Question about Alessi MG32 Cordless Electric Kettle
My water is not heating in my electric kettle
The light comes on but the water doesn't heat - the heating element needs replacing - where in Mumbai or any other city in India is there an Alessi service centre.?
jerryg50
  • 1673 Answers
SOURCE: Alessi Electric kettle
The switch is most likely defective and has to be changed. It is also possible that the heating element is pulling too much current and also has to be changed.
An appliance service tech would have the tools to test the kettle and determine the exact fault.
Jerry G.
Posted on Apr 29, 2008
  • 351 Answers
SOURCE: Where can I buy spare parts for the Alessi 9093 cordless kettle?
This site seems t0o have the parts yo are looking for ..
Alessi 9093
http://themagazine.info/products/-/167.html
Posted on May 11, 2010
  • 9 Answers
SOURCE: MG32 Cordless Electric Kettle: Power light shows on my kettle but water does not...
sounds like there's water in the element. Empty it out and let it dry out completely for a few days, and then try it again.
If the element is a concealed element (ie- you can't see the coils when you open the lid up) then there's probably a water leak into the sealed compartment.
Contact the manufacturer for a recommended repairer.
Posted on May 23, 2010
eugbug
  • 479 Answers
SOURCE: My daughter bought me an
Have you tried using it on a different socket outlet ? Possibly there is a problem with the wiring at this socket.
If the electricity supply "trips" at the consumer unit it is either the RCD which trips due to e.g. the base of the kettle becoming wet or alternatively the MCB tripping due to an overload which shouldn't happen unless there is a fault in the kettle.
When you got a replacement kettle presumably they replaced the base also?
Posted on Sep 04, 2010
drifterK
  • 4924 Answers
SOURCE: the handle fell off the kettle, how can I re-fix it?
If it do not have any obvious way to fix it (locking clips or screws) and it was just inserted on the metal part ..than you can use some kind of glue for plastic and fix it back again .a super -glue will work or a strong plastic adhesive .Clean both ends so that any grease to be removed...and apply the adhesive on the plastic end .. and than insert it to the metal end ..in such a way that the adhesive to fill the space and the excess substance will drain off when you press them together. leave them to react for a while without touching them ..be sure you choose a temperature resistant adhesive ...
Posted on Nov 17, 2011
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
Alessi Kettle light comes on but wont boil
I have seen an open heating element, or a thermo fuse cause this type of fault.
Jerry G.
Jun 06, 2012 | DeLonghi KBO3001 Cordless Electric Kettle
It blew my fuse box, i have changed the fuse the light comes on but it is not heating up approx 5 years old
This happened to my Alessi kettle also. I changed the fuse in the plug but the kettle is dead! Red lights are on but the heating element in gone. From what i can gather parts are not available to fix it.
Feb 15, 2011 | Alessi MG32 Cordless Electric Kettle
I need to buy optio w90 pls provide address of distributor/dealer in india city pune /mumbai
as of now, there is no official dealer but there's a distributor:
IDLDPL (India Digital Life Style Distributors Pvt. Ltd.)
407, Arun Chanbes, Tardeo Road, Tardeo, Mumbai-400034
022-6610801, 03, 04
022-66106802
Jun 11, 2010 | Pentax Optio 50 Digital Camera
May 17, 2010 | Alessi MG32 Cordless Electric Kettle
Jerry G.
Apr 26, 2008 | Alessi Al384730-640 Cordless Electric...
Alessi MG32 Cordless Electric Kettle Logo
212 people viewed this question
Top Alessi Kitchen Appliances - Others Experts
Jerry Greenberg
Jerry Greenberg
Are you an Alessi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
