Question about Refrigerators
Where do the shields go on at in refrigerator
How do I replace the lights in my freezer
Turn off the power to the refrigerator/freezer by flipping the appropriate switch in your breaker panel. Alternatively, unplug the refrigerator from the wall outlet.
Open the freezer door. Remove any items from the shelf directly under the light shield, then remove the shelf.
Press down on the top, front edge of the light shield until the locking tabs slip out of the slots. Swivel the light shield downward slightly to release it. Pull the shield out of the freezer compartment and set it aside.
Turn the light bulb counterclockwise to remove it. Insert the GE replacement bulb into the light socket and twist it clockwise.
5
Reattach the light shield by sliding it into place. Gently push the tabs into the original slots.
6
Insert the shelf into the freezer and reload it with the frozen food removed earlier.
7
Close the freezer door. Restore power to the refrigerator by flipping on the breaker or plugging it into the wall outlet.
Jul 25, 2017 | Freezers
GE Side-by-Side Refrigerator GSE25GGHBCWW has a buzzing noise if any food touches the plastic shield over the fan in the freezer section.
Try taking off the fan cover and see if the blade has slid too far forward on the motor shaft. If that's the case just push it back a bit to give it more clearance( do this with the fridge unplugged)).. It could also be ice buildup which is then hit by the blade at the slightest pressure..
Jul 12, 2017 | GE Refrigerators
Replace bulb in refrig compartment of model TFX25JRYF_WW
Hello Brenda;
My name is Peter. I am a retired field service refrigeration technician.
First, This is a special bulb. You can obtain the bulb in your local supermarket. They are a little more expensive than household bulbs.
To remove your light bulb shield, pull down on the bottom of the shield, pull towards you and lift up.
Dec 02, 2014 | GE Refrigerators
Light went out on refrigerator side
Your Sub-Zero unit contains standard 40 watt appliance bulbs in all compartments.
You'll need to remove the light shield in the top of the refrigerator or freezer to replace the bulbs. Place your hands under the light shield and release the two clips on the back of the light shield, then lift up and slide back slowly until the key slots on the side of the light shield drop past the mounting studs in the side walls. Then remove the shield.
The bulbs are now accessible.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 27, 2011 | Sub-Zero 690 Side by Side Refrigerator
Water leaking from ceiling behind light bulb near water filter in Frigidaire side by side FRS26LF8CS1
On your model the freezer is over the fresh food section and defrost coms about every eight hours. If by chance your condensate drain from freezer above becomes blocked behind that light shield the water from defrost will collect in a cup behind that shield and flow down into the fresh food section. Click Here=> Leaking Refrigerators and once done there click here=> Leaking Refrigerators, Just What May Be Happening If you have any questions about your Refrigerator I will be here or reachable here, Thanks and please rate if helpful, Sea Breeze
Oct 18, 2011 | Hotpoint HTS16HBR Top Freezer Refrigerator
How to change the light bulb
Hi
Not all bulbs will fit your refrigerator. Be sure to replace the bulb with one of the same size, shape and wattage. On some models, the dispenser light requires a heavy duty 10-watt bulb. All other lights require a 40-watt bulb.
1. Unplug or disconnect power from your refrigerator.
2. Remove light shield when applicable.
NOTE: To clean the ligt shield, wash it with warm water and liquid detergent. Be sure to dry the shield thoroughly before installing.
3. Remove the light bulb and replace it with the same size, shape and wattage.
4. Replace light shield when applicable.
Also check this link bellow:-
http://whirlpool.custhelp.com/app/answers/detail/a_id/1403
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 02, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Manual says to release the hooks at either end of the light shield. Don't see any hooks at either end. How do I get at the bulbs? Thanks
The hooks are on the inside of the shield. Use a flathead and pry lightly on the sheild edge nearest the back of the refrigerator on either side.
Jan 31, 2011 | LG LRDC22744SW Bottom Freezer Refrigerator
How to change the light in the refrig. compartment?
Some models are different...I hope this helps.
Replacing Light Bulbs
To avoid electrical shock which can cause severe personal injury or death, disconnect power to refrigerator before replacing light bulb. After replacing light bulb, reconnect power.
To avoid personal injury or property damage, observe the following:
• Allow light bulb to cool.
• Wear gloves when replacing light bulb.
Fresh Food Section
(style of light shield varies)
1. Slide clear light shield toward back of compartment to release from light assembly.
2. Remove light bulbs.
3. Replace with appliance bulbs no greater than 40 watts.
4. Replace light bulb cover by inserting tabs on light shield into liner holes on each side of light assembly. Slide shield toward front of refrigerator until it locks into place. Do not force shield beyond locking point. Doing so may damage light shield.
Freezer (style of light shield varies)
1. Reach behind the light cover.
2. With firm pressure, press forward on the notches at the back of the cover and pull down the cover will open from the back.
3. Remove the cover.
4. Remove light bulb
5. Replace bulb with appliance bulb no greater than 40 watts.
6. Insert front tabs of light cover into slots in freezer liner and snap rear portion over light assembly until rear tab engages.
Ric
Mar 09, 2010 | Heartland 3220RHSS Bottom Freezer...
Lightbulb replacement refrigerator
Most shields push in then down to engage them so push in and lift straight up. They are tight so will take a little pressure to remove. They have 2 or 3 tabs.
May 02, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Need to change the light bulbs
The light shield has two tabs, one on each side. They may be on the front or back of the shield, It fits either way. Pull the tabs down and slide the shield back and forth a couple of time and it should drop from the four pegs that hold it in place. You will have access to the bulbs. You can go to http://www.subzero.com/locator/locator.aspx?type=0&zip=02030 and find a parts distributor near you or take a bulb to the store and match it. Make sure you get the same wattage rating.
Nov 24, 2008 | Sub-Zero 690 Side by Side Refrigerator
Refrigerators Logo
48 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
