Question about Garden
Put on new belt and now blade release is now in the off position instead of the on. Mower blades will now cut in the reverse.
  • 1,169 Answers
Then I would say you have belt(s) on wrong.
Posted on Apr 11, 2015
How did I get my troy bilt lawnmower in reverse
If it is a riding mower 1st depress the clutch, lift the mower blades to the up position then move the shift lever to R. It will stall and shut off if you attempt to go into reverse with the blades in the cutting position.Mine has reverse on the fly but I never use it. Hope this helps.
Sep 24, 2017 | Troy Garden
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
I replaed the blade drive mandrel and reattacheed the blade and the blade does not freelyturn t is so bound up tht I cannot turnit manually
okay check see if brakes is on the mower, not the tractor but the blades of the mower deck if not then take belt off of the new mandrel side and try turning blade by hand. should turn freely if not mandrel is bad but unlikely. sounds like you changed wrong side mandrel I presume you have 2 blades and mandrels. or when you installed it back on. the belt may be bound up between a guide and pulley just kind of look things over before a tear apart. and then do your tear apart one step at a time then check blade to see if it turns does not seem serious you may have put belt on wrong, I have done it my self. hope this helps major note do not do this with engine running cut you hand off in a flash.
Aug 13, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
How do I change the drive belt on a 7021r mower? The drive will move the mower on pavement but not on the grass
First, you need to make sure you have the right tools for the job. You'll need a wrench, work gloves, mower blade clamp, drain pan and fresh fuel. Check your owner's manual for the correct belt to your specific lawn mower. Belts that are not specifically designed for your mower will not fit properly and may wear down prematurely. Next, remove the spark plug wire. This is a safety precaution to prevent the mower from accidentally starting.
Now you can remove the screws that secure the drive cover to the mower deck. Once you've taken off the drive cover, loosen the screw that holds the belt tension spring to the transmission. As the screw is loosened, tension on the belt is released allowing you to remove the belt off of the front transmission pulley.
At this point you'll need to turn your mower on its side to take off the mower blade. Be sure to use a work glove to protect your hand when removing the mower blade. You can use a lawn mower blade clamp over the blade to secure it. Unscrew the bolt to remove the blade and then the engine baffle. Once the pulley unit is exposed, you can remove the entire drive belt. Insert the new drive belt and place one end on the rear pulley and re-attach the engine baffle. Then, place the mower blade back (making sure it's facing the correct way with bottom of the blade facing the ground) and tighten the bolt. Remove the clamp and return the mower to its upright position so you can place the other end of the belt to the front pulley. Remember to tighten the screw to the tension spring.
Put the front drive cover back on, tighten the screw that secures the cover to the deck and reconnect the spark plug wire. Add new fuel to your mower and you're done!
May 14, 2011 | Husqvarna 7021 21Inch 160cc Honda GCV Gas...
Mower will not disengage
this is because your belt that drives the blades is to tight i suggest getting a looser belt
May 10, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Husqvarna ride-on mower LT1536. We put a new
This seems to be the correct part no. for the 36" deck, is the belt definitley the correct one, it should have the no. 174978 marked on it.
Sep 29, 2017 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Replacement blade position.
The blades have such a close tolerance tip to tip on a V belt deck that it makes no difference where they are positioned, On a 3 blade deck the center spindle is forward of the two outer spindles. So for that reason you still get a quality cut. Most all commercial units use a V belt and have a good quality cut.
Some john deere mowers have a timing belt with cogs like a car and their blades have to be in time
90 degrees perpindicular to each other and locked down and if you strike something then the timing will be off and your back working on your mower instead of cutting grass,and the belts are twice as expensive than a v belt.
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Craftsman 42" riding lawn mower blade free spinning but wont cut
It sounds to me that you need a new mower deck drive belt, or your blades need sharpening. If the blade edges are rounded, they won't cut butter... Also, when mower is off, check mower deck drive pulleys to make sure you don't have any that are locked up or are dragging. You can check this by pulling the belt away from pulley and spinning the pulley by hand. MOWER MUST BE OFF before attempting any of these checks. You would be surprised how many people would try this with the mower running.
Hope this helps
Mar 11, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
