Question about Smeg Dishwashers
My Smeg Dishwasher has not drained the water and it will not turn on.All lights are off and will not turn on. I have turned it off and on at the plug - still nothing.
    Top Expert:
  • Smeg Master
  • 10,875 Answers
Check circuit breaker
Posted on Apr 11, 2015
No power after blocked drain dishwasher
Reset it by turning power off to it or unplugging it for a minute. If it still wont work then you need to take the kick panel off and see if there is leak under the machine.
Feb 08, 2014 | Smeg Dishwashers
When I turn on the dishwasher, the light on program 6 flashes but the program will not start.
Pull the power plug or turn off the circuit breaker for about 30 seconds, plug it back in or turn the breaker on and the diswasher brain should have reset. Good Luck.
Dec 14, 2017 | Smeg 24 in. DWI612 Built-in Dishwasher
HOW DO I DRAIN WATER FROM MY SMEG DISHWASHER
There is a screen filter at the bottom of most dish washers, if the screen gets dirty it probly won't drain properly. Check the screen and clean if neccesary. If not that, then pump may be getting weak.
Jun 25, 2012 | Smeg Dishwashers
SMEG DWI612C WON'T PUMP WATER OUT
even if the pump is running does not mean the impeller shaft is turning, You could unplug the machine and disconnect the washer and pull out and drop the hose to see if water will drain when you lower the hose to about 8 inch's does it run out freely? if not check for a plugged water pump or water pump hose if the water flows freely you will need to drain the washer if it's on rollers roll it out side to allow the water to drain out the machine from the porch. while it is draining check the hose that the washer connects to see if you see any plug in the pipe. put the sink drain plugs in and fill half way with water put a bucket under the sink after filling the water to half full pull the stopper out of the sink that connects to the dish washer. Hold your hand on the hole of the connection to the sing watch to see if the drain allows the water to flow. If it flows freely you can assume that the water pump is bad. If thats the case it's best find someone to replace the unit the pump can be replaced but you need tools to do so and you did not state if you had any. thanks for using fix-ya.
Apr 18, 2010 | Smeg 18 in. DWF409WH Slim-Line...
Water hasn't drained and combination of lights notin troubleshoot
Here is a tip that I wrote that will help you with your problem...
Dishwasher2_bing.gif Problems - Water will not drain out
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
heatman101
Mar 29, 2010 | Smeg STX2 Dishwashers
Will not finish the cyle and is not draining the water
more than likely your drain hose is plugged or something in the pump is plugging the drain hose using a wet vac the water out of the drain hose and see if you get water out of it if not take hose off from bottom and try reverse suction to ensure hose is clear most dishwasher will not complete cyc if float is in the up position and will not advance.
Aug 21, 2009 | Smeg 24 in. DWF614SS Stainless Steel...
Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
Apr 07, 2009 | Smeg CSU2001 Built-in Dishwasher
SA 660 SMEG dishwasher constantly filling....
this can be water draining from your sink into the dishwasher via the drain pipe, assuming the drain pipe goes to a spigot on the sink trap.
take the drain hose up as high as possible in a swan neck to prevent this.
Jul 17, 2008 | Dishwashers
Dishwashers Logo
89 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
