Question about Bulova Clocks Miniature Clock B0425 Watch
How do I get to the battery in a miniature clock?
I have a g-shock ga-150 watch runs on no battery after 4 years the watch is not on so to speak.any ideas???
The miniature perpetual motion machine has failed. Could be due to dirt or part fatigue.
Sep 21, 2017 | The Watches
Battery cover is stuck-can't remove to replace battery.Tried small screwdriver to no availe-will not fit into top
A "dollar store" set of miniature screwdrivers will have what you need, although I often find the only one that fits is the smallest.
Apr 13, 2017 | Watches
What is the battery replacement # for a pulsar n944 6a00 ?
BATTERY CHANGE The miniature battery SEIKO SR927W which powers your watch should last approximately 2 years. However, because the battery is inserted at the factory, its actual life once in your possession may be less than the specified period.
Mar 24, 2016 | Pulsar Watches
I just got a Bradford Exchange Purr-fect Moments Kitten Cuckoo Clock and the battery powered clock movement doesn't work. I need to get a new clock movement with the wire that connects it to the bird
Bradford is a high end retailer. You can contact them because if the item is not over a year old then it is warrantied. The other thing is you can email them to see about the clock works inside the unit. See this page and look for "contact us" at the bottom.
Jan 05, 2015 | Watches
Danbury clock 'things remembered'. How do I access the battery? I cannot figure out how to find the battery. The battery is dead after two years and I need to replace it. It is not obvious how to...
The things remembered clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Jan 31, 2014 | Watches
The clock is just tension fit in the housing. Easiest way to get it out is to get a plastic suction cup. Press the suction cup onto the face of the clock and pull and jiggle till the clock comes out. This way you wont gouge up the wood trying to pry the clock out with a screwdriver. It takes an N cell battery: https://en.wikipedia.org/wiki/N_battery
Danbury book clock, how do you take clock out to put in battery?
Oct 20, 2013 | Watches
Large clock and second not working
probably needs a new battery these watches have two batteries
May 01, 2013 | Kenneth Cole Mens Gunmetal-Tone Watch...
Metal pendulum wall clock run by AA batteries... does not run... new batteries do not solve the problem.
Hi! the movement must be bad, you can actually have a battery clock movement replaced easily at a watch or clock shop! We charge about $30.00 to 50.00 if the movement is available, you did not mention what type of clock? if you can let me know i may be able to help further. thank you!
Sep 20, 2011 | Watches
I have a Westclox battery operated wall clock with chicken on face. The battery is new. The second hand tries to move but just "clicks" How can I fix this?
Sounds like it is just worn out.
Sometimes you can replace the generic clock works in these type of clocks. Go online and do a search for battery powered clock works, and see if you can match yours. They are removed quite easily after popping off the clock hands, and removing a nut under the hands that holds the clock works in the chicken.
Here's a link to a site that sells the clock movements... http://www.clockworks.com/
Jun 09, 2010 | Watches
Bulova Clocks Miniature Clock B0425 Watch Logo
126 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
