Question about Hitachi 50V500 50 in. HD-Ready LCD Television
When I turned it on I get audio but the entire screen has vertical lines on it
Samsung TV display has gone out - has audio, but there are vertical, colored lines/bars across entire display.
Call a television engineer. Don't try and fix it yourself it always ends badly and more expensive. Could be a board, a component on a board, a bad connection, or blown capacitors. The course is 2 years full time education.
Apr 30, 2018 | Samsung Televison & Video
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
Anything to do for vertical lines on screen?
most likely a damaged sensor. How about the pictures? Do they show these lines on them too?
Oct 23, 2015 | Canon PowerShot ELPH 340 HS Digital Camera...
Vertical Lines over entire screen.
What is the brand and model number (not indicated here) so I may try to give you an informed answer.
Mar 31, 2012 | Televison & Video
I turned it on and just one line accross the screen appears. the audio is fine.Everything is normal except theres just a line on the screen.
You have a vertical problem. You may need to resolder the vertical IC, and check each cpacitor that is near the vertical IC. Your TV will be restored to full screen!
Mar 27, 2010 | Televison & Video
Dell 1720 screen
If you can see the vertical lines during POST, try to check the vertical lines in BIOS. If the vertical lines are there in BIOS, the only thing you can do is to replace your LCD screen.
Oct 31, 2009 | Dell Inspiron 1720 Notebook
Vertical lines across my entire screen
My 42" Samsung Plasma HDTV HP-R4252 has a 2" vertical strip of green pixels down the right side of the screen.
My 3 year warranty with Circuit City expires in Nov 2008.. so I hope I'm covered.. can't call until the morning.
Samsung said it might be a logic board problem.. but they want almost $2000 to fix. I might as well buy another TV if Circuit City can't fix it.
Apr 19, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Picture shows only about a 2-3" blue,green,or red vertical line down the middle
If your seeing vertical line across the screen you need to check the components in the vertical stage as well as the vertical IC could be bad, or the yoke could open.
Also check if any voltage reaching the vertical stage.
Good luck.
Was this help full.
Oct 31, 2007 | Panasonic PT-47WX53 47" Rear Projection...
Tube turns on nothing else does
If the Tv turns on (power supply is ok), screen lights up (inverters are ok) but don't get a blue screen, menu options, source options, or audio, it's most likely the main board (aka Motherboard) is faulty. If a DVD player is hooked upto the TV, check whether you can get audio from that (change the source using remote), in such a case it could be a problem with LCD Interface board. My $3 is on faulty Main board.
Jul 27, 2007 | Sanyo Vizon LCD-15A2 Television
Hitachi 50V500 50 in. HD-Ready LCD Television Logo
44 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
