Question about LCN 4041 Hw/PA Hold Open w/62PA Arm Door Closer
Why is the hold open stoping the door from closing
I have no power to the dashboard in the bob cat after door was opened with the bucket up
Blown fuse. Short in wiring to cab door. Unplug door harness replace fuse a be careful not to damage door with loader arms until you get new door harness it will not know if door is open or closed
May 09, 2012 | Bruder Cat Skid Steer Loader
My lift master 41A5389-1E, works fine but a couple of days ago it stoped, it does not want to reverse, so the motor doesn't reverses to close tg He door, isatead it wants to keep going up, but it is...
Likely something else. Look at the sensors near the bottom of the door track. These get knocked out of alignment (or blocked), and the system thinks something is in the way and opens the door, if requested to close.
May 11, 2011 | Vacuums
The freezer door does not close properly, or opens by itself as if one of the drawers is pushing it open. The drawers are all closed correclty and there are no obstructions or foreign objects preventing...
The lower hinge on each door may have a door closing cam. It raises the door up ΒΌ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
Mar 23, 2011 | Refrigerators
Whirlpool Dryers Model LEQ9508LWD does not start problem I used to be able to start it by wegling conection of the dryer load door and dryer. now it stoped completly
It sounds to me you could have a faulty door micro switch or the door is not aligned properly. When you open & close door the switch should operate so the drum stops when you take things out of dryer.
There will be a little plastic pillar on the door which presses the switch when door closed. Make sure the door isn't warped.
Pete
Nov 06, 2010 | Dryers
The right side sliding door of my 2005 voyager is not workingat the begining trying to open it partialy worked mean the when i presed the the open/close button the door started moving but on a specific...
hi
this is because of the track in which the door slides.there is something in the path or the track got damaged which prevents the door sliding after a certain limit.
the wiring harness and the motor are seems to be in good condition becausethe door works til certian point.so the problem is with the track only.
if my answer was usefull please vote
Jun 27, 2010 | 2005 Dodge Caravan
Washer door won't unlock
im sorry to tell you but you may need to get a repair man out to fix the lock from the inside of the washer its sort of stoped half way through its washing cycel
i gess the drum suport springs have poped off and thats why it went for a walkys in the first place
Oct 25, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
99 Trans Sport Power windows not working
Check the wiring in the door opening you likely have a broken wire or 2 in the rubber bellows.I think the wire color is orange/black stripe.
Apr 26, 2009 | 1997 Pontiac Trans Sport
Door will not open
try pulling emergency rope open door and close it this may reset opener if you have electric eyes make sure they are clear and they line up
Feb 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
My Maytag Jetclean Dishwasher Model # MDB4010AWB Serial # 16163916uk is stoping midcycle, it doesnt make any noise or anything just stops. Water left sitting in bottom and have to open door then close...
possibly a bad door switch losing contact, only after opening nad closing is it making contact again. part number for door swtiches and holder 99002254 retails for a about $25
Nov 05, 2008 | Maytag Dishwashers
LCN 4041 Hw/PA Hold Open w/62PA Arm Door Closer Logo
394 people viewed this question
Top LCN Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a LCN Hardware and Accessory Expert? Answer questions, earn points and help others
