Cual es el statu de el caso de mi hijo el # es sdo2011637095
    Top Expert:
  • Televison & ... Master
  • 75,283 Answers
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 11, 2015
Cual es el codigo de chunghop rm-68e para una tv LG
0031 0384 0134 0193. Try these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Or, do a search by type in the brand name of your device at its search box, and press "Enter".
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
Jul 01, 2014 | Universal Remote Control Televison & Video
Quiero entrar en mi cuenta
Delmi, no dices donde esta tu cuenta (gmail, yahoo, hotmail, etc) ni cual es el problema por el que no puedes entrar. Estoy asumiendo que no recuerdas el nombre de usuaro o el password. Si ese es el caso, todos los servicios de email del internet tienen un link donde dice 'Reset Password' (restaurar paswrod) o 'Olvido su contrasena o olvido su nombre de usuario (forgot username or password). Usando el link appropiado, podras tener la oportunidad de accessar a tu cuenta denuevo
Apr 09, 2014 | Computers & Internet
Mi televisor es marca LG y quisiera poderlo apagar y prender con el control del dish network quisiera y me pudieran alludar?
Luis, mi nombre es Kimberly y formo parte del departamento Social Media con DISH. Es un placer poder asistirle. para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales sientase libre de contactarme directamente a: kimberly.escobar@dish.com
Kimberly.Escobar
Social Media Representative
DISH L.L.C
Aug 24, 2013 | Televison & Video
Como puedo programar el control de la Caja de dish network para que apague mi tv lg
Kimberly.Escobar
DISH L.L.C
Necesito programar mi television sanyo pero no tengo control remoto
Hola Rodolfo, para que su control funcione con su TV, el control tiene que ser programado a la TV. Tendra que hacer lo siguiente: Siga este vinculo, http://www.mydish.com/support/apps/remotecodes.aspx seleccione el modelo de control (este se encuentra en la parte de atras del control) Una vez usted haga esto, seleccione el tipo de aparato al cual necesita programarlo (en su caso es TV) Y despues la marca de la TV. Una vez usted haga esto le aparecesaran los codigos que posiblemente funcionan con su TV. El procedimiento a programar su control es el siguiente Oprima el boton de T.V localizado en la parte de arriba en su control por 5 segundos, despues cuando vea que los botones de arriba se iluminan ingrese un codigo seguido por el signo de numero por ejemplo: 585#. El boton de t.v debe de iluminarce 3 veces, despues de esto puede intentar apagar el televisor, deberia funcionar. Si tiene preguntas adicionales por favor contacteme a kimberly.escobar@dish.com.
Dec 26, 2012 | DISH Network IR Remote Control
Codigos de programacion para mi tv tecnomaster
mi televisor teenomaster modelo ttv-2124pf y chasi 01-11-ttv2124pf1026 se bloqueo y solo prende y apaga por el control no realiza ningun mando adicional no cambia ni puedo vajar ni suvir el volumen
Mar 05, 2012 | DISH Network IR Remote Control
Tengo un problema con un cadillac deville pasa el aseite al anticonjelante se calienta y pierde mucha fuerza asta no kerer correr mas el mecanico dice poder correjir el problema cambiando los empakes pero...
el problema de aceite mescandose con el anty congelante es por lo regular empaques de cabeza pero en algunos casos puede ser solo empaques de manifool de admission o en terminos usuales diriamos empaques de la arana asegurese que el mecanico le de un precio en caso de que solo sean los empaques de arana por logica seria mucho mas varato que los de cavezas. el caso de la cantada a que se devio le faltava agua? o estava tirando talves bueno a menos que la transmission no trabajava bien antes de la primer calentada estaria en mal estado pero si trabajo bien antes no tendra ningun problema. espero este comentario le ayude para ahorrar algo de dinero y trabajo buena suerte, informeme de lo que acontesca y grasias.
Feb 23, 2011 | 1998 Cadillac Catera
Silvania
Ulises realmente es un caso extrano, pero bueno todo puede pasar.
Fijate si no hay ningun boton en el televisor donde se pueda hacer un Reset
Esto seria de gran ayuda. Generalmente los botones de Reset no se ven, no estan a la vista, a los cuales se accede con algun pin u objeto.
Oct 20, 2008 | Televison & Video
Brakes
buen dia amigos.
Necesito conseguir el manual completro para reparacion del FORD RANGER MODELO 2000 supercab....estoy en Honduras C.A. y no logro conseguirlo, favor avisarme a mi e mail josehernandezsps@gmail.com y decirme cual es el costo del envio o en el mejor de los casos favor enviarlo por e mail GRATIS.
si es posible en español.
gracias espero
Jul 17, 2008 | 2000 Ford Ranger SuperCab
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
