Question about Garden
How do you adjust the drive arm.
I have play in the drive arm and looking to know how to adjust the drive arm.
    Top Expert:
  • 10,875 Answers
Make and model???????????????????????????????????????/
Posted on Apr 11, 2015
Testimonial: "2008 bad boy pup"
Bit of play in accelerator. like to know how to adjust please
look at the carburetor and you will see the cable coming to it, they have adjusters on the arm that cable attaches too ( it could be a stretched cable causing the play )
May 05, 2015 | Cars & Trucks
Steering is really loose. There is about 2 inches of play in the wheel, and it is all over the road when driving
You need to check your front end very close. Start by making sure the ball joints and all 4 tie rod ends are tight, zero movement by hand. Also check the pittman arm, off the steering box and the idler arm, from the frame on passenger side. They should not have any play. Work all the tie rod ends on the drag link, which hooks them together. Sometimes the holes in it will wear. The tie rods shouldn't move in it. Have a look at the control arm bushings. If they are squished out and noticably cracked then they need to be replaced. Check both the uppers and lowers.
If that all checks out then the problem is wear in the steering box and that does have some adjustment but not really enough to take 2" of play without making other problems. You'll have to replace it. Hope this helps.
Nov 01, 2010 | 1988 Chevrolet Blazer
Looking for a belt tensioner for a 1997 Jeep Cherokee Country. Where would I look? Perhaps I am not calling it by its correct name as no one can even guess what I am looking for...Thanks!
Do you mean the tensioner pulley?
Then, I would look for something with a 1/2" square hole in a pivoting spring loaded pulley that is designed to put 'tension' on the serpentine belt.
Depending on the engine, it can be located in various positions.
REMOVAL & INSTALLATION - 8 cylinder engine Alternator Belt
  1. Loosen the alternator mounting and adjusting arm bolts.
  2. Pivot the alternator inward and remove the belt from the vehicle. To install:
  3. Install a new belt.
  4. Holding the alternator in place to maintain tension, tighten the alternator mounting and adjusting arm bolts.
Power Steering Belt
  1. Loosen the adjusting and mounting bolts on the front face of the steering pump cover plate (hub side).
  2. Pivot the power steering pump inward and remove the drive belt. To install:
  3. Install the drive belt.
  4. Holding the pump in place, tighten the adjusting arm bolt and the mounting bolts.
Air Conditioning Compressor Belt
  1. If the engine is equipped with an idler pulley, loosen the idler pulley adjusting bolt and remove the belt.
  2. If not equipped with an idler pulley, loosen the adjusting and mounting bolts.
  3. Pivot the air conditioning compressor inward and remove the drive belt.
  4. Installation is the reverse of removal.
Air Pump Drive Belt
  1. Loosen the adjusting arm bolt slightly. If necessary, also loosen the mounting bolt slightly and remove the drive belt. To install:
  2. Holding the pump in place, install the drive belt, then tighten the adjusting arm bolt and the mounting bolt.
Oct 17, 2010 | 1997 Jeep Grand Cherokee
Sears radial arm saw; adjustments to tighten arm to column
Uncer normal use a nylon bushing on the column wears out and/or cracks and prevents proper adjustment. You can get any nylon or teflon bushing with the same ID as the column OD and that should do the trick.
Mar 30, 2010 | Craftsman Saws
Yardman snowblower will not shift properly
you must been the arm back. look under your unit and check the drive rubber wheel. your are going to probably need to adjust the shift arm assay. make sure you lube all slide shafts. let me know
Oct 18, 2009 | Garden
Tone arm gets caught up and skips repeatedly
Is there a counterweight on your arm or is the an adjustible spring setting? You need to move the counterweight toward the needle. You dont need much but the needle end needs to be heavier than the back side. If your anti skating is a magnet ... reduce the force on that as well.
Let me know what happens.
a
Sep 25, 2009 | Audio Players & Recorders
Hydraulic P20 tranny with hasport hydraulic > cable conversion. The arm that attaches to the TOB arm came out and the clutch stopped working. When i popped the hood and looked i found the bolt that...
The throw out bearing arm was on the outside of the clutch actuator arm. The throw out bearing arm should go into the clutch actuator arm with a bolt going into the clutch actuator arm through the throw out bearing arm. I used some blue locktite to make sure the bolt didn't come out again. See pic below.
May 04, 2009 | 1991 Honda CRX
Playing to the end of the record
I LOVED the 40bs, and if you look at the size selector, which is located at an angle to the right side at the front along with the manual or auto setting in the front. There are 4 settings, 78-10, 45-7, 33-12, and 33-7 for the speeds and sizes of the recordings.
Apr 14, 2009 | Teac AG-V1050 Receiver
Drive belt slips on lawn tractor, cannot see an adjustment.
hi,
i would check with the owners manual to see if it shows an adjustment for the belt drive. most mowers today are equipped with a self adjusting arm witha pulley tensioner with a spring attatched to it. as the belt stretches the tensioner spring pulls against the arm causing it to apply tension to the belt thus tightening it. it sounds as if your belt is stretched beyond the limits of the tensioner. at least every new season it would be a good idea to inspect the belt tensioner for room or space of free play. that is to check to see if it will move opposite the pulley allowing the belt to tighten. if there is not enough sufficient room then i suggest replacement of the drive belt.
Mar 29, 2009 | Garden
Drive chain adjustment
To adjust the chain you need to make sure you make the adjustment with the swing arm parallel to the ground, (this is the tightest point in the arc of the swing arm moving rotation), at that point you want to be able to put two finger between the chain and the swing arm at the swing arm pivot bolt. This will insure proper adjustment every time. The best thing to do is have somebody sti on the bike off the stand to make sure the swing arm is at its MAXIMUM arc, otherwise you stand a significant chance of over tightening it and this can and WILL cause SERIOUS damage to your engine. You will rip the output shaft bearings out of the center cases.
You also want too make sure you have proper wheel alignment as well. There are marks on the rear of the swing arm for adjusting the chain, make sure you have the marks on the adjusters in the same location on BOTH sides of the swing arm.
Please let me know if you need further assistance.
Regards,
RSelvy
Dec 17, 2008 | 2005 Suzuki RM-Z 250
Garden Logo
144 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
