Question about Kenmore Washing Machines
Kenmore top load model 11022622100 washer won't spin fast enough to drain water
  • Kenmore Master
  • 473 Answers
The spin cycle doesn't drain the water out, the spin cycle rings out the clothes. There is a drain pump that actually removes the water from the washer. If the tub is staying full of water check the hoses (2 of them) that come off the drain pump. Now if you mean the clothes are not spinning dry enough that is a different. Your Kenmore is actually a Whirlpool washer that uses what is called a DIRECT DRIVE COUPLER. It couples the motor to the transmission instead of a normal belt. Think of it as a Oreo cookie device.on the outside is 2 plastic pieces. Each piece has 3 plastic prongs sticking outward and each one will press on to a metal shaft. One goes on the motor shaft and one goes on the transmission shaft with the prongs pointing at each other. In the center between these plastic parts is a solid rubber disk with 6 holes drilled in it. The 3 prongs on each shaft go into the holes on opposite side to couple the motor to the transmission. when this part goes bad, either the prongs break off or the holes in the rubber disk wear all the way through. In either case the coupler would need replaced. It comes as a 3 piece set for about $10 to $15 and takes about 1/2 hr to fix if your handy.
Posted on Apr 11, 2015
    Top Expert:
  • Kenmore Master
  • 46,336 Answers
Call service man transmission not shifting to hi
Kenmore Series 70 Top Loading Washing Machine Model # 110.20722991 Serial# CL 1134809 Hello, Our washing machine is leaving our clothes soaking wet when finished. What could the problem be?
2 things are possible. Can you tell if the spin cycle is engaging? If the spin cycle is not engaging properly or very fast, then the water will not leave the clothes. less likely is that the machine is not draining the water away properly or fast enough.
Jun 09, 2016 | Kenmore Washing Machines
OK- my Kenmore He2 won't spin fast enough to drain when there is a heavy load involved. This is what I've done- emptied the filter- lots of change and other gunk, cleaned out attached hoses and the p
Check the shocks on the drum to make sure they are ok. if they wear out the drum spins out of balance and the computer wont allow it spine because it would WALK and damage itself.
Apr 19, 2017 | Kenmore HE2 Plus Front Load Washer
The water in my front-loaded kenmore-he washer is not draining and doesn't seem to spin very fast either.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 10, 2011 | Kenmore Front Load Washer
Kenmore model #22622100 top load washer. My question is our washer has a sour smell and we have pulled it out from the wall. We are wondering how to take the top off.
First, see the Sears parts site for your washer with diagrams and parts lists. Always a good reference tool.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11022622100/0582/0153200?pathTaken=&prst=0&shdMod=11022622100
Next, see the following for how to release the console and remove the cabinet:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
As a final reference, see the following Whirlpool / Kenmore Service manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Feb 12, 2011 | Kenmore Washing Machines
Does not spin dry enough
Look for pinched or restricted drain hose. Is the water volume exiting the machine, enough?
Jan 22, 2011 | Kenmore 22422 Top Load Washer
Kenmore washer top load all cycles normal but when in the rinse/spin cycle notice it does not seem to spin fast enough to remove water from clothes and the are wetter then normal
There could be a number of reasons My best guess is that it will reduce the spin speed if it thinks it can't drain properly. Check that all the pipes/ filters etc are clear and that it can drain all the water out. Also it wont spin fast if the load is unbalanced. Does the spin speed change according to loading or is it low all the time? It may have a motor control problem, but that seems unlikely if it's working normally other than the spin.
Jan 13, 2011 | Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
Kenmore 90 Series washer needs two spins to remove water
We have exact same washer. It is 11 years old. We are at a point where we have to spin it 7 times and then still isn't too dry. It dies yesterday a very loud death. Mentioning this here because it could be a foreshadowing of your Kenmore 90's future.
Dec 29, 2008 | Washing Machines
Kenmore 90 Series, clothes wet after spin
First thing you need to check is the speed of the spin cycle. As long as you are not overloading the machine, it should spin the clothes pretty dry. the basket drive may need to be replaced. If it is spinning very fast, then check the drain hose, make sure the water is coming out nice and fast. If not you may have a water pump problem even lint clogged inside it.
Nov 29, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
Sal DeAngelo
fordexpert
Ed Mac
