Question about Westbrass RFT-202-CP Rapid Fit Tip Toe Bath Plug Mechanism, Chrome
How do I remove a "rapid fit" drain stopper? - Westbrass RFT-202-CP Rapid Fit Tip Toe Bath Plug Mechanism, Chrome
These are a little tough to do sometimes as they seize up. I typically will tighten them by hand just a little to some times crack seal they have made in threads. Then feather then unscrew I unscrew while putting force on edge as if you were trying to tip it to one side. 99% of time this is enough.
If not unscrew top counter clockwise then use small pliers to grab unit as low was possible. When free clean threads and put a light cost of Vaseline on threads so it does not happen again.
Posted on May 02, 2015
Clogged drain on moen bathroom sink
There should be a stopper valve on the sink's downspout (the first section of drain pipe). You SHOULD be able to loosen the nut holding the stopper valve's lever inside the pipe. Once you remove that nut, you can pull the lever out - that releases the stopper inside the sink, so you should start with the stopper OPEN, and hold it open with a chopstick or pencil or other tool when you remove that lever.
The lever and the bottom of the stopper itself will be wrapped with masses of hair. That's normal. Clean it up and reinsert it, put the nut back on & snug it down, then readjust the stopper.
If that's not enough, you may need to open the trap (the gooseneck-shaped piece of drain pipe under the sink) to clean it out.
Apr 05, 2014 | Moen Tub Drain Assembly, Lift-N-Drain -...
Pop up plug cannot be connected in the drain
Turn it around the other direction. Not upside-down, just rotate it 180 degrees. The stopper lever will fit through the hole in its end one way or the other.
Apr 04, 2014 | Moen 103459 Drain Pop-UP Plug
Grohe drain stopper installation
Try cleaning drain with a length of wire. Strip insulation back about an inch. Turn exposed wire back to form a hook and put down drain and spin, then remove from drain, repeat until hook comes out fairly
clean. Then put drain cleaner down drain, follow instructions with drain cleaner. This should remove gunk that is preventing stopper from working correctly.
Jan 20, 2014 | Plumbing
How does the lift and turn stopper come out so we can clean plugged drain?
  • Push the stopper down to fully seal the stopper against the tub drain.
  • 2
    Turn the knob on top of the stopper counterclockwise with your fingers. Do not lift the stopper while turning the knob. Remove the knob from the stopper.
  • 3
    Insert a large flathead screwdriver into the slot on the center shaft of the stopper. You will see the center shaft when you remove the knob. Turn the shaft counterclockwise to unthread it from the retaining hole in the bathtub drain basket.
  • 4
    Use a pair of vise-grip pliers to turn the shaft if the center hole has corrosion and will not accept a screwdriver. Lock the jaws of the pliers securely around the shaft, and turn the shaft counterclockwise.
  • 5
    Pull the stopper out of the tub by lifting it by the shaft.
  • Mar 12, 2011 | Maax Soprano II: One-Piece Shower Module...
    I am trying to use a plunger in a slow drain. bathroom lav. The pop-up valve stopper is in the way of my plunger. the Pop-up valve is a Price- Pfister. My past experience with other older pop-up valves has...
    Some of the drain plugs have holes or slots in them so that the stopper can not be removed without taking the actulating lever out from under the sink. This rod is part of the linkage that is hooked to lift rod on top, Unscrew retaining nut to remove rod so you can take stopper out. Remember that any water that is in sink is going to run out of this hole once you remove rod. Good luck and thank you.
    Feb 21, 2011 | Price Pfister 47 Series, Lavatory Drain...
    I have akohler bath drain that seals/drains simply by pushing down on the gasketed spring-loaded chrome stopper. The drain is clogged with hair but I can not figure out how to remove it and snake the...
    Toe tap stoppers remove by just gripping the stopper and unscrewing it. Once the stopper has been removed the hair will be usually caught on the crossbar underneath the stopper where it can be removed with needlenose pliers.
    Spring type stoppers for drains are just about as notorious for being hair catchers. Once again there is nothing to stop the hair from leaving the tub.
    May 21, 2010 | Plumbing
    Direct push-type Kohler bath drain won't drain.
    Spring loaded chrome stopper will not stay down to fill tub with water.
    Jan 12, 2010 | Kohler Plumbing
    Stopper came out Pegasus bathroom sink
    Pegasus make several models but I'll make an assumption that it has a pop-up plug actuated by a rod just behind the tap head.
    If correct....
    Under the sink in the cabinet you will see the rod comes down and connects to an adjustment fitting and into the main drain line from the sink. There will be a fitting on the drain line holding the connection. Inside is a metal ball and connecting rod that links to your plug.
    Remove the fitting.
    Slide the ball and rod partially out.
    Put your plug back in.
    Engage the rod again (you will need to fiddle a bit here).
    Tighten the fitting.
    Run water to ensure the fitting is tight and not leaking.
    Should be good to go.
    Please rate this answer if it gives you some direction.
    Dec 22, 2009 | Pegasus Technologies Home
    My tub is stopped up
    you any thing that can fit the surface of the stopper and provide a good suction
    Jun 05, 2009 | Kohler 1014-H2-96 Portrait 5' Whirlpool...
    Bathroom tub drain clogged
    If you have a popup/ plunger type drain stopper controlled by a lever at the overflow, then, yes, it would be a great idea to remove that. They commonly add to drain problems.
    Remove the two screws at the overflow plate (the one with the lever for stopping the water). Be careful that the gasket between the tub and overfow does not fall out when you fully remove the screws. Pull out the stopper assembly. You may have to jiggle it somewhat. Clear your drain some more and run a little water in it. Then replace the stopper assembly, making sure to keep the overflow drain lined up as you screw the plate back in.
    You may consider replacing a lever stopper with a "twist and twirl" type.
    If you do not have a lever assembly then you may have to use a small hand held snake to clear out the drain
    Mar 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Westbrass RFT-202-CP Rapid Fit Tip Toe Bath Plug Mechanism, Chrome Logo
    923 people viewed this question
    Top Westbrass Home Experts
    Donni Steen
    Tom Chichester
    Are you a Westbrass Home Expert? Answer questions, earn points and help others
