My screen is blank. But when I purse any button it goes on for 3 to 6 seconds then goes off. Need help?
    Top Expert:
  • 10,875 Answers
Make sure all connections are tight and computer is on,unplug from comp and re plug in
Posted on Apr 11, 2015
tantong
  • 138 Answers
SOURCE: Screen's gone blank and the green power button flashes intermittently
This is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
nickpower
  • 43 Answers
SOURCE: Monitor goes blank less than a second after turning on.
YOU NEED TO HAVE THE INVERTER BOARD REPLACED.
YOU CAN USUALLY FIN THEM ON E BAY OR YOU WILL HAVE TO TAKE IT IN IF YOU DON'T FEEL COMFORTABLE REPLACING IT YOURSELF.
Posted on Dec 19, 2008
  • 89 Answers
SOURCE: pavilion f1903 silver goes blank seconds after turning on.
The monitor you have has bad components on the circuit boards inside.
This is a classic problem with all LCD monitors.
I rebuild them on a daily basis so I recognize the symptoms.
I would suggest finding someone who can do component level repair on the circuit boards inside.
I also suggest not trying to repair yourself as there are many breakable components to them as well as components inside that do not like static electricity discharges.
Posted on May 17, 2009
  • 1684 Answers
SOURCE: same problem
The problem that we have found on that model is bad solder joints on the power board. Th board has coils called inductors that carry a good deal of current. The solder connections melt and the circuit breaks. You should be able to remove the back of the monitor and you will see one or more solder joints that are not making connection. heat up a soldering iron and apply a little bit of new solder to the connection. Re-assemble the monitor and you should be back working.
I hope this helps, If so please rate my solution.
Check out our web site for other monitor and printer repair tips. www.ccl-la.com
Buddy
Corporate Computer
Posted on Jul 20, 2009
fredtmccoyjr
  • 380 Answers
SOURCE: Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Posted on Jul 21, 2009
Display is Blank
Step 1:
Press the Blue key/button.
Step 2:
Press the "Settings" button.
Step 3:
Press the "Screen Saver" button.
Step 4:
Adjust your screen saver time. Not sure if this is the problem you are having but give it a try. Please add more info about your problem to get more help. Good Luck.
Mar 18, 2013 | Mitel 5330 IP Phone
Gx620 boots up, then screen goes blank, reboot gives blank screen with cursor blinking. will boot with cd but still shuts down after a minute or two.
Remove the battery and open the case. Look inside the computer with a flashlight to see if any of the capacitors are busted or leaking from corrosion. The capacitors look like little battery towers, but they are not as tall as the AA or AAA batteries.
If the capacitors are bad, your computer goes bunkers.
Apr 30, 2012 | Computers & Internet
3/4 of my camera screen is all white and i don't know what could have happened to it because i haven't dropped it, but it has been in my purse for a long time, but nothing in my purse is heavy...
Possible that the LCD screen has failed. You can take images and load them to the PC.,If the images are clean then the LCD is a suspect. remove the battery for sometime and reset. If the fault occurs as a blank screen then the LCD must be taken out and checked for possible damage.
Jul 11, 2011 | Cameras
I have a Nixon LowDown Tide Watch and the screen is staying blank, almost as though it is in a battery saver mode unitl i press any button and its display turns on for 3 seconds or so then goes back to...
Hey, this just happened to my nixon watch (I have the nixon housing - same setup as the lowdown) and what you have to do is simply hold in the light display button for about 3 seconds and the display won't disappear after the light times out.
hope this helps :)
Apr 09, 2011 | Nixon Lodown Tide watch
Blank screen, triple beeps when trying to shut off
I have looked around for you and here's what i found:
Try holding down the power button on the front of the unit till you hear a beep (4-5 seconds). If you don't the unit will power on, but won't reset the video settings. Most people don't hold the button down long enough.
i hope i have helped and i hope it works,let me know how goes !!
Jan 04, 2010 | Sony Playstation 3 (PS3) Console
Screen Goes Blank
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Radio screen goes blank every so often
yep, or unit has a problem it self.
Apr 13, 2009 | 2004 Honda Accord
Dec 18, 2008 | Proview PL926WBi 19" LCD Monitor
Screen goes blank
I put a new CR2025 battery in my T5e671 Timex and it solved the problem.
The screen no longer goes blank at any time.
PS:Timex manual says "remove battery strap" to replace the battery.
But it doesn't say HOW.-& I couldn't google an answer to that.
Here is how:
The metal strap goes across the middle of the battery and then goes over the edge of it on both sides.
At both edges the metal strap goes over a nylon tab.
One of those nylon tabs is notched, if you put the end of a paperclip in the notch, you can release the metal strap edge that runs under it.
Oct 14, 2007 | Timex Ironman Triathlon 51931 wristwatch
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
