Question about Garden
Mower starts and runs but will not move forward or back
    Scholar:
  • 140 Answers
If it is hydrostatic, the release lever is probably pulled. This allows it to be pushed or pulled. This little release is usually located low on the rear of the tractor. Make sure that the little wire hook is not pulled out and hooked.
Posted on Apr 11, 2015
    Sergeant:
  • Garden Expert
  • 187 Answers
In addition to the by-pass lever that Kevin mentioned, the brake/clutch pedal also activates a fluid by-pass. So check that the rear lever is all the way in. Make sure it is still connected up by the transmission. Then make sure the brake lever is properly connected and fully released. Unless you have a problem inside the tranny, that should get you going.
For a machine specific diagnoses we need
  • Make
  • Model
  • Year
  • Engine Model
  • Transmission Model
  • Deck Size
  • Hours on meter (indicates wear patterns)
  • If you haven't already done so, add a short description of the events preceding the beginning of the problem.
  • Kprime
    Kprime Apr 11, 2015
    forgot to mention, the tranny is belt driven. Check the belts and pulleys that go to the tranny.
Mower starts and runs but won't move forward or reverse and brakes don't work.
If your transmission is automatic on the drive axle, look for a small lever inside the frame and below the seat. It can be hard to find the first time. This lever disengages the drive inside the auto gearbox so the mower can be pushed by hand. If the lever is not not moved, pushing the mower also tries to turn over the engine making it impossible to move. With the lever moved accidentally the drive is disengaged and the mower won't move in either direction. The lever operates a flexible cable that comes out from the auto transmission.
Dec 12, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
Mower will not go forward .... it runs .... and the deck still engages but will not move forward or backward
i would inspect the belt the mower and the trans operate from different belts
Jul 10, 2012 | Garden
24 hp LA165 mower. While mowing the mower stopped moving. Engine runs, blades turning but won't move forward or backward (the side lock has been released and the pin at the back is pushed in) 11...
check the connecting rod to the tranny. follow the gear handle and you should find a rod connecting the handle to the axle make sure you're in neutral and adjust the rod until the handle starts to move
Jul 17, 2011 | John Deere 24HP VTwin Hydrostatic 48"...
Motor runs, but will not go forward or rever
if you can push mower by hand ? there is a shuttle valve that may have got turned on , its a little handle in the back of the mower that turns off the hydrolics so you can move the mower without the motor running
May 21, 2010 | Garden
Murray Riding Mower will not move forward or back
my murray Riding Mower will not move forward or backward
Jun 22, 2009 | Garden
The cable traction cable is broken on my toro personal pase lawn mower. part number 105-1844 how do i change it
I changed the cable on my toro mower but i cant make it go unless i pull back on the handle .i cant find a picture to see what i am doing wrongcan you help. Thanks
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Hydrostatic mower goes in reverse but not forward. Only 73 hrs on it!
On my hydrostatic there is an adjustment on the forward/back lever which can be made to run all reverse or all forward. Normal setting gives both of course. Look at that adjustment. Maybe something let go.
Oct 14, 2008 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
