The system shuts off after about ten seconds. I press the reset button and it comes back on then shuts it self off again. And I'm only using 78 watts on the 200 watt system
atlasuk2007
  • 85 Answers
SOURCE: New pc won't boot
Continuous Beeping: Memory or video problem This is usually caused by a problem with the system memory, or possibly the video card. The memory is more likely--the system complains long and loud if it can't find any usable memory, as there is no way to even start the boot process when this is the case. The motherboard itself could also be the problem. hope this helps
Posted on Aug 19, 2007
Inky
  • 691 Answers
SOURCE: epson r320 System error. Press and hold both Power and Stop buttons for 7 seconds
This could be the Ink Overflow Protection Error. If it is you may need to get a Rescue Kit for your machine form http://www.TheServiceManualShop.com Does the status monitor or LCD indicate that parts inside are past there service life?
Posted on Sep 16, 2007
  • 11 Answers
SOURCE: Heater Shuts off at 1500 Watts
Could be a bad element if the heater does not run at all at 1500w.
If it runs a little before stopping, things could just be dirty causing the thermal sensor to shut it off. A good cleaning is needed in that case.
Good Luck,
Denis
Posted on Oct 11, 2007
  • 631 Answers
SOURCE: boss chaos 150 200 watt that shows light but doesn't produce sound
If this is the CH150, it's not bridgeable. Try connecting it normally (one speaker per channel) to see if it will produce output.
Posted on Dec 05, 2007
  • 631 Answers
SOURCE: VR 200 Watt amp
Disconnect the wire from the remote turn-on terminal of the amp and insulate it so that is can not make contact with anything.
With the wire disconnected, does the amp remain on?
Posted on Jan 03, 2008
Reset printer
according to canon, try to reset the device using the steps:
Reset the device when it is not functioning properly. If the device is not functioning properly or to clear memory, reset it.
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Apr 06, 2011 | Canon PIXMA MP190 All-In-One InkJet...
The router was working fine yesterday. I checked it today, and it isnt working anymore. I unpluged it, and plugged it back in, and no indication lights are illuminating. I have tried this several times and...
Step 1 Locate the reset pinhole on the back of the unit.
Step 2 With the unit powered on, press and hold the Reset button.
Step 3 Hold the Reset button for about 10 seconds.
Step 4 Release the Reset button.
Step 5 The unit will reboot. Allow 20-30 seconds before reconnecting.
Step 6 The device is now at factory defaults.
Note: Do not recycle power during the reset procedure.
When it says hold for about 10 seconds, don't hold for more than ten seconds or the procedure will likely fail, if ten seconds doesn't work try 5 seconds
Dec 16, 2010 | Belkin F5D8236-4 Router
My iphone 3G just shut off on its own & it will not come back on when I try to trun it back on. Does anyone know more or less what I can do to fix that?
Is it completely charged? Plug it in and charge it overnight.
If it is charged, these steps may help:
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Dec 16, 2010 | Apple iPhone 3G
I have a Kodak easyshare C875. Can I take a delayed picture? If so, how?
In any still mode except for Panorama, press the self-timer button (on the top of the camera, marked with a one-handed clock) once for a ten-second delay, again for a two-second delay, and yet again for two pictures (after ten-seconds and eighteen-seconds). To start the self-timer, press the shutter release button.
Dec 15, 2010 | Kodak Cameras
I cant start my iPhone,and I did not sfiched off last night,for some reson did by it self.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Dec 10, 2010 | Apple iPhone Smartphone
I have not droped or no water damage.just flashes all the time when on charge but does not charge watt can i do please.
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Nov 25, 2010 | Apple iPhone Smartphone
How do I set the timer?
Press the self-timer button. It's the bottom part of the cross-shaped button on the back, marked with a clock icon. Each press of the button cycles between ON and OFF.
After pressing the shutter release button completely, the self-timer lamp lights for approximately ten seconds, blinks for approximately two seconds, then the picture is taken.
To cancel the self-timer, press the button again.
The self-timer is automatically canceled after one shot.
Mar 29, 2010 | Olympus Stylus 850SW Digital Camera
Trying to figure out how to use the timer on my Nikon Coolpix S570
Press the self-timer button (left of OK).
Press up or down to choose either two second or ten second delay.
Frame the picture and press the shutter release halfway to set focus and exposure.
Press the shutter button the rest of the way. The self-timer starts, the remaining number of seconds shows on the display, and the self-timer lamp blinks.
After the picture is taken, the self-timer reverts to OFF.
To cancel the self-timer, press the shutter release button again.
Fuller details can be found in the manual under "Taking Pictures with the Self-timer."
Jan 15, 2010 | Nikon Cameras
Describe how to use the self timer on the samsung S830 digital camera
Make sure you're in a recording mode other than VOICE.
Press the Self-Timer button (right button) until the display shows the desired mode. Your choices are 10-second mode (the camera takes a picture ten seconds after you press the shutter button), 2-second mode (the camera takes a picture two seconds after you press the shutter button), and Double-self-timer (the camera takes a picture ten seconds after you press the shutter button, then takes another two seconds later).
You can cancel the self-timer mode by pressing the Self-Timer button again.
The 10-second mode allows you to run back for a group picture. The 2-second mode is useful when you want to take a picture without fear of camera shake; simply place the camera on a steady support such as a tripod. The Double mode increases the chances of getting a picture with everybody's eyes open.
Jan 11, 2010 | Samsung S830 Digital Camera
Reset canon pixma mp 190
Apr 13, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Computers & Internet Logo
223 people viewed this question
David Payne
David Payne
