Question about GE Washing Machines
My ge top load washer wont start already change out board. not sure if my lid switch or magnet is bad?
Im thinking its my lid switch but not sure
  • Gabe pallares
    Gabe pallares Apr 11, 2015
    Model # GTWN 505MOWS serial # DV907984G its a GE top load washer
  • GE Master
  • 473 Answers
Does you washer attempt to fill with water or is it totally dead. If it doesn't fill then you may have a bad inlet water valve. If you are on hot wash---switch to cold wash. if it starts to fill its the valve. If it fills and then goes dead, it could be several thing including the lid switch. A model number will help us help you.
Posted on Apr 11, 2015
    New Friend:
Sure does sound like your safety switch isnt working. To be sure please give me model number to unit and I can do some checking and get right back to you
My ge spacemakermodelwslp1100d0ww reads lo when i try to start it
Hello Tina,
The LO code means lid open so the washer thinks the lid is open and wont agitate/spin with the lid open. What to check and see if the lid switch which is basically a magnet is good firstly check on the lid for the magnet to be in place,with the lid open the magnet will be in the upper left corner (ya can check it by seeing if a paper clip or similar item sticks to the magnet) if it seems ok next check where it would fit to when the lid is closed which would be on the top in the front left corner and check and see if that area seems intact and not cracked. If ya find the magnet or the area on the top to be in good shape the lid switch would need to be replaced . The part number for that switch is WH12X10104 the exact name for it is the REED SWITCH and it could be purchased at your local appliance parts store or online at;searspartsdirect.comapdepot.compartselect.comapwagner.comrepairclinic.com
I hope i have been able to help ya fix your washer,GENE
Oct 04, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Washer would wash, or spin. the water appears to drain ok and fills ok
the magnetic lid switch is bad,its located underneath the lid toward the right side of where the lid lays,yoiu will see the magnet under the lid,the switch is below this
Jul 06, 2011 | GE WBSR3140DW Top Load Washer
I have a GE top load WJRR4170G1ww. It wont agitate or spin. Any suggetions you might have would be appreciated.
the magnetic lid switch thats mounted along the right side of where the lid sits is bad remove front cover and unclip it from underneath the top cover its a g.e. part number-- wh12x10334
May 29, 2011 | GE WBSR3140DW Top Load Washer
Dosen't spin, dosen't fill water
your lid switch is a magnetic switch. make sure you have the magnet attached at the lid. if you do still the switch may be bad. question : did the washer fill with the lid open?. if it not then that would be an indication the switch bad. let me know
good luck to you.
Feb 07, 2011 | GE WBSR3140D Top Load Washer
My Lid on my washer displays open when I close it and won't start if lid is open... please help.
your lid switch is not working or may be jammed try opening the top of the back of the washer make sure the lid switch is working im not sure if the mtw range uses switch or magnetic recognision with switch there is a small lid switch that clicks when the lid is slightly lifted with magnetic it makes no noise however they can both be bypassed by cutting the switch wires normaly black and red running along the right side of the control board (making sure power plug is not plugged in) stripping the two wires and joing them together
this should work
Dec 28, 2010 | Maytag Bravos MTW6600T Top Load Washer
Whirlpool stack washer will fill but will not progress to rest of cycle
It sounds like the lid switch is not making contact. It is a magnet located on the lid so that when you close the lid, the magnet pulls the switch closed. Make sure the magnet is still on the lid. If you washer lid will not stay open on most models, the magnet is gone because this is the same magnet that pulls the lid switch closed. If you can find where it goes, find a strong magnet and place it on the top inside rim where the lid goes when closed. Turn the machine on, let fill with water. Once this is complete and the machine should start. Take the magnet and move it around the rim until the unit starts running. If you can't get it to run, most likely the switch it's self is bad. I think you will find the magnet on the lid is gone and the machine will start running once you pass a magnet over the place where it goes. If so you will need to replace the part.
Oct 17, 2009 | Whirlpool LTE5243D Top Load Stacked...
GE Profile wont spin,why?
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wiring to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you replace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!! Thanks for using Fix-ya. A high rating would be appreciated for your free question :)
Jul 26, 2009 | GE Profile WPRE6100G Top Load Washer
GE washer GNSR2140A0WW wont spin/agitate but fills and drains
Hello, your problem is going to be with the lids switch, in this machine it is going to be a magnetic contact. You can confirm this my pulling the front panel off and accessing the wireing to the lids switch, If you have electrical knowledge bypass the lid switch using a wire nut and run the machine. If all is ok make sure you relpace the lid switch since it is there for a reason. If you have any other questions or concerns please feel free to comment again. Good Luck!!!
Jul 19, 2009 | GE WBSR3140DW Top Load Washer
No spin
lid switch sounds like some ge had a plunger type switch operation ck for broken pin on lid that pushes switch lever down ..others had a magnetic type switch magnet on lid front right corner that closed switch on cabinet front corner
Jul 31, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
