Question about Sharp Televison & Video
I have a sharp vcr vC992 what is sp the menu pops up and sound but movie not working
  • Sharp Master
  • 5,151 Answers
SP is standard play. If you are playing a VHS video and cannot see the picture, but you can hear the sound playing. Then you need to clean the video head inside the machine. You can get a head cleaning tape to do this. That should restore the picture.
Posted on May 05, 2015
3 Suggested Answers
bshldn
  • 736 Answers
SOURCE: Have a Sharp VC-H810 vcr
Unfortunately if there is no menu option to do that or button on the VCR you will need one of these remote controls
http://www.replacementremotes.com/SHARP/Buy-RRMCG1236AJSB-VCR-Remote-Control.html
or
http://www.replacementremotes.com/SHARP/Buy-RRMCU0002AJZZ-Remote-Control.html
Posted on Jan 07, 2011
SD Tech
  • 14553 Answers
SOURCE: how can I get my VCR to go from SP to EP?
Most of these there is either a button on the front or ONLY on the original remote--if no button on unit itself you need that remote.
Posted on Apr 23, 2012
How can I get my VCR to go from SP to EP?
Apr 22, 2012 | Televison & Video
Have a Sharp VC-H810 vcr without remote. Is there a way tosiP, SP etc without a remote on the vcr? Thanks in advance!
or
Jan 07, 2011 | Sharp VC-H810U VHS VCR
My VCR won't play my movies! The tapes are fine its just when I put the tape in it just shows a scraggly screen. Everything is plugged in but my movies won't play. What do I do?
If the vcr is running the tape, your video head is probably dirty, try using a cleaning tape if you have one. The second option is use a brand new blank tape T120 and set the the machine to sp speed (2hr running time) and let the tape run the full course. The third option is to remove the lid of the vcr and carefully clean the video head with a swab dipped in rubbing alcohol rotating the head by hand as you proceed allowing several minutes to dry before loading your tape.
Dec 21, 2010 | Sharp VC-H810U VHS VCR
The VCR is stuck on SP when recording movies how do you change that?
There should be a switch, button on the front of the unit SP/LP or similar, you toggle that. It may also be a function under the remote.in setup.
Feb 22, 2010 | Sylvania SRD3900 DVD Player/VCR
Cant get rid of closed captions on dvd player
go to menu turn off captions thank you for using fixya
Feb 12, 2009 | Philips Magnavox DVD/VCR Dual Player
Changing from sp to ep
it will automatically play at the speed the tape was recorded at. but if you want to change record speeds here's how: you should be able to access menu functions from the front of the vcr, if so, put a tape to be recorded into the unit and then set the timer for a couple of minutes.while you are on the timer menu it will ask you for recording speed. set the timer record speed to ep and let it record for two minutes and let it record for the full time untill it stops recording. the record speed will automatically change settings to whatever you used last on timer record.
May 01, 2008 | Sharp VC-A560U VHS VCR
How to set the tape lenght when recording
on older vcr's there should be a sp/slp or ep button on your remote or vcr. if not when you set a program to record, the option to choose should be there. sp= 2 hrs, ep =6 hrs.
wg
Feb 17, 2008 | Sharp VC-H810U VHS VCR
Won't record with sound
Hi, click menu check mute might on /off it and test viewing records movies.
Dec 03, 2007 | Olympus SP-350 Digital Camera
Taping TV shows
You need to have an antenna in (from TV antenna or cable). Set the VCR to that channel and press RECORD. Or use the on screen menu to set up the recording time/channel
You really need to have a manual to find the step by step instructions for your VCR. Go to this website and search
for a VCR manual from Sharp. I was there and did not find the exact manual.Download a couple of ones that have similar model numbers and follow the process.
www.retrevo.com
Or call Sharp and ask them to fax/email you a manual.
http://promosearch.sharpusa.com/search/?sp-q=vc%20h954&sp-a=sp10009e61&sp-k=
Mike
Oct 31, 2007 | Televison & Video
Flashing
One possibility is the tracking/audio head is dirty. Remove top cover of VCR, this head sits just to the right of the rotating video head. Use a cotton swab moistened with rubbing alcohol, or other video head cleaner and clean this head, especially the lower edge, as the tracking info is recorded along the lower edge of the tape (if memory serves). Another possibility is a problem with tape travel past this head. If the tape is lifting or moving up or down, even slightly as it passes this head, tracking will be lost, hence your blue screen & bad audio. This could be observed by playing a tape with the VCR cover off.
Jul 10, 2007 | Sharp VC-H982U VHS VCR
Televison & Video Logo
260 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
