Question about Sewing Machines
No power to the machine.
After moving the machine to a different room, it won't power up. Have checked outlets and switch and pushed the plug into its spot repeatedly. Anything else to try?
    New Friend:
No, can't get it to come back on, no matter what outlet I try.
Posted on Dec 11, 2015
  • 1,631 Answers
Yeah, you were not really clear...
but... does it still work where you moved from?
Posted on Apr 11, 2015
3 Suggested Answers
SOURCE: no power to machine, checked power cords were all
If you have a light to light up the sewing area, this light has to be on or the machine will not work.
The switch should be next to were the cord goes in the machine.
Posted on Jun 22, 2011
SOURCE: My Juki HZL-E80 won't turn on
no, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
Posted on Oct 15, 2012
Sewing machine was shocked it won't turn on when plugged
this is all i can find out at the moment.Check the electrical outlet for power and reset the house circuit breaker if the outlet is dead. Replace the outlet cord if it's worn or damaged. Unplug the sewing machine and check for loose wires. Replace the on/offswitch if it's defective.
Sewing Machine Won't turn on ' Symptom Diagnosis - Sears PartsDirect
https://www.searspartsdirect.com/sewing-machine-repair/symptom/SMAC2200003.html..
or go to this link might help you out.. Sewing machine won turn on Google Search
Oct 23, 2017 | Sewing Machines
I need to know where the power switch to my vintage sewmor sewing machine is
It depends on the model of your sewing machine. Usually, there is a push button switch somewhere on the machine. However, some machines did not have an on/off button--just activated as soon as they were plugged in to the electrical outlet.
Mar 11, 2017 | Sewing Machines
Tried different outlets & unplugged. Lights came on briefly when on kitchen counter plug, but moved then it wouldn't start??
If the power is flickering, then your machine probably has an electrical short somewhere.
Dec 11, 2015 | Sewing Machines
Oct 15, 2012 | Juki HZL-E80 Computerized Sewing Machine
Brothers sewing machine
first check the outlet to see if it works
next check to make sure the power cord is plugged into the machine
correctly.
if you've done the above things, & you push the switch to turn the machine on & it still won't come on, then the machine needs to be
checked.
Sep 05, 2012 | Brother Sewing Machines
Nina ME 4123 won't switch on
is the power cord inserted correctly?
is the outlet working ?
if the answer to these questions is yes, then the machine needs to be check to find out what's wrong with it
May 26, 2012 | Bernina Sewing Machines
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
When I use the presser foot nothing happens. The machine is plugged in, turned on and everything is set up correctly. I was told my a not so reliable source that the motor may be shot. But, the machine...
even though it's only used moderately the motor can go out,
does the light come on?
try plugging the sewing machine into a different outlet
check to make sure the power cord is pushed all the way in
it also may be the power cord itself that has gone out
it could also be the on & off switch
Sep 01, 2010 | Singer 6038 Mechanical Sewing Machine
Sewing Machines Logo
56 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
