How do I fix a broken clutch ( a tiny plastic piece) in my printer. This is due to pulling out a jammed paper too hard.
I have taken apart the printer as far as I could go. But not able to get to the "clutch". It looks like this tiny piece can only be replaced as part of a larger piece. (It cannot be glued on that is certain). It is that larger piece that I could not remove. It would be useful to know the name of this piece and how to remove it so that I may possibly order the part. Is there a site where I could get a diagram of the inside of the printer?
    Top Expert:
  • 10,875 Answers
If we knew the make and model,we could help you,but,we dont so we cant
Posted on Apr 11, 2015
Epson dfx9000 it gives me paper jam
My epson printer showed a paper jam light although no paper was visible.
I discovered my son had had a paper jammed and ripped the paper out and a tiny piece was jammed inside but was not visible easily.
***NO RESPONSIBILITY ACCEPTED FOR LOSS OR DAMAGE IF YOU USE THIS SOLUTION I USED TO FIX MY PRINTER*********
i cut an A4 sized square of cardboard from a cereal packet.
I inserted this instead of paper and attempted to use the feed paper button to eject the paper jam.
This did not initially work so as i kept pressing the paper feed button i forced the cardboard into the printer in the same direction that the paper feeds whilst printing.
The cardboard pushed the tiny piece of paper out.
Turn off the printer and then turn back on - you should find the printer now works.
I also found it helpful to clean the feed path and to try and keep dust from settling in the printer.
If it is in a dusty environment it helps to keep the printer covered when not in use - you can buy plastic covers for this or any large plastic will do but does not look as aesthetically pleasing.
Hope this has helped.
Oct 24, 2012 | Epson Office Equipment & Supplies
The paper in the printer is lined up and everything should be working however I need to print things for work and it tells me that it is either jammed or that I need to load/ reload the paper. I can't...
I have found over the years that printers really don't lie. If it says there is a paper jam there usually is. I have completely taken apart a large laserjet printer to find a very tiny piece of paper causing the problem. Also if you run sticky labels through printers they have a tendency to leave residue or even part of a label behind which will cause the printer to tell you there is a jam. Check your printer very carefully, use some canned air to blow it out. You may need a printer repair person to come out and take it apart to look for possible stuck paper.
Jul 03, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Printer jammed. I cleared the jam but it
You most likely have a tiny piece of paper stuck in the paper path that cannot be seen unless taken apart. Depending on the type of printer... remove the paper tray and the back cover and look for any small shred of paper. If you still see nothing, a local repair shop would be your best option.
Jan 02, 2010 | Office Equipment & Supplies
Cannon MP600-where do you see Error Code? I just get "Paper output slot" paper is jammed; but it's not!
That error usually comes from the sensor under the platen roller. It's a tiny black plastic piece that the paper pushes when it passes under the platen roller. The end can bend when you pull out a jam, or a tiny paper scrap can hold it down. The same screen gives error codes when there are other malfunctions, the error now is just that sensor.
Dec 29, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Lexmark x 3350 all-in-one
I picked up a used Lexmark 3500 with the same problem. Had requested help fixing.
Tried to feed more paper through - still pulling hard on the right side. Tried to feed several pieces of paper - one at a time, getting them jammed then pulling them back out. Finally one got jammed way down in there - yanked it back out. Open the top(as to load ink cartridges) Saw a tiny piece of paper sticking out between the plastic rollers, got a small crochet hook (tweezers would have worked), grabbed a hold of it and pulled it out enough to get a good hold of it, then pulled it out. There had been a shread of paper jammed in the roller area. 3" long by from 1/4" to 1 1/2" wide.
My problem was the chunk of paper stuck in the roller mechanism where you could not see it or get to it, until it was partially forced out.
Hope this helps someone else!
Oct 16, 2008 | Lexmark X1270 All-In-One InkJet Printer
Plastic piece came out, where does it go?
very good you explanation is correct the tab is part of the paper feed section you will have to figure out how to slide the plastc under the spring some how. normally the machine is taken apart. the reason for the part coming out was from the paer jam. if you need more help let me know i will try and help brother tech
Oct 07, 2008 | Brother MFC-465CN InkJet Printer
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Xerox PE 220
first with any jam message, identify if you have actually had any paper jam in it in the first place, especially if you are turning up to site and you're getting 2nd hand info. IE "oh no it just said that ...one day"
so assuming it actually had jammed paper in it that was removed at some point, find out where it was jammed...front or back. how it was removed...via front or back. note! many printers dont like having paper pulled out in the reverse direction to which the paper normally travels, this sometimes catches little flags and breaks them or pulls them out of position and the little photo sensor that is normally closed is then left 'electrically/optically' open so the printer sees this as a jam as soon as its finished booting up.
okay assuming you have gathered reliable info re the above.
check that area of the path for what looks like a small swinging flag, or maybe a little black 'U' shaped sensor that looks like it should have a flag in it.
remember the print will/can only say there is a jam if a sensor is stuck..open/closed or how it 'shouldnt be normally.
if you're out of luck you may find the pieces of a flag loose in the unit.
ideally they have a bit of flexability and just pop out.
BIG rule...dont force 'remove' jams. if it wont come out, contact someone with a bit of mechanical ability, even if they arent a printer tech, (like myself) then at least they have an 'intact' unit to work with so they can see how its supposed to work and just pull it apart to clear the prob area.
ok...so assuming you've found the area, if the flag is broken i wouldnt try making bits up to do the job, timing is critical, unless you can glue it back together exactly right then dont bother, you'll likely get timing related jam messages. just contact the manufacturer, see i you can get a part number. it may cost you a few bucks for a bit of plastic but its the best way trust me.
HP, lexmark, and fuji xerox i have found pretty good with parts down to a small level. some other brands i wouldnt touch with a barge pole.
after all this. most jams are in the fuser and most people are rough as guts and usually break something in the fuser by yanking it cos they're angry.
most fuser can be sort of pulled apart into sub components (although its not expected in my industry) so if you have an intact fuser but its got a heavily 'fanfold' paper in it so tight you dont even know its there, dont dig it out with a screwdriver, if you score or scratch the surface of the rollers then you done your money there. better to look at it for a bit, try to work out how to loosen it apart and remove the jam, inspect the rollers for scratchs or damage, andreassemble it.
(15 years repairing this gear, the methods are pretty much similar thinking for most printers when physical issues are the prob.) best of luck. - keith
May 14, 2008 | Xerox WorkCentre 220 All-In-One Laser...
Printer jams
Have you checked the paper path for anything which might be lodged there? A small crumpled piece of paper, paper clip, or even some broken piece of plastic from inside the printer itself. Are the rubber rollers extremely dirty/covered with paper dust? Depending on the design of the printer, one set of rollers may be spring loaded, and if the spring is broken, disconnected etc, the tension on the roller of course goes away. Anything like this will prevent proper paper movement through the printer
May 29, 2007 | HP OfficeJet G85 All-In-One InkJet Printer
41 people viewed this question
k24674
