Craig tower stereo CHT954 wont power on. Need help. Only had two months. Tried holding power button ten seconds, removing all wires and replugging in, and still nothing
    Top Expert:
  • Computers & ... Master
  • 8,375 Answers
If its new take it back to the shop.
Posted on Apr 13, 2015
  • 56 Answers
SOURCE: e-machine 210 shut down and wouldnt come back on
try a different power supply first if this does not work
post here meage will go through other possibilities
Posted on May 22, 2008
  • 13 Answers
SOURCE: I have an advent laptop
http://www.w00tw00t.co.uk/
Posted on Oct 08, 2008
  • 60 Answers
SOURCE: Flashing Green Power Light on Tower
Try holding down the power for a full minute or two then start it up again. The power button may be set for sleep and not shut down. You may have to hold the button longer. If that doesn't work it could be RAM, or a serious problem with the motherboard.
Posted on May 06, 2009
pc brainiac
  • 18 Answers
SOURCE: The power button no longer works. IS the
i think your power supply has blown, take it to a computer store and ask them to replace the power supply then your problems should be over but you could just ask them to transfer computer box and that should also fix your problem because most boxes have a power supply in them. a small test you can do before that is get a switch open the pc and connect it to the mother board (without soldering it) if it turns on it is the switch then you buy a box if it doesn't make sure you dont use a toggle switch if you use a small hold switch and it wont turn on get a new box.
Posted on Oct 06, 2009
  • 979 Answers
SOURCE: no power on tower. The green light is on the back,
Hello Liz, hi, the flashing green light means its on stand by mode. when this happens, the power supply cant power on, due to... well like loose wiring, loose connections, or something on the computer. so I suggest you have it checked by a tech person, this requires that the whole PC be disassembled and reassembled.
Posted on Jun 09, 2010
Aspire tc-780 wont boot up or turn off, can i just unplug wait a few seconds then replug then try agaim
try holding power button in for 30 seconds to force a shutdown.
If it is a laptop you need to remove the battery as well as unplug the power from it if you want to try removing the power to it.
Jun 13, 2018 | Aspire Computers & Internet
The lights on the mute button, blue tooth button and aux button are all solid white
Try disconnecting from all power for a few minutes. If it has a battery, remove it
May 31, 2014 | Bose® CORPORATION Bose - SoundLink Mini...
ICraig Tower Stereo system will not turn on from standby
sometimes the system can get a little "rusty" after inactivity. The most common simple solution is to unplug it then plug it back in
Jan 01, 2014 | Craig Tower Speaker System For iPod,...
Can not get my Craig CHT907 tower to power on
Is the power cord loose/connected?
Try holding down the power button for 10 seconds then try turning it on.
If it does not work your power supply (PSU) might be broken.
Get a friend to help you or better go to the shop where you bought it if you still have warranty.
Oct 28, 2013 | Computers & Internet
Tower turns on, but not the monitor or the keyboard
There seems to be a problem with the motherboard. You need to get your hardware checked.
Alternatively, there is a solution that worked every time for me.
Disconnect The A/C Cord or Charger from the laptop,
Remove the battery,
Hold the Power Button for 45 seconds.
Put everything back together and then try!
Tips : Use a cooling pad or a hard surface to keep your laptop on. Sometimes this problem occurs due to improper ventilation & overheat problems.
Good luck !
Feb 14, 2013 | Acer Computers & Internet
My sons ipod touch hasnt been used for a couple of months & now it wont turn on or show any signs of charging. i have tried holding the on/off & home buttons without success, please help!
Restarting your device
Press and hold the Sleep/Wake button for a few seconds until the red "slide to power off" slider appears, and then slide the slider.
  1. Press and hold the Sleep/Wake button until the Apple logo appears.
    Follow these steps to reset your device
    Note: Reset your device only if it is no longer responding and the steps above do not work.
  1. Press and hold the Sleep/Wake button and the Home button together for at least ten seconds, until the Apple logo appears.
Oct 07, 2011 | Apple iPod Touch 8GB 32GB 64GB 3rd...
My ipod touch is disabled and i know the password but the ipod won't let me unlock it.what can i do? model;A1288. some months ago and on the screen of my ipod is the word "ipod disabled connect to...
Here is how you can do it. Make sure your ipod is connected to your itunes.
1. Turn power of.
2. hold the home button and the sleep/wake button for ten seconds.
3. let go of the wake button. ( keep holding on the the home button for another ten seconds)
4.?»¿ itunes will tell you that there is an ipod on recovery mode. and on the side a button should say restore.
Feb 07, 2011 | Apple iPod touch
Stereo wont hold memory
Look for a second power wire that needs to be hooked up. There is one wire that is switched (runs from the ignition) and another that is direct from the battery. You can test for this with a light or a meter. Typically the always hot wire will include an in-line fuse to prevent fires in the event of a short... Hope this helps...;-)
Apr 28, 2009 | 2005 Subaru Baja
Dvd not read or played
Try to boot from the DVD rive by using any a windows installation disk. If you can't, then boot to windows and download and update your firmware. If still the same thing, load bios defaults, shut down system, unplug system from power outlet, push and hold down the tower's power button for ten seconds, replug system, turn on system, try to use the dvd drive. If still no go, replace dvd drive.
Feb 18, 2008 | Acer Aspire™ T180 PC Desktop
Not recognizing the keyboard
try this, disconnect the computer from the power source(unplug). Hold down the power button on the tower while still disconnected. Ten replug the computer and turn on.
Feb 15, 2008 | Dell Dimension 3000 PC Desktop
Computers & Internet Logo
144 people viewed this question
David Payne
David Payne
