (less than 10 seconds) the display goes off but the power and signal are still...
medproducts, Nothing new here. Check internal "switch-mode-power-supply board" only after devoting about 1-2 hours of viewing "lcd monitor disassembly" and "lcd monitor repair" video clips at YOUTUBE!!! Then you will need to make big decision!!! Let me and all who read this know what your plan of action is.
12fixlouie
Sep 16, 2010 | Soyo 19" LCD Flat Panel Monitor
I have 2 Soyo DYLM246d Montiors when i plug them in nothing happens wont turn on nothing at all. Is there a Fix or are they junk?
Check your power cable and try to replace the cable and clean any dust on the LCD and try to switch on and check the power unit also
Aug 17, 2010 | Soyo DYLM24D6 LCD Monitor
Soyo monitor goes blank after a couple of seconds.
your power supply is bad or the back lights. you need to open the back cover and look for leaking or crown capacitors and replace them.
Dec 30, 2009 | Soyo TFT 19" LCD Monitor
Wont boot up just beeps
3 beeps points to the memory. Try re-seating the RAM.
Mar 20, 2009 | Soyo P4VTE (SY-P4VTE) Motherboard
Syncmaster paower button blinking and no display
CHECK THE REFRESH RATE ON TH OLD COMPUTER MONITOR AND MOVE IT TO A HIGHER REFRASH RATE IN THE CONTROL PANAL, MONITOR, PROPERTIES, ADVANCE SETTINGS
ROD
Feb 10, 2009 | Soyo DYLM1986 Monitor
Power on. Blinks like strobo.
I have exactly the same problem and am searching the web for a solution. I am unable to change any settings on the computer, because of the strobbing monitor (I don't have a reserve monitor). If anyone knows the cause and, more importantly, the solution to this problem, that would be most appreciated.
Jan 20, 2009 | Soyo DYLM24D6 LCD Monitor
Soyo monitors
your monitor doesnt have drivers for it.. and doesnt need drivers for that matter. It sounds like you dont have the right drivers installed for your graphics card. here is a link to the drivers you need.
http://www.nvidia.com/object/winxp_169.21_whql.html
hop this helps, good luck.
Jan 22, 2008 | Soyo Dymond DYLM017A 17" LCD Monitor
Repair
if the monitor green led is blinking continuosly the follow the steps remove the cable of the monitor which is connected to the CPU and watch the monitor it should show a message ( no input signal or cable disconnected, that means your monitor is OK the problem is with your CPU . try this and let me know
Oct 10, 2007 | Computers & Internet
Computers & Internet Logo
131 people viewed this question
Top Soyo Computers & Internet Experts
Roy May
Matson Kurian
Matson Kurian
Are you a Soyo Computer and Internet Expert? Answer questions, earn points and help others
