Question about Photography
How to make a monopod - Photography
I have the QSX Versipod 2 and the top broke. looking for replacement.
Sorry this site doesn't have any parts or anyway to look them up for you.
Nov 29, 2016 | Photography
How do I change the thread size on my monopod?
You should not need to change the thread size on your monopod. All tripods, monopods, cameras and other accessories have standard fittings. Check that you haven't accidentally crossed the threads on your Panasonic which would make it difficult to locate the threads to tighten it.
Also, check that you are not trying to screw the monopod into the hole. Some cameras have a smaller hole beside the tripod thread.
You may be able to contact your monopod manufacturer in case they supply an adapter that wasn't supplied with your monopod.
Sep 18, 2014 | Manfrotto 290 Series 59.4" Monopod
How do you rebuild a manfrotto 685B monopod
You can find parts at www.ManfrottoTripodParts.com
Depending on how much work it needs you will need leg locks and a foot and possibly a head.
Feb 11, 2013 | Manfrotto Photography
Monopod is slipping
If the monopod is slipping and getting shorter as you use it, then find the clamp that is not secure. flip open the clamp lever and using a small socket wrench, turn that nut about 1/8 of a turn. Test the slippage. if is still slips give it another 1/8 turn. Do this until is is not slipping. Do not over tighten the nut or you may damage the clamp or leg tube.
If it is the head, I will need more info as to which head you have on that monopod.
Nov 03, 2012 | Manfrotto 681 Monopod
Broken Head of Monopod
Contact Sunpak direct, they are required to sell parts.
Apr 15, 2009 | Sunpak 9002TM Tri-Monopod with 3-way Fluid...
685B Monopod
If In melbourne look up www.adeal.com.au . They are wholesalers and DO NOT sell to the public, but if you go out to them in Altona North they will help you over the counter. Or go to any TED's Camera Store. They sell the range of Manfrotto tripods and they will be able to help you.
Jan 12, 2009 | Manfrotto 679B Monopod
Titan II Monopod Quick release
Go to Spartan Photo Center.Com and order the part. The size of the quick release is listed inside the receiving end of the mount
May 10, 2007 | Quantaray Clamp Pod Flexible Monopod
Photography Logo
185 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
