Question about Altec Lansing Audio Players & Recorders
I need a fuse cover cap for main box. - Altec Lansing Audio Players & Recorders
    Top Expert:
  • Altec Lansing Master
  • 45,233 Answers
Contact the manufacturer is only option you have .
Posted on Apr 11, 2015
Need a fuse diagram for a 2005 Dodge Dakota SLT Quad Cab 4x4
Look underneath the cover for the main fuse box under the hood. It should have a diagram for all the main fuses along with the sizes and the relays.
Jun 09, 2015 | 2005 Dodge Dakota Quad
Where is the fuses on a suzuki c90t
According to the 2007 owners manual for my C90T there is a 30A main fuse located behind the left upper cover. To access the main fuse lift the fuel tank lid and remove the six bolts that are holding the left and right tank covers in place (not the screws that are located under the fuel cap) then remove the two screws on the front of the speedometer/fuel inlet cover (they face the base of the handlebar risers) then remove the left tank cover and left upper cover by removing the screw at the base of the left upper cover. One 30A spare fuse should be located in the main fuse box. To access the fuse bank containing the other six fuses remove the right crank case cover, once it is cool to the touch. One 10A and one 15A spare fuse should be located in the main fuse box. Fuse list: 30A MAIN fuse protects all circuits; 10A HEAD-HI fuse protects the headlight high beam and headlight high beam indicator light; 10A HEAD-LO fuse protects the headlight low beam; 10A FUEL fuse protects the ECU, fuel pump, injectors, neutral indicator light and oil pressure indicator light; 15A IGNITION fuse protects the fuel pump relay, starter relay, ignition coils, decomp relay and solenoid; 15A SIGNAL fuse protects the turn signal indicator light, FI indicator light, speedometer lights, brake light/tail light and horn; 10A POWER SOURCE fuse protects the electrical accessories connected to the output terminal
Aug 13, 2011 | 2005 Suzuki Boulevard C90T
I have a S 4.0, car has been sitting in garage for 1 year. New battery installed but only drivers side window, and power seats work. No crank, no lights, wipers or any other acc's. I have checked the...
Look in your owner manual for the 3 fuse box locations. It is similar to our Lincoln LS.
From LS owner manual.
There is a 175 amp mega fuse in the wire harness near the luggage compartment fuse box. In circuit with Red/Blue wire.
Front power distribution box
The front power distribution box is
located in the engine compartment.
The power distribution box contains
high-current fuses that protect your
vehicle's main electrical systems
from overloads.
Passenger compartment fuse panel
The fuse panel is located on the right hand side kick panel. Remove the
panel cover to access the fuses.
To remove a fuse use the fuse puller tool provided on the fuse panel
cover.
Rear power distribution box
The rear power distribution box is
located in the luggage compartment
under the spare tire well cover. The
from overloads.
Jun 08, 2011 | 2000 Jaguar S-Type
How to Change the master fuse
open the hood, look on the drivers side fenderwell for [main fuse box] black box,plastic cover,remove the top lid,under the top lid will have diagram where the main fuse is located. if you have an owners manual,usually located in the glove box, this will guide you to all fuse panels,under the hood and the dash.but the main fuse is located under the hood in the main fuse box on drivers side fenderwell. clearly marked[main fuse and relays] you may have to turn the plastic bolt on top of the cover[counter clockwise] to remove the plastic cover,look under the lid for exact location of fuse or relay you are seeking. thank you for choosing fixya.com
Mar 04, 2011 | 2000 Dodge Grand Caravan
Where can I locate the fuse box for my 2003 Hyundai Elantra?
You can find the fuse box, under the steering wheel. Remove the plastic cover, and look on the back for the diagram to see which fuse to replace. There is another fuse box under the bonnet as well, usually behind battery, black plastic cover.
Dec 04, 2010 | Hyundai Elantra Cars & Trucks
Where is the fuse box that is supposed to be under the stearing wheel
Mazda 323/MX-3/626/MX-6/Millenia/Protégé 1990-1998 Repair Guide
1994 Mazda MX-6 2.0L MFI DOHC 4cyl
Circuit Braker
A bimetal circuit breaker is located in the joint box, which is just above the interior fuse panel. This circuit breaker protects the rear window defrost circuit and is the plug-in type.
Fuses
The main fuse block is located inside the left side of the engine compartment near the battery. There is also an interior fuse panel located just above the left side kick panel.
Fuses Replacement
CAUTION Never replace a blown fuse with one of a higher rating. Severe damage to the vehicle, electrical harness and components, as well as personal injury or even death could occur.
Main Fuse Block
(see Figure 1)
  1. Disconnect the negative battery cable.
Fig. 1: Remove the fuse box cover, located in the engine compartment, to access the main fuses for the vehicle
  1. Unhook the lock tab from the main fuse block cover and open the cover.
  2. Pull the fuse from the main fuse holder.
  3. Installation is the reverse of the removal procedure.
Interior Fuse Panel
The interior fuses simply unplug from the fuse panel. Use the fuse puller tool provided with your car to remove fuses from the panel. The tool is located on the back of the interior fuse panel cover.
Relay
The main relay box is located on the upper left-hand side of the firewall (bulkhead). There is also a relay box mounted inside the vehicle under the left side of the instrument panel.
Relay Replacement
  2. If replacing a relay at the main relay box, disconnect the electrical connector and slide the relay from its mounting bracket.
  3. If replacing a relay at the interior relay box, simply unplug the relay.
  4. Installation is the reverse of the removal procedure.
Fig. 1: Typical fuse box and panel locations and configurations
I hope help you with this (remember rated this help) Good luck.
Sep 28, 2009 | 1994 Mazda MX-6
Fuse Box for 02 Suzuki XL7
The main fuse panel is inside the engine compartment. The second fuse box is located under the drivers side of the dashboard. Remove the fuse box cover (if equipped) by pushing in at both ends and pulling off the cover.
Feb 25, 2009 | 2002 Suzuki XL-7
Fuse location
The fuse is located near, but not within the main fuse box. (took me 5 years to figure that out...haha) The main fuse box is the one that is shaped like an upright rectangle, containing most of the fuses for the car, and concealed by a cover. Don't bother with the main fuse box...
Look immediately above the main fuse box, and you will see a uniquely shaped fuse holder, containing, you guessed it, the cigarette lighter fuse.
The fuse holder should say "20 Cigar" on the cover. The cover actually swings open from the bottom. Just grab it gently between two fingers and give it a tug, it'll pop right open giving you access to the fuse.
Oct 01, 2008 | 1994 Ford Escort
154 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
