Question about Vacuums
Rainbow Series E - we replced the plug with a non polarized plug. the breakers in the house popped off. no burned motor smell
The unit will not come on now please help. if the a fuse or resistor that can be replaced?
  • 16,037 Answers
So now you have to check the wires. The reason there is a polarized plug is to prevent the hot wire from being sent to ground. Obviously when you changed the plug, the hot wire was sent to ground. The current draw then burned a wire in half. There is no fuse.
Posted on Apr 11, 2015
Testimonial: "thank you, check the wires in the power cord or the motor?"
  • 2 more comments
  • Brad Brown Apr 11, 2015
    CORD
  • Anonymous Apr 12, 2015
    wires are fine, replaced the plug now with a polarized one, does the rating on the plug need to be rated to a specific level?
    asking this as the vacuumm still does not come on - no evidence of the motor or board being burnt out wires
  • Brad Brown Apr 13, 2015
    I am not sure where you are located. Most plugs in the USA are rated for 15 amps. You are going to have to get a meter and use it to check the wire on the cord
My rainbow vacuum e series won't turn on.
it could be the switch . or brushes
Feb 01, 2015 | Rainbow Vacuums
Why does my rainbow e series smells like it's burning?
Belt for Power Nozzle EXCEPT the PN 12
or...
Motor Rainbow 120v
is most likely going bad. You can also call out technical support team if needed... Contact Us
RainVac
Jul 20, 2014 | Rainbow E series Canister Wet/Dry Vacuum
The rainbow sat for too long on the water now wont run
So depending on how long, you may have rusted out the bearings in your motor, especially if it sat so long as to eat the glue off of your gasket.
Sounds like you may need a new motor, gasket, baffle plate and separator.
Rainbow series vacuum main unit parts
GoodVac.com
800-775-6586
Apr 14, 2014 | Rainbow E series Canister Wet/Dry Vacuum
I smelled something burning one day , but i kept using my d4c, now the motor part does not run but the top plug in will run
I work on Rainbows. D4C-E2 etc. Not sure what you mean by the top plug in. There are two motors in the rainbow, one in the main unit, one in the power head. Where was the odor coming from? email me back with more info, I can help you with this. Jerry
Nov 06, 2010 | Rainbow E series Canister Wet/Dry Vacuum
Rainbow E-series will not turn on
Hi, there is no reset button on a Rainbow vacuum. There is a safety switch on all E series and E2 series Rainbow vacuums, that keep it from running without the water basin on it.
If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also. Thank you, Ralph
One other thing. All E series vacuums have a built in circuit breaker on the motor. Some of the earlier ones, it was only a fuse, and if it blew, it had to be replaced, or removed and wired directly without it on there. Most of them have a automatic reseting curcuit breaker, that will blow and auto reset its self, after it cools off. They do sometimes stay blown also, and do not reset. If that is the case, it has to also be replaced, or removed, and wired directly, with out it on there.
Motor brushes are usually the source of a non working E-2 vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature.
Thank you again,
Ralph
Apr 05, 2010 | Rainbow E series Canister Wet/Dry Vacuum
I bought my rainbow se vacum 4 years ago and I was using it and suddendly stoped working, I try to on no power I on and off not working at all. what shall i do is there posibility to work again.pls.help...
All SE series vacuums have a built in thermal and load fuse on the motor, and if it blew, it has to be replaced, or wired directly, with out it on there.
Motor brushes are usually the source of a non working Rainbow D4 and SE and all model Rainbow vacuums and when they burn out, they usually take the motor armature with them, from excessive heat and flare electrical arking to the armature. It is probably the thermal and load fuse, that is your problem, if you did not smell any electric burning type of smell, before it quit. It could be the power switch, but not as likely as the fuse. If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
Thank you,
Ralph
Feb 13, 2010 | Rainbow 75th Anniversary Canister Vacuum
Rainbow Vacuum smells like something is burning.
Your belt is worn and that is why there is a burnt rubber smell. You need to change your belt. You can find a replacement belt and instructions here:
Rainbow Replacement Belts
Apr 02, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Vacuum plugged in but not on, smoke started coming from the motor
The motor winding burned out. Perhaps the motor was very hot when the vac was turned off after the last use and the insulation of the motor windings broke down when the air stopped moving thought the unit. Perhaps also the polarity of the receptacle it was plugged into is reversed or the plug on the vacuum is not polarized. Those things in combination could cause this but this is kind of a long shot guess. In any case the blower motor is likely burned out and will need to be replaced and checked out.
Jan 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Rainbow e series smells burnt when power nozzle in use
Replace the belt in the power nozzle, it has to be changed yearly.
Oct 01, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Burning Smell
Check the carbon motor brushes, there might be arcing on the armature. New brushes may help if the armature is ok.
Mar 29, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
152 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
