Question about RCA Televison & Video
Zenith universal remote control code for a rca dugital converter box
    Top Expert:
  • RCA Master
  • 74,383 Answers
0281,0228,0288. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 11, 2015
VOTIT
  • 2071 Answers
SOURCE: philips universal remote codes for zenith t.v.
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or yourbrand is not listed, and you are still not able to get the unit to respond, trythe following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when youreach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing thefollowing steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keysor press and hold SETUP until the Cinema's red light flashes twice to lock inyour new feature. (If the red light does not blink twice, stop and repeat stepsthrough 6).
To test the new feature, press and release the device key in which the newfeature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,please feel free to post them here.
Television Video - DVD Audio Satellite Set Top Box Video - VCR Brand: Model (optional): clip_image001.gifclip_image001.gifWe could not find an exact match, we think this code will work. 10054 clip_image001.gifclip_image001.gifSetup Instructions
· Set the "Mode Switch" to TV.
· Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
· Enter the 5 digit Code above.
· Try your new code and tell us how it worked!
You'll have to settle for that, use the middle power key in the tv device to power on & off the tv.
hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE;
Posted on Sep 01, 2008
SOURCE: converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
if It is similar to most RCA universal remotes, to get the code follow these steps(Manual code search MAy take awhile):
1:Manualy turn on the component that u want to control
2: press and hold the component key (ie SAT while holding SAT press ON-OFF key(button) for three seconds until all of the components light up and release the keys(button).
3: keep pressing ON-OFF key until your component turns off.(Note may take awhile)
4: one the correct code is found hit the STOP key and it will save your component IF YOU DO NOT HIT THE STOP KEY THE CORRECT CODE WILL NOT BE STORED.
Hope this works
Posted on Oct 26, 2008
SOURCE: Problem programming Zenith Digital TV Converter DTT901 remote.
Be sure that your TV is set to channel 3 or 4 if you are using the RF cable or Video 1, etc if using the Audio/Video cable.  The Installation  Guide should appear.  The "improved" picture that you are seeing is simply the analog throughput, not the digital conversion.
Posted on Jan 17, 2009
  • 1126 Answers
SOURCE: zenith universal remote codes
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=zenith&dv=universalremote&md=zn501s&kw=&st=&ar=&dt=&so=&pg=2&file=others/zenith/zn501s-manual.zip
Unfortunately, there is no code sheet included in this user guide. However, Code Search is covered on page 10.
Posted on Sep 11, 2009
Testimonial: "thanks, took 2 minutes and i was back in action"
SOURCE: NEED CODE FOR AN APEX CONVERTER BOX FOR THE RCA
how can i program a rca remote without a code search button to a apex digital converter cable box
Posted on Nov 18, 2010
I have a RCA 3 device remote model rcrno3br I need to program a zenith digital converter box to it model number dtt900 it won't work the 51415 codes a bust the search is a bust I need help
You have this backwards; the remote codes control the Zenith box. If your RCA remote is universal and you can't find anything that works using code search, you may have to try a different universal remote.
Nov 14, 2016 | RCA Televison & Video
What is the code of zenith converter box to program with my universal control remote?
If the remote is universal, you should be able to perform a code search to find something that work with your Zenith converter. If you search through all codes stored in the remote without success, you may have to try another universal remote. Some of the newer RCA universal remotes specifically control converters and other devices.
Feb 25, 2015 | Zenith Televison & Video
I need the zenith tv tuner converter code for a RCA universal system link 4 + remote.
ZENITH HDSAT420 ..................... 0634
ZENITH HDSAT520 ..................... 0634
ZENITH DTV1080 ........................ 0634
Aug 26, 2012 | RCA 4-in-1 Universal Remote Control
There's no code for a Zenith DTT 901 to an RCA universal remote?
Hi.
Try this RCA code for Zenith -> 001
Regards...
/Tech5508
Feb 16, 2009 | Zenith DBZN-311 Remote Control
Lost codes for RCA DTA800B1 converter box
rca converter box syvania tv codes please thank you robert
Feb 01, 2009 | RCA Universal Remote Control
Universal remote programming
Since Insignia is really Zenith, a universal remote that can work on Zeniths should do the job. I have this converter box and use a RCA universal remote. I code that works is usually reserved for Zenith satellite boxes (5203).
Oct 26, 2008 | Insignia Digital-to-Analog Converter for...
I am trying to find a universal remote code to control the new Zenith digital tv tuner converter box. The model # is DTT900. It is for a person with low vision who cannot see the buttons on the remote...
Pls post back with the brand and model of the universal (replacement) Remote Control or what remote control you would want to use with the Zenith DTT900 Digital-to-Analog Converter Box.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 23, 2008 | Televison & Video
Converter box codes for rca universal remote rcr3273/3373 for zenith or lg boxes
Hope this works
Oct 07, 2008 | RCA 3-Device Universal Remote
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
