Question about Stihl Used Fs46 Fs45 Fs55 Fs55r Engine Powerhead Lk 12
Just installed new coil but back fires through the carby and won't start.
  • Stihl Master
  • 1,169 Answers
Check for shear flywheel key.
Posted on Apr 11, 2015
1250 cub cadet will not fire. Put in new point s, condenser, plugs and coil. Still no fire.
Hi have u tried cleaning the carby & the jets in it .U mention it won't (FIRE) do u mean it.wont start or do u mean there is no spark. . Cheers.
Dec 29, 2016 | Cub Cadet Garden
My 1985 Mercedes 190e isn't getting fuel to the distributor, why
to start with if you got fuel to the distributor, there would be a massive explosion and a fire. Fuel goes to the carby or injectors and electrical spark is from the distributor . if you are new to the mechanics of a vehicle then get a workshop manual for your vehicle . If there is no fuel to the carby( carburettor) then the reasons will be that the pump is not working, tank not venting, filter blocked carby needle and seat problem or injector problems. If there is no spark at a plug lead then it could be immobiliser, coil, HT leads , coil or distributor ignition module.
Dec 29, 2014 | Cars & Trucks
Klx250 wont run it has spark new battery and cleaned carby but wont fire up will occasionaly start and run fine
Remove the filter or filter connection to the back side of the carb and spray it with starter fluid. If it starts when you do that each time, the carbs still have a problem and need to be cleaned out again or adjusted correctly.
Jan 17, 2013 | 2005 kawasaki KLX 250
Hi i just got a 1988 gsx600f i put new plugs in it tuck it out for a ride and it was running good then i gave her a little gas to kinda see what it would do and it bogged so i idled it home and statred...
it seems odd that your coils would play up, usally the they just stop working. You talk of it bogging down? , i would suggest that to be a carby problem, especialy if the bike has sat around for a while. first try to just drain the carbys, as you can do this without removing them, should be a drain screw or plug on the bottom of the carby. Make sure your air filter is clean too!
May 27, 2010 | 1988 Suzuki GSX 600 F (Katana)
2.4 pontiac wont start but cranks over
Do a compression test as a malfunctioning valve can cause back fire through the carbie. Since you have changed all the wires double check you have them in the right order because if they are wrong you could get a backfire.
Sep 23, 2009 | 1996 Pontiac Grand Am
Yamaha dt 175, voltage question. When idling, my DT measures 7 volts across the battery terminals. When revved it jumps up to over 13 volts. This is a six volt bike. I know the battery is completely shot....
You need new regulator and new battery.The battery works as a filter as well.If it is in bad condition it does not filter anything and in high rpm the current is very high.
Jun 08, 2009 | 2006 Yamaha DT 125 X
Stihl Used Fs46 Fs45 Fs55 Fs55r Engine Powerhead Lk 12 Logo
88 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
