Question about Samsung Captivate Cell Phone
My Samsung Galaxy S Captivate has a loose charging port. It will not charge unless I push up on the cable at the exact right spot. How can I fix this?
    New Friend:
    Problem Solver:
  • 7 Answers
Maybe try using a different USB connector. It may not be your phone, but the wire or wall plug itself. If that fails then I'd suggest taking your phone into a phone repair store to get your charging port replaced. The same thing happened to me and I took it up to foxpaw and it was only about $50. A new USB cord is around $5 at any walgreens or gas station.
Posted on Apr 11, 2015
How do i fix a battery on a samsung tablet
The problem may be a frayed wire inside the charger cable right at the connector, or the charger jack may be worn or have a cracked solder connection. If it charges reliably with a different cable (such as a USB cable connected to the computer, it is probably the charger cable. If it has to be wiggled to get it to charge with a known good cable, then the charger jack should be replaced. This requires an expert technician; the solder connections are very small, and the circuitry requires special handling because it is easily damaged by static electricity.
Apr 28, 2016 | Samsung Galaxy Tab 2 7.0
How can I repair charging point on Samsung ce0168?
Samsung CE 0168 cell phone: repair charging port:
The simplest way to repair it is to take it to a local cell phone repair shop and let them do it for about $35 to $50. I would determine first if that is worth the phone to do so.. If not, it may be more economical for you to just buy another phone.
Parts for this particular device are not easily found. And, you can't just call up Samsung Customer Support and say you need this part. Parts are usually sold through 3rd party cell phone repair centers only.
The schematics for this device are not readily available and there are no known repair videos online for you to follow.
Jan 11, 2016 | Samsung Cell Phones
It charges somtmes but only 26% now it wont charge and wont turn on i have changed cords and plugs nothing works please help
1. is there lint or some pants pocket debris or dirt inside the charging port on the bottom of the phone? use something non metal that won't break inside, it needs to be thin enough to move around and poke around the bottom, not interfering with the chip that sticks out.
charges-somtmes-but-only-26-now-wont-c42sdu52tip34gjoftdmfcql-4-0.png before you do that.. turn off the phone and take out the battery just in case. you don't want to short the charging port, so why risk it.
you can use a thin side wooden tooth pick (not the thick rounded ones, they won't fit), or you can use an unused plastic brush tooth pick that's available at most stores like Walgreens, CVS, Safeway, etc..
2. If nothing comes out, try using a different wall charger adapter that works for your Samsung device. Many cell phones use a 3volt charger that won't work with Samsung smartphones because Galaxy phones need a 5volt charger. The others will just trickle charge it or may not work at all. Also, the cord itself. You can't just use any micro USB charging cable. You need to use one that can push enough electricity to your device. So it has to be a Samsung smartphone compatible one. If you have ruled this out..
3. Is the wall outlet bad? Try a different wall outlet. Example: at the airport we tried all the wall outlets in the same area, none of those charged the device. We thought it could be the charging cable or the adapter that was dead. Then we went to another area in the airport and tried again. This time we were charging the phone fine. Cable and charging adapter were apparently working great.
4. If that's not it.. what happens when you try jiggling the charging cable connected to the phone.. try angling the cable head to the left or right.. does it only charge when in a specific position? it could be the charging cable or the charging port that needs fixing..
5. If that was not the case, and everything you've tried doesn't work, it could just be the charging port on the phone is bad. Bring it to your local cellular repair shop. It should cost around $35 to $50 to fix.
6. If your phone is not worth it to fix it, it might be a better idea to buy a newer model phone. If you can't afford another phone or to fix the port, why not just buy a separate battery wall charger. You can buy a cheap China version to charge your existing battery outside of the phone and then just pop the fully charged battery in when you need to use the phone. I'd recommend charging the battery when you are sleeping.
The attached link is to an eBay listing that has a compatible wall charger sold in the US for $5.99 shipped free
LCD Battery Charger for Samsung Galaxy Mini GT S5570 i5510 S7230 S5330...
Nov 10, 2015 | Samsung Galaxy GT-S5570
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
My galaxy 3 phone will not charge properly how do i fix it
Charging issues is a process of elimination. First the charger....many chargers will fit but not all that fit will work. A bluetooth charger will fit but would never charge your battery completely. Make sure you are using a proper charger. 2nd is the charging port on the phone. If the charger is loose it could be a bad port or the prongs on the charger are not holding....is it loose? Or if there is corrosion on the port. If corrosion, clean with alcohol and tooth brush. 3rd is the battery. If its swollen, then it's toast. A li-on battery will start to decrease after 400 to 500 charges.
Jun 18, 2014 | Samsung Galaxy S 4G Cell Phone
Where can i get my galaxy s charging port fixed and how would the port become loose?
If it's loose it is probably broken away from the internal circuit board. A common problem. People accidentally knock the plug sideways and they only have fragile connections.
Get a technician to resolver if possible or take to Samsung repair centre.
May 02, 2014 | Accessory Export Samsung Galaxy S i9000...
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
P5113 not charging properly
There are a couple of common problems that can cause bad charging:
  1. Bad charging cable - try a new cable
  2. Bad charger - try a new charger, or try plugging it into a PC USB port overnight with the PC turned on
  3. Charger is not the right charger for your tablet - Samsung devices are known for being picky about what charger you use. If you don't use the original charger that came with the device, or a Samsung charger made for your specific tablet, you will have trouble.
  4. A bad/broken charging port on the tablet - this is not something you can fix yourself. You would likely have to return it to Samsung for repair, or find a local repair shop.
Jan 07, 2014 | Samsung Galaxy Tab 2
Samsung Captivate Cell Phone Logo
60 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
