My tv screen has colour patches.how i remove it. I havent degussing coil so please tell me the method for remove it.tv degussing coil coil reading 18 ohm
    Top Expert:
  • Televison & ... Master
  • 75,462 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Posted on Apr 11, 2015
Removal of colour patch in lg tv
My lg 21inc flatron tv has one side with red spot and aother side has green spot
how to remove it
May 19, 2010 | Televison & Video
Top portion of the screen is some what green. Every thing else is OK
If you have green patching or anyother colour patching on the screen, your TV may need de-gaussing. The problem is caused when a magnetic field comes close to the TV. A simple solution can often be achieved with a fridge magnet, by moving it over the green patch and pulling it away in certain directions may solve the problem. A TV tech will have a de-gaussing coil which can solve the problem in a matter of minutes.
Sep 26, 2009 | Sylvania 6427TE 27" TV
Screen series of coloured circles
The degusser is out .
When you turn the set affter its
been off awhile it makes a thud sound
and demagnatizes the tube thats
the degusser working . cost to
fix verries on makes 40.00 80.00
on 27"
Jul 01, 2009 | Televison & Video
Sharp tv
First chanage your tv direction if not work than
Use external degaussing coil to remove magnetic fields shows on screen.
Jun 17, 2009 | Televison & Video
Bush tv has a circle on screen like looking thru a telescope
HELLO
Funnily enough I have been given a 21 inch standard Bush set with the same problem!
It's a DEGAUSSING fault. This means the deguss circuit in the TV is not operating as it should - probably a faulty positor. When you switch the TV on (NOT FROM STANDBY) the circuit that removes magnetism from the screen does not work correctly.
Switch it off, unplug the set from the mains for 30 minutes or so and try it again. If there is no change, contact a TV repair centre.
Make sure there are no hifi loudspeakers next to the TV or a radiator as this can have an effect too.
ALL THE BEST! (:-)
Jan 06, 2009 | Bush 5693D 24" TV
Monitor colours are only fluro purple & green!
use a 10 ins, speaker magnet to front of picture tube degussing color
Nov 29, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv screen
Did the set get dropped?? If it did the picture tube shadow mask inside the tube is bent and there is no cure for that. If not then the degussing curcuit could be at fault. try unplugging the set overnight and plug back in in the morning. did it help at all or a little, if it did but not all the way back to normal do that unplugging like three nohjts . If that dosent cure the problem then you have a bad degussing curcuit and on this set a cold solder connection On the thermistor for the degussing coil is A very very popular repair. Good luck
Apr 25, 2006 | Daewoo DTQ-27S3FC 27" TV
Screen discolored
did you have a speaker of move something magnetic by the front of the set or move it to a differant location?? Try to unplug the set first for several hours then plug in cold and see if that takes care of your problem.. If it doesent take all of the discoloring away but did a little try this procedture a few more times cold. if its making no differance to the set then the degussing curcuit is not working in the set and your gonna need a tech to check out the relay or thermistor or to deguss the set with a coil.
Apr 05, 2006 | Sanyo DS27910 27" TV
A magnet touched my screen
My son touched my television screen with a magnet in two spots leaving two discolored areas on the screen,purple and green in hue. I read many quick solutions to this problem on the net and none seemed to work completely,so what i did is took the same magnet that touched the screen and held it in my fist,then with TV on i waved my fist all around the screen working from the spots outward to the edges and this worked completely! Hope this helps someone..
Apr 04, 2006 | Sanyo DS27800 27" TV
Televison & Video Logo
Top Televison & Video Experts
