Question about Munchkin Inc Munchkin Safety Toddler Bed Rail
How do I attach a munchkin safety toddler bed rail?
I need the instruction manual to attach the rail to the bed
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Instruction manual for tomy bed rail
need instructions on how to covert to toddler bed
Apr 23, 2010 | Baby Gear
I'm missing instructions for my 4 in 1 crib
Certain cribs are going to the crypt. Simplicity Inc. is now out of business. As of July 12, 2009 at least 13 children have died in cribs and basinets recalled by Simplicity.
Sorry to say,but you may never find the manual.
I tried to access their site,but to no avail.
Please check to see if your's is one of them. You have to call the 1-800 number...if you can find it.
Sep 19, 2009 | Simplicity for Children 4-in-1 Convertible...
Converting Delta Martinique 5-in1 Crib to single bed
I have the same crib and it can be transformed into a toddler bed by removing the front rail and it can be transformed into a full size bed using a full size bed frame and the front and back rails of the crib.
May 30, 2009 | Delta Martinique 5-in-1 Crib
I dont have the instructions to turn my simplicity 4 in 1 crib to a toddler bed
Install Safety Rails
Mattress support must be in lowest postition
Remove the Front Panel Contoured Top rail and Front Panel
Loosen connector pieces on the end of the leg of the Safety Rail to the End Leg using two of the Allen Bolts (11/2 in). Loosely attach the leg of the Safety Rail to the underside of the Mattress Support using one of the short Allen Bolts (3/4 in) through connectors. Tighten all three of the bolts holding the safety rail to the unit.
Repeat procedure with the other safety rail.
These are the instructions in the manual. Basically, you take off the front cross board and rail, attach the safety rails to each of the front legs. They kind of go 1/3 of the way across the front with about a 1 1/2 foot opening in the center.
Apr 08, 2009 | Simplicity for Children Ellis 4 in 1 Sleep...
Trying to turn our crib into a toddler bed
Part needed: Allen Wrench
Safety rail
Safety rail bolt
Make sure the mattress support in in lowest position. Remove the front top rail and front panel. Attach both safety rails ( small side pieces) to the crib end leg using the safety rail bolts.
Mar 25, 2009 | Delta Enterprise Baby Gear
Need instructions on how to convert my aspen simplicity crib into a toddler bed?
i think this is the same crib that i have. I remove the front rail that slides up and down, then i removed the plastic contraptions that allow it to slid up and down on. I then attached the bed frame on the lowest setting, by first fastening the two back ends first. Then I attached the toddler rails to the bottom of the bed frame and then once they where on I attached the bed frame to the crib with the rails and the brackets for the bed frame pressed together. I hope i explained it so that i makes sense.
Mar 14, 2009 | Simplicity for Children Aspen 3 in 1...
Aspen simplicity converting instructions
all you have to do is take off the front railing and attach and screw in the peices that came with it for the todler railings and thats all you do
Nov 04, 2008 | Baby Gear
Jardine convertible crib instructions
Hi, I know it looks hard but It's really simple .just take out the screws that are on each side on the bottom and top 1 on the top and one on the bottom each side( 4 in total )(Sides not on the front) and that's it, the front part comes off and you save it for when you make the bed a full size bed wich that part becomes the foot board. Hope this information helps! Good luck!!
Jun 11, 2008 | Baby Gear
Convert to toddler bed
They do have answers on their website, you may want to check your printed or online crib instructions to remind yourself how you put the crib together, too.
I found the answers here:
http://www.pali-design.com/index.php?path=customer_services&template=faq&section=customer_services&subsection=faq&page=faq
i've pasted them below. You can make it a toddler bed without a side rail just by removing the movable side of your crib, and you can install the side rail instead of the movable side if you want it to look a little more finished and help keep your child from rolling out of the bed.
FAQ
How to convert a crib into a toddler bed
To convert a crib into a toddler bed you must loosen the two front gold bolts left and right side of the crib and remove the dropside (the front gate that goes up and down). After removing the dropside be very careful that you tighten back your two gold bolts.
How to install the streight rail (toddler rail)
To install a streight (toddler) rail loosen the two front gold bolts left and right side of the crib and remove the dropside, once you have removed the dropside replace with the streight rail. Always be very careful and make sure you tighten back your two gold bolts in the front.
Oct 14, 2007 | Pali Sabrina Crib
Munchkin Inc Munchkin Safety Toddler Bed Rail Logo
612 people viewed this question
Top Munchkin Inc Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Munchkin Inc Baby Gear Expert? Answer questions, earn points and help others
