Question about AOC Computers & Internet
Turned on computer today and my screen is blue green, does not change using monitor buttons?
I have tried to adjust settings manually, also through the display menu but the tint does not change? The pop up menu on the monitor has the correct color scheme but I cannot figure out what changed since having it on last night. The tint or hue overall is green
  • AOC Master
  • 4,134 Answers
Sounds like you are using an analog standard VGA cable interface. Since the menu has the correct coloring, it is not the monitors fault. Check the connections of the video cable at each end to ensure they are tight and not kinked. If they are ok, try using a different video cable. If thew problem still exists after that, it is probably the video card in the computer.
Posted on Apr 11, 2015
Green LED always on, power switch has no effect
if using a box or receiver in line with the set unplug those as well. I assume the red light on the set is not coming on or a light is blinking?
Dec 18, 2012 | Sony Grand WEGA KDF-50WE655 50" Rear...
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
I have an Flatron LG W2343T monitor and I am running Windows 7. After over a year of trouble free usage, the screen colors have shifted to a blue-ish green. How can I reset the colors to the factory...
Welcome to Fixya. If the color changes from a blue-ish green you can set it up using the Color Preset and change it to your desired settings. I've Provided the link for the manual of your LG W2343T Monitor so that you will have a guide on how to do it. Just click on Manuals and Documents then download the Owner's Manual. Color Preset is on page A14. If changing the settings won't fix the problem try to use another cable and see if it will works.
LG W2343T Manual
If you have questions please let me know. Thanks for using Fixya.
Mar 18, 2011 | LG Computers & Internet
I have an Acer AL1916 monitor and I turned it on like normal yesterday and it has now got a weird green tint all over.. I've gone into the settings of the monitor and played with the red, blue and green...
sounds like a cable problem, can you find another VGA cable to try, look at the cable ends carefully for bent pins.(they are easy to bend by accident) wiggle the blue VGA connector while its on, try both ends, I think when you push the button your pushing on the cable momentarily which causes the monitor to function properly, likely the connector on the back of the monitor. if this helps, please use the thumbs up for feedback. cheers
Aug 26, 2010 | Acer AL1916B 19" LCD Monitor
Monitor turned green
There should be adjustment buttons either on the front of the monitor on the computer itself. Then your can try taking the green out.
Dec 05, 2009 | HP W2007 Desktop Monitor
Green tint display
The monitor is faulty, not enough red. you can make changes in your display advance settings to try and reduce the yellow and blue to make the screen look a bit better. you might want to try a differant vga cable or check the pins in the plug that nun are bent
Aug 18, 2009 | Star Logic 17" LCD Monitor
How to adjust intensity of Acer X193W LCD monitor manually
if you go into the screens menu, there will be a button for contrast and brightness.  When you have the one you want selected, press munu again and that will bring up the dialog to change the percentages.
Mar 06, 2009 | Acer X193W LCD Monitor
Complete red screen but can still see desktop images clearly
A few possible reasons.
1. Loose or failed video cable. Check that the video (D-Sub or DVI) from monitor to computer is plugged in tight. If you have or can borrow a spare one you can try it to see if its the cables problem
2. Refer to the monitor instructions to adjust the Red Green and Blue settings. Maybe Red is too high or green and blue is too low.
3. If they both don't do anything then the problem could be the graphics card or monitor. Try plugging your monitor in another computer and also try someone eases monitor on your computer.
Sep 29, 2008 | Dell E152FP 15" Flat Panel LCD Monitor
Screen colour error
Recommend to go to the color settings and change it to the use settings and adjust accordingly.
Oct 17, 2007 | ViewSonic VA1930WM LCD Monitor
Computers & Internet Logo
161 people viewed this question
Top AOC Computers & Internet Experts
Jerry Umali
Raj Patel
Are you an AOC Computer and Internet Expert? Answer questions, earn points and help others
