Question about Microwave Ovens
Microwave turn table does not work - Microwave Ovens
    Top Expert:
  • Microwave Ovens Master
  • 44,530 Answers
Check for a broken rubber drive belt underneath
Posted on Apr 11, 2015
Why is my turntable not turning in my microwave oven?
Is your microwave clean under the table? No stuck on food or anything? Does the the oven work without the table?
Does the little prop in the centre that turns the table move when there is no table on it? Try to carefully clean it and see if that helps.
Feb 17, 2015 | In Microwave Ovens
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Thanks
Nitin
Oct 19, 2013 | Microwave Ovens
My Kenmore Built-in microwave doesn't heat and the turn table doesn't turn. Model 911-47812200
It is good that the microwave does not work all together. It might be an interlock button or even a relay connection burn on the main mother circuit board.
Need a qualified technician. The service manual will be like $20-50.
e
Nov 22, 2011 | Microwave Ovens
Microwave Drum not moving Problem
Remove the plug and take the turn table out of the microwave cabin. Now keep the microwave rested on the side andopen the back pannel,you can see the turn table belt drive.If this is broken replace.if not trace the motor connection and mark them.Now heat the microwave in normal position,place the turn table and a cup of water.Close the door and switch on the microwave set for a minute.Now check the voltage on the motor line marked.If present ,then the motor is fault.If not the controller board is faulty, and must be traced.Can be the relay drive or the relay. hope the other sections are working fine.
Aug 31, 2010 | Microwave Ovens
Defective turn table (not working).
opening a microwave oven is not recommended at consumer level due to hazardous internal componants. Seriously hazardous.
Oct 27, 2009 | Sharp R-1214 Microwave Oven
TURN TABLE QUIT WORKING
take down the bottom panel and replace the turn table motor p# wb26x10038
Mar 20, 2009 | GE JVM1631 Microwave Oven
Turn table
The 22 seconds is the giveaway.
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 22, 2008 | Panasonic NN-S262SF Microwave Oven
Microwave Oven EM-804T
You need to trace the power feeding the high voltage transfomer. Because the table doesn't turn, it implies that a door switch or safety interlock is the problem.
Jan 01, 2008 | Microwave Ovens
Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Microwave Ovens Logo
43 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
