Question about 1996 Ram 1500
I have a 1996 dodge ram 1500 5.9 When it idels its has a slight shimmer or sputter when I take off from a stop it hesitates a bit then goes but when cruising and step on it takes off.
  • Dodge Master
  • 2,039 Answers
Egr valve is sticking on so bad idle when you slowly take off valva open to fast putting to mush air in the engine equal hesitation leave the car idling take something like a hammae gently tap on that egr and your idle should get better after disconnect the electrical part of the egr and road test it should be good and after its your decision to change it or leave it like that if you leave it disconnect check engine light will be on but you no its because you disconnected that valve
Posted on Apr 11, 2015
  • Anthony Apr 11, 2015
    Where is the egr valve?
  • pierre laplante Apr 11, 2015
    go on you tube type egr valve for your model basicly dodge got all the same look
emissionwiz
  • 76673 Answers
SOURCE: 1997 Dodge Ram 1500 transmission will a 1996 interchange
No, the frame is different.
Posted on Nov 30, 2008
Molson02536
  • 3854 Answers
SOURCE: trouble code P0442 on 2001 dodge ram 1500
P0442 means you have a small leak in your EVAP System. your can try replacing the Gas cap since it's the easiest thing to do and reset the check engine light with a scanner. If the check engine light came back on then your going to have to go though all the Vacuum line in the EVAP system and connections. The other thing too is the service engine light should turn off when the problem is addressed and it may take up to three start ups to clear. Good luck and keep me posted, be glad to help, Recap, change the gas cap and inspect all the hose and connection's to the EVAP system.
Posted on Jun 08, 2009
  • 64 Answers
SOURCE: 1998 dodge ram 1500 Cruise control , speed
Look under the hood to check and make sure there is two steel wire cables connected to the throttle body. i had the same problem on my 02 dodge ram, turns out that just one of the cables came loose
Posted on Sep 15, 2009
  • 8 Answers
SOURCE: 2003 dodge ram 1500 abs & brake light came on.
Problem: I have a 2004 Dodge Ram 1500 5.7 L HEMI. My ABS and Parking Brake lights were illuminated, and my speedometer needle would "bounce". Also when sitting at a stop sign or just sitting idle, the engine would stall, and often times stop running.
Solution: After long research on this problem, I decided to dig in and try to find the problem myself. I replaced the Rear ABS Sensor
($35) that's located on top of the rear differential. Still no fix. I then unplugged the ABS Controller (or Module) that's located directly behind the battery (You should see the metal brake lines running into the top of it.) When I unplugged it, I noticed LOTS of moisture in the plug. Using an air hose, I blew out the water and let it dry good. When I plugged it back in, and hooked the negative battery terminal back up THE PROBLEM WAS SOLVED!! Simple fix. Hope this helps.
Posted on Mar 01, 2010
SOURCE: cruise control on my 2005
I have a 2005 dodge 1500 with the 4.7 litre engine. The cruise control is intermittent. Sometimes you turn it on and the cruise light stays on for a bit and sometimes it shuts off within a second or so. Any ideas; without the cruise light on I have no cruise.
Posted on May 27, 2011
Why does my 2005 dodge ram 1500 3.7 liter only goes up to 4000 rpm when i reve it up and it starts to sputter when in park
its the rev limiter. its suppose to do that when the engine has no load or the vehicle is stationary so you don't break the engine
Oct 09, 2016 | 2005 Dodge Ram 1500
Sputtered & died
this happened to me on my 1999 dodge ram and it ended up being the fuel pump
Apr 08, 2010 | 1996 Dodge Ram
What is the proper preload on front wheel bearings for a 1998 dodge ram 1500 4fd?
Simply snug it & back the nut off a slight bit,not alot,just a smidge. You'll be fine.
Jun 25, 2009 | 1998 Dodge Ram 1500 4WD
03 dodge ram 1500 hesitates and tries to stall when in drive at stop sign or light.The tachometer fluctuates up then down hesitates then stalls.
Remove IAC (idle speed control) motor, clean with throttlebody spray cleaner & the port (hole)it came out of. Re-install & try it. If it cures it for a while & does it again, replace the IAC motor.
Jun 04, 2009 | 2004 Dodge Ram 1500
1994 dodge ram 1500 pick up 5.2l
The catalytic coverter might be plugged.
Mar 09, 2009 | 1994 Dodge Ram
Po 108
if there is not a vacuum leak it seems that the signal wire to the MAP is either open or shorted to 5 volt reference wire. if not either of those may be the PCM
Jan 09, 2009 | 2001 Dodge Ram 1500 Truck 2WD
1996 Ram 1500 Logo
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Ruben Diaz
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
