Question about Garden
No, Need to see a diagram of the springs that are on the deck of riding mower Model #247-288851
Put on new belt and now the blade release is backwards. What did I do wrong. Need to see diagram of mower deck.
    Sergeant:
  • Garden Expert
  • 187 Answers
Hope this helps. Craftsman Tractor model #247288851 Deck and Belt Diagram
No, Need to see a diagram of the springs that are  - no-need-see-diagram-springs-deck-riding-2usc5bn0lieugip1xgsingxf-3-0.jpg
Posted on Apr 11, 2015
Model 917.20381 riding mower. Why don't blades disengage?
Terry, Deck full of debris around belt tensioner not allowing it to release, tension arm seized/spring broke, wrong/small belt installed.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
CRAFTSMAN 42 MOWER REPAIR
My mower deck will not disengage
Blade will not disengage Craftsman 917 270662
https://answers.yahoo.com/question/index?qid=20090407155731AACRvsq
Sears Craftsman 917 272481 LTX1000 Riding Mower Deck Belt Blade...
Apr 08, 2016 | Craftsman Garden
Spring mount location for belt tensioner for murray 45256x92a
Try this site to get your manual and see if the exploded parts diagrams help
Mar 30, 2015 | Murray Garden
Need diagram of deck for 2006 super bronco model 6605
I DON'T HAVE IT ON HAND, BUT YOU CAN TYPE IN ON GOOGLE SEARCH "YOUR MODEL # DECK BELT DIAGRAM" TO FIND IT, BUT TO DO IT YOURSELF, JUST REMEMBER THAT BLADES MUST TURN COUNTERCLOCKWISE AND THAT GROOVED PULLEYS MUST FACE THE INSIDE OF BELT AND FLAT PULLEYS THE OUTSIDE OF FACE OF BELT, ALSO REMEMBER THAT SOME MODELS HAVE JUST ONE BELT (DRIVE AND DECK BELT) OR TWO BELTS (DRIVE BELT AND DECK BELT)
Jul 08, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Blade does not stop spinning when lever disengaged.
Under seat of tractor theres a plate that says model # it looks like 917. 000000 i need that # please and i can help you with the problem it sounds like the belt isnt disengaging which will cause blades to continue to go.
Jun 09, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blade still running after lever is disenagaged on Sears Craftsman LT2000 2010 riding mower.
the moveable arm that the blade engage pulley is attached to has a hole for a spring as well as the deck (or at least an attached immoveable bracket). spring goes there to bring the blades to a stop when putting the lever in the off possition.
I have a troy bilt riding mower blades will not engage in the 1 or 2 deck setting
There is a spring attached to a tensioner that probably came unhooked while changing the belt. Higher deck settings push the deck backwards enough to spin the blades, the lower setting need the spring tensioner to take up the slack in the belt.
Jun 27, 2012 | Troy Garden
Blade belt pullys, need diagram, picture.
Need to know what Model # you have?
Try going to www.precisionope.com and put your model number in there to see if it can give you what you need.
Oct 02, 2009 | Garden
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I NEED TO SEE A DIAGRAM ON A JOHN DEERE 214 LAWN MOWER TO PUT THE BELTS ON THE DECK
Hi..my name is Keith..and you can go to an online lawn mower parts site and put in your model of lawn mower and search for the mowing deck..and they will have a diagram of the mowing deck with the belt on it..and there are several sites online but i'll give you the one i use www.outdoordistributers.com ...i hope this has helped
Jul 11, 2009 | Garden
Craftsman 18.5 riding mower when I engage the blades to cut the blades turn But they do not engage NO Power.Blades Turn But Not enough to cutthe grass.
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
1,548 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
