Question about Microsoft Computers & Internet
Format pc when install windows again no hard found
  • Microsoft Master
  • 5,631 Answers
So I understand that your computer can't recognize the Hard Disk installed. Means your device is in a really bad condition, probably stone dead. You can't do anything with a hard drive if it is not recognized, but remove it, use it as paperweight and install a new one.
Posted on Apr 11, 2015
Unable to format Seagate ST9500423AS
Have you tried reformatting your hard disk? this happened to me when i tried to us PartionMagic tool. my hard disk stopped working tho' it's still showing up when i plug it in another PC. this is how i get it working again:
i plugged my hard drive to another PC and i used DiskPart to clean it and i formatted it in Windows Disk Management.
it worked for me and i doubt, there was an error partitioning my hard disk so i needed to make it fresh again.
Apr 18, 2013 | Seagate 500GB ST9500423AS 7200rpm SATA2...
During restore windows i found error "Windows could not complete the installation. To install windows this computer, restart the installation.
Reboot windows without any CD in drive and tap F8 key before windows screen appears. Select safe mode from the menu that appears and elect to do a system restore.
If this doesn't work you could try changing the boot order in the bios ensuring that your hard drive is first boot device. should get into bios when starting PC usually F2 or del key. remember to save changes in bios normally F10
Oct 13, 2012 | eMachines E730, Core i3-330M 2.13GHz,...
How to format r51
You can use your Windows installation CD to format the hard drive and install Windows again.
Boot up the ThinkPad with the Windows installation, follow the instructions to delete the existing partition, then create a new partition, then format the hard drive - do a full format, NOT a quick format.
You can then continue to complete the Windows installation.
Aug 06, 2011 | IBM ThinkPad R51 Notebook
No Hard Disc found after crash
Compaq uses F10 at boot to initiate the recovery program resident on the hard drive partition normally called "Recovery". If you cannot initiate the hard drive at boot then press F1 to get to setup and see if the hard drive is recognized there. If it is not then you will have to troubleshoot the hard drive.
If you have another laptop to try the hard drive out or a laptop to IDE hard drive adapter  (cheap) to connect to a desktop computer as a slave drive you will either verify that the hard drive is bad or it is good and a boot sector problem is at hand. Also if you can get the drive recognized as a slave drive you can either rescue data or format the drive.
These are preliminary steps so post again when you have more information. Steve Medley
Jan 26, 2009 | HP Compaq nx6310 Notebook
Hp laptop has failed to start windows
Hi , You need to run Format the drive before you install Windows.
Jan 05, 2009 | HP Pavilion ze4200 Notebook
Brand new hard drive >>>>> problem ? yeah ........my bad .
Vincent:
It sounds like you corrupted your install of WinXP...it happens.
What you need to do now is (first take a deep breath)...OK, that's better.
When you boot your PC, make sure your WinXP CD is in the CDROM drive. You'll only get a 3-5 second window to catch the "Press any key to boot from CD" message as it pops across the screen...you have to be sitting there, in front of the monitor waiting for it to display (or you can just start pressing the space bar or any other key every second or so as the system boots).
Don't just hold the key down because you'll get a "Keyboard Error" if you do that.
Just wait until you see the boot from CD prompt and hit a key - this will get you back into the WinXP CD's setup menu.
Follow the instructions that I posted before for formatting the drive using the recovery console (Found Here).
Apr 24, 2008 | Compaq Presario SR1800NX Desktop PC
Intel Pentium IV Trouble (40gig)
os not found usually means that your hd is faulty.
try remove hd and reseat it.
if no joy have os disk(windows) in cd drive start pc and boot from disk.
select install windows...system checks drive and informs of existing os..want to continue...install windows...next screen shows partitions.choose to delete partition then create new then format and install.
if when u try to boot from disk system say no hd found then hd is damaged.
Mar 14, 2008 | Computers & Internet
Problem in hard drive
The hard disk may have some bad sectors. Try zero filling the hard disk. Try to download the programs from http://www.samsung.com/global/business/hdd/support/utilities/Support_HUTIL.html You will come to know if your hard disk is the culprit.
Oct 06, 2007 | Microsoft Windows XP Professional With...
IBM Netvista 6059 - Can't upgrade to windows XP
Right well XP Pro really MUST be formatted with NTFS only... I suggest you get a third party partitioning program like Partition magic and completely remove the partition & redo it all again & this time Format NTFS. Or if ya have a WIN98 boot disk, and ya can use FDISK, Delete ALL partitions, and remake them again, using all the disk space, then format as NTFS, then proceed as below Then using your windows XP PRO setup Disk, start the install ...then when asked about where you want the install located, select C & REFORMAT it AGAIN with the windows setup using again NTFS file system... this should finish & then the Install should "see" your entire hard drive and format it accordingly and then when finished you can proceede to install XP.
Sep 04, 2007 | IBM NetVista PC Desktop
Computers & Internet Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
