Question about Water Heaters
I have a gas leak from the control box the leak is at 38%. I have 5 day to figure out how to repair it or replace it. Hoping I can just replace gas and burner supply lines, Or does it need replaced.
  • 2,355 Answers
If its leaking at 38%, your lucky it hasn't blown up yet. Turn off the gas and replace the water heater.
Posted on Apr 11, 2015
Testimonial: "Thanks John, I had lose fitting that needed to be tighten. No more leaks so far."
Error code on rheem water heater
https://www.manualslib.com/products/Rheem-Gg40t06tvt-1618904.html
Rheem GG40T06TVT Manuals
Page 31 of manual above shows troubleshooting when experiencing six flashes. It shows a possible problem with gas supply, or a faulty pilot that needs to be replaced.
You may need another technician to repair it.
Gas leaks can be dangerous, and even cause *****, so you are advised to seek assistance to repair it soon.
Mar 29, 2018 | Rheem Water Heaters
Is this a dangerous gas leak?
Any gas leak is dangerous, call him back!!!!
Nov 19, 2014 | Water Heaters
I have an AQ125B-NG not producing hot water..
Maybe the problem is bad faucet cartridge.
Test for crossover:
http://waterheatertimer.org/Crossover.html
Tankless are really made to be thrown away when problems start.
It's like replacing parts on your computer ... for real, when the hard drive crashes and new one is installed, then rarely are problems repaired satisfactorily.
Repair any brand tankless, any problem, permanently, same day, for $385
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Mar 09, 2013 | Water Heaters
Drain wont stop leaking
1) Copy following link for fixing drain valve on 38 gallon gas water heater with plastic drain valve.
http://waterheatertimer.org/How-to-replace-water-heater-drain-valve.html
2) According to serial number, your GE (Rheem) water heater was made in 3rd month of 2007. No service manuals are available from Rheem. Warranty period is probably 6 year. Unit appears to have reliable White Rodgers gas control valve.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
3) Add comment and say what you discover.
Feb 18, 2013 | Water Heaters
Put in gas valve, a few days later sensor set lock out due to flamible sensor setting off. what are the codes to unlock system?
Air intake is probably clogged, so combustion air flow slowed and caused overheating inside combustion chamber.
This tripped FV system and broke TRD, which is a small glass vial located under burner. The spring-activated air baffle snapped closed and shut off air supply, and also tripped FV lockout of gas control.
Remove burner, replace glass vial ordered from Richmond, and clean air intake.
http://waterheatertimer.org/How-to-repair-Rheem-TRD.html
If you have Intellivent gas control, then it can be reset.
Copy following link to identify gas control valve, and download possible service manual:
Nov 11, 2012 | Rheem Richmond 40 Gal LP Gas 6 Year Tall...
Atwood G6A manual water heater had gas flare up around the control knob when lighting the pilot. Unit is about 9 years old so repair or replace? works OK & no gas smell.
The gas control is leaking gas around the knob?
The gas control needs to be replaced before causing explosion and/or fire.
Gas control has identifying marks on side.
Sep 27, 2011 | Water Heaters
Our Rheem gas water heater was acting finicky a few months ago so we called the manufacturer and they sent us a new/replacement kit for the Invensys WIPER Electronic Control & FV Sensor. We replaced...
You're probably in for a service call and/or possibly water heater replacement if unit is more that 5-6 years old.
Your water heater plugs into outlet. Check outlet with cheap circuit analyzer to make sure the unit is receiving correct polarity without line interference.
If unit is in the attic, then add more venting to soffit and roof so pilot is not being snuffed out by hot air. If unit is in basement, then open some doors and a window and see if unit needs more air.
Most gas water heaters require yearly cleaning and service.
Clean the combustion parts and tubes.
Clean the air intake.
Have gas company check gas pressure.
Open following link for possible illustrations:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
The problem can be bad gas control valve, air in gas line, low gas pressure, gas shut off handle not fully parallel with gas line, dirty combustion parts, lack of combustion air, improper venting. Or combination of all things. It's an electronic gizmo, anything can be bad or shorted, and repair may not last long.
Without a trained service technician to ohm-test the parts using correct service manual, then we are guessing at the cause.
Power vent water heater implies that you have side wall venting which must be replaced with another side-wall vented unit -or- it implies rapid reheating of water.
If water heater is more than 6 years old, you might be money ahead by installing a new one from local box store. Avoid the power vent and electronics. Local box store will have passive roof-venting type water heater BUT box store does not sell side-wall power vent. If your power vent goes up through the roof, then box-store variety gas water heater will work. Total cost $350 do-it-yourself for 40 gallon gas.
Or get 40 gallon 240Volt electric for $220 and connect to circuit breaker box. Requires no venting, and is easy to repair for years to come.
Or small 120Volt electric that plugs into outlet to tide you over until gas repairs can be made.
Look for scratch-n-dent models and always offer 10% off.
Shower uses 5-9 gallons hot water.
Aug 01, 2011 | Rheem Water Heaters
When water heater is off a strong gas odor is present. checked by closing or shutting valve control assembly to off positon, where no gas ordor is present.
You may have a leaking gas valve control. Make up a squirt bottle of soapy water (use dishwasher soap and water) and spray the On-Off-Pilot knob for leaks, as well as the pilot button. Look for bubbles forming. Also check all the gas line fittings and connectors hooked up to the water heater for leaks. If you are smelling gas, do not attempt to relight the water heater. Close the shut-off valve on the gas line and see if the gas smell goes away. If it does, you may have to replace your gas valve. Depending on the age and condition of your water heater, it may be more cost effective to replace the control or buy a new water heater. Reliance is a common brand sold at stores like Lowe's. Typically, parts like your gas valve will usually only have a 1 year warranty. Check the manufacturer decal on the tank to see what their actual warranty period is. If you find a leak on the gas line itself, you will have to turn the gas off at the natural gas meter before disassembling the line to fix it. Use a soft setting teflon based pipe dope for the pipe threads. If you are uncomfortable doing the work yourself or don't know how to proceed, then call your local gas supplier for help. Douglas
Sep 02, 2010 | Reliance Water Heater #6-50-GORT 50GAL...
Water Heaters Logo
61 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
