Question about Mtd Garden
I have a lawn tractor that won't start I think a safety switich is bad could you tell me where are they located
No power from the solenoid
    Sergeant:
  • Mtd Expert
  • 187 Answers
When I turn the key nothing happens.
There are several elements that go into cranking (turning over) the engine.
  1. Battery
  2. Fuse
  3. Key Switch (and wiring)
  4. Starter Solenoid and wires
  5. Starter motor
Let's start with the battery. The quickest way to make your initial check of the entire starting system and particularly the battery is to get a jump. Yep, get some jumper cables and jump the mower off your car. Turn the key and try to start it in the normal fashion. If it starts cool! It is likely a bad battery.
  • Charge the battery for a few hours, on a charger.
  • Then perform a voltage measurement of the battery.
  • Switch a volt meter to DC Volts and clip it to the battery. It should read between 12-13 volts. If not the battery is suspect.
Now let's check the starting system while bypassing all the safety switches and wiring. How? You can perform this test simply by jumping the starter solenoid. Hold a wrench or fat screwdriver across the two large posts of the starter solenoid. This bypasses the key switch and all safety devices and directly drives the starter. Your starter will crank if the battery and starter are good, the wires and connections are good, and the engine is not locked up. Don't crank it for more that a couple seconds. You just want to verify the battery and the starter are both in good shape. (The engine will crank but not start during this test if the key is off, or if the safety switches or wiring are damaged, or if the safety switches are in the no start/run positions.)
If the starter cranks try one more test. Run a small jumper wire from the positive post of the battery to the little terminal on the solenoid. You may have to take the small wire off the terminal, on the starter solenoid, in order to do this. When you apply this current from the battery to the terminal it should make the solenoid activate and the starter crank. This test bypasses the key switch and shows you the starter system is working. You could do this test first; if it works you do not need to do the basic jump test.
If these tests cause the engine to crank, but it will not crank with the key, then you know you have a problem somewhere in your starter wiring, safety switch system, fuse, or in your Key Switch. Of course you did check the battery terminals for good connection, right?
Most modern riding mowers have the following safety switches:
  • Seat switch
  • PTO switch
  • Reverse switch (RIS) and Reverse Relay (RIO)
  • Brake/Clutch switch
If you need detailed instruction for testing your wiring and safety system, I will need your complete machine info.
  • Make
  • Model
  • Year
  • Engine Model
  • Transmission Model
  • Deck Size.
On a John Deere (100 series) the starting current flows through the following items in this order:
  1. Battery to Fuse then to the Key Switch.
  2. With key switch in the start position, the current flows from the Key Switch to PTO.
  3. With PTO off, current flows from the PTO to Brake/Clutch
  4. With Brake/Clutch Pedal all the way down, the current flows to the starter solenoid.
  5. If the Starter Solenoid is in good shape, the solenoid connects the battery to the Starter and the engine cranks. Cranking does not mean running; it just means the engine turns over. Running is dependent on many other systems.
These listed components are all part of the cranking/starting system. They can prevent the Starter Motor from cranking when you turn the Key Switch.
Electrical elements that are NOT part of the starting system:
The RIO is the Reverse Implement Option. It is a switch that latches and stays latched under certain conditions. It is activated by the RIS. The RIS is the Reverse Implement Switch. It activates the RIO. These two separate components work to allow the blades to cut while you are backing up (without killing the engine). They have nothing to do with the starting system.
The Seat and the RIO (the reverse latch not the button) switches are tied into the engine kill system.They provide a ground path for grounding the Coil. This same system controls the fuel shut off valve beneath the carburetor. The Seat and RIO can keep the engine from running but they will not prevent the Starter Motor from cranking. Therefore, if you turn the key and nothing happens, the problem has nothing to do with the Seat and Reverse switches.
Note: With the Key in the RUN position, power flows from the Key Switch to the Hour Meter, then to the RIO latch relay (not the RIS button), then to the fuel shut off solenoid. If you do not hear the Fuel Shut off Solenoid clicking on and off when you turn the Key Switch from off to run, there may be a problem in this circuit; including a possible problem in the Hour Meter. Of course none of this affects the cranking circuit. Your engine will still crank, it just won't run.
Posted on Apr 11, 2015
  • Mtd Master
  • 17,173 Answers
There is usually one in the seat.
Cub cadet lawn tractor not starting?
There are several safety switches located on the tractor that could be giving you the problem. The starter solenoid may be bad as well.
Jul 10, 2016 | Cub Cadet Garden
My tractor dies when I put it in gear.
solenoid only engages the starter nothing else .it could just need the carb cleaned
Apr 16, 2016 | Garden
Solenoid clicks but starter does not kick in to start tractor
Clicking Sound While Attempting to Key Start - Riding Mower
troybilt.custhelp.com/.../clicking-sound-while-attempting-to-key-start---r...
Jul 19, 2002 - Why does the tractor make a clicking sound and not start? ... Thesolenoid connects the battery to the starter motor when the solenoid is energized. ...It can click, but not make a complete connection. ... Starting - Riding Mower · Professional Shop Manuals · Basic Troubleshooting - Lawn & Garden Tractors.
How Do I Tell If the Starter Solenoid Is Bad on My Kohler ...
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
Most large Kohler engines on riding lawn mowers use an electric starting system. ... A bad solenoid can deny electricity to the starter motor and prevent engine startup. ...Lawn Mower Will Fire but Not Start · Replacing a Solenoid on a Craftsman Lawn Mower or Tractor · How Does a Starter Solenoid on a Lawn Mower Work?
My Bolens lawn tractor won't start. It just clicks when I turn ...
Dec 03, 2015 | Garden
Lawn trc murray 17.5 hp 42in cut
my specialty,but,you didnt post what the problem is,so,here goes,if it wont start,it is probably a bad safety switch,take the small black wire off of the coil,if it starts,then its a safety switch,if it doesnt then it is the coil,if it only clicks with a charged battery,it is the solenoid,turn on your key and short between the two big bolts on it if it starts it is bad,if you need a belt,i will need the numbers under the seat,otherwise i will try to find them for you,i will post a user manual for you here, Murray 425607x52A 42 34 Lawn Tractor Parts
Murray 425016x48A 42 34 Lawn Tractor Parts
Murray 425306x48A 42 34 Lawn Tractor Parts
Murray 425600x48A 42 34 Lawn Tractor Parts
Murray 425618x48A 42 34 Lawn Tractor Parts
Murray 42560x52A 2000 42 34 Lawn Tractor Parts
Murray 42820x24A 1996 42 Inch Cut Lawn Tractor Parts
Murray 425619x24A 42 34 Lawn Tractor Parts
a few manuals,find yours here or go here to find it by the numbers under the seat,all part numbers are in them, Search eReplacementParts com
Apr 24, 2015 | Murray Garden
John Deer tractor (JD301-A) won't start (no power at all) but if I unplug the carburator solenoid it cranks but it won't start. I need to move it to a roofed are, it is in the field. Is ther
yes a bad solenoid will shut it down if you put power direct to the solenoid and it still doesn't operate its bad with a grinder grind the tip off while your waiting for the new one just make sure you bring down to idle for a few min before shutting it off it a anti back fire solenoid
Sep 23, 2012 | Garden
Dynamark riding lawn mower won't start, new battery but will not turn over?
use jumper cable to test the starter if ok jump the small wire at the solenoid to power and see if it kicks it over if yes check the safety switches
May 13, 2012 | Garden
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
If a solenoid clicks is it good or bad. with the battery hooked up i can jump the two terminals on the solenoid and it will start. or, can it be a safety swithch unhooked or stuck like the one where you...
If the solenoid just clicks, that usually indicates a low battery voltage. But if starts by jumping the solenoid, as you say, then that indicates the solenoid has burnt contacts inside itself. Some are rebuildable, mostly just replaceable. I would still, first, disconnect the battery, remove the cables from the solenoid and clean both the wires and the contact points of the solenoid before discarding the solenoid. I would rule out all safety switches at that point because it is trying to work. If it was a safety issue, the solenoid would not recieve power to ingage (or click).
Apr 19, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a white lawn tractor and i just change the battery and the spark plug and it wont start . I also have current to my switch to start but no current to the starter . Could you solve this.
do you have power from the switch to the starter solenoid ? What you should have is a battery lead going to the starter relay / solenoid. a battery lead coming from the relay / solenoid to the starter and a 12 or 14 gauge wire coming from the switch to the relay solenoid. Depending on the age of the machine this wire may actually go direct to the solenoid or it may have to go through a couple of safety switches. the first thing I would check is make sure you have power coming out of the starter switch to the start circuit. The terminal on the switch is usually marked with an s for starter / solenoid. If you have power coming out from here then trace this wire to either a safety switch or relay solenoid, keep checking for 12 vdc until you dont have power and you will either find the problem or the bad part... hope this helps you
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HOW DO I TELL IF ITIS SOLENOID OR STRATER BAD ON MY SEAR LAWN TRACTOR?
you can check the starter by removing it and using jump cables to the body- and starter terminal to +. still there are the saftey switches in the picture when on the tractor. if you have a bad switch then it also wont start.
Jul 21, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
316 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
