Question about Uniden expandable dect 6 0 cordless telephone with caller id-call waitin
What is t coil? - Uniden expandable dect 6 0 cordless telephone with caller id-call waitin
  • 2,039 Answers
Posted on Apr 11, 2015
2005 Pontiac vibe fuse for coil . were is it located at
no fuse for coil if no power to coil[s] assuming its the ignition coils sheck and test wiring and coil for damage or failure
Dec 20, 2017 | Pontiac Cars & Trucks
I have a 2005 Grand caravan 3.3 with 236.000 miles it came up with a code P2308 ignition coil C secondary circuit ? No spark to cylinder 6 & 3 ?
No cylinders fire at same time. 6 & 3 must be from same coil-ignition coil C-that is the one with the problem. And the secondary circuit- that is the spark firing portion of the coil. Coils have a primary winding circuit and a secondary wire winding circuit. The secondary comes out of coil as the tower, or the spark plug wire tower -the business end of the coil leading to the plug.
You could have a bad new coil (happens occasionally) or the connection to that coil may be the problem-the connection where the coil snaps onto the coil pack assembly. Try swapping that coil (coil C) with another one there and see if problem follows the coil. See? Keep your plug wires the same, just swap coils with another and see if the new position for suspect coil causes other cylinders to misfire. If a different coil in that "C" position causes same code, then it is not the coil itself, but probably the base assembly that the coil connects to.
These ignition systems use what is called a waste spark, or exhaust waste spark system. The coil will send spark to 6 & 3 simultaneously, but since one is always on the exhaust stroke while the other is on the compression (firing) stroke, the exhaust spark is very weak, and all the energy from coil is directed to the compression stroke cylinder. It sounds crazy but it works great.
Since you say it runs bad just as before, that indicates the coil is not the problem, but something wrong with the base of the coil pack . This is where the wiring is directed to the coils.
Oct 13, 2017 | 2005 Dodge Grand Caravan
No spark from coil to distrubuter
Disconnect the ignition coil output wire at the distributor cap.
Connect a spark plug to the end of the ignition coil output wire which you just disconnected.
Connect a ground wire to the threaded portion of the spark plug.
Disconnect the ignition coil ground wire from the negative terminal on the coil (Green Wire).
Connect one end of a ground wire to the ignition coil negative terminal.
Turn the ignition switch to the ON position.
Tap the other end of the ignition coil ground wire jumper on an good grounding point (for example the battery negative terminal) and look for sparks at the spark plug that correspond to the frequency of your tapping of the ground wire.
If you have a good spark at the spark plug, the ignition coil is good.
If you don't get a good spark, check for approximately 12 VDC from the coil positive terminal (black wire) to ground with the ignition switch in the ON position. You should also get approximately 12 VDC from the coil negative terminal (Green wire) to ground
Ignition Coil Resistance Check
In addition to the test above, you may elect to perform an ignition coil resistance check as confirmation of the coil's condition.
Check the ignition coil primary coil resistance by connecting an ohmmeter between the positive (Black wire) and negative (Green wire) terminals on the coil. The resistance should be 0.4 to 0.6 ohms.
Check the ignition coil secondary coil resistance by connecting an ohmmeter between the coil output terminal and the ignition coil negative terminal. The resistance should be 5000 to 7200 ohms.
You may have a bad coil or bad ground or wire connection
Jan 23, 2017 | Cars & Trucks
How to change a coil pack on a Chevy Tahoe
To Remove......
1. Remove the spark plug wire from the ignition coil.
2. Disconnect the ignition coil electrical connector.
3. Remove ignition coil bolts.
4. Remove ignition coil.
To Install.....
1. Install ignition coil.
2. Install ignition coil bolts.
3. Tighten ignition coil bolts to 8 Nm the same as 71 inch pounds.
4. Connect ignition coil electrical connector.
5. And finally, install spark plug wire to ignition coil.
Apr 22, 2015 | Chevrolet Tahoe Cars & Trucks
I need to wire 3 woofers but 2 are dual voice coil and one is single voice coil
sure, if you wish to wire them all together, wire the first dual voice coil subs first voice coil negative to 2nd voice coil positive, second voice coil negative to single voice coil sub positive, and single voice coil negative to 2nd dual voice coil subs 1st voice coil positve (again with the second dual voice coil sub, run the first voice coil negative to the 2nd voice coil positve) your speaker leads will be attatched to first dual voice coils 1st voice coil positive, and 2nd dual voice coils 2nd voice coil negative)
Apr 01, 2013 | Kenwood KAC-8104D - 1000 Watts Class D...
I need a digram of the ignition coil for 1997 E320 mercedes
Hi.
Ignition coil terminal 1 --> UCE Bosch ME2.0 (terminal 21(coil 1) ,16(coil 2), 7(coil 3) ,14(coil 4), 4(coil 5), 18(coil 6))
Ignition coil terminal 2 --> Fuses and Relays Module X61 (terminal 34)
Ignition coil terminal 3 --> UCE Bosch ME2.0 (terminal 20(coil 1) ,17(coil 2), 6(coil 3) ,13(coil 4), 5(coil 5), 19(coil 6))
Hope i helped.
May 20, 2011 | Mercedes-Benz E320 Cars & Trucks
How to remove a 1989 pickup chevrolet ignition coil ,6 cil.,chayane
GM Full-Size Trucks 1988-1998 Repair Information
Ignition Coil - REMOVAL & INSTALLATION
(sSee Figures 1, 2 and 3)
Fig. 1: Ignition coil mounting-4.3L engines
  1. Tag and unplug the wiring connectors from the coil and the coil wire.
  2. Unfasten the retainers securing the coil bracket and coil to the manifold.
  3. Remove the coil and bracket and drill out the two rivets securing the coil to the bracket.
  4. Remove the coil from the bracket.
To install:
The replacement coil kit may come with the two screws to attach the coil to the bracket. If not, you must supply your own screws.
Fig. 2: Ignition coil mounting-5.0 and 5.7L engines
Fig. 3: Ignition coil mounting-7.4L engines
  1. Fasten the coil to the bracket using two screws.
  2. Fasten the coil and bracket to the manifold. Tighten the retainers until they are snug.
  3. Engage the coil wire and the wiring connectors to the coil.
Hope this help to solve it (remember comment and rated this).
Apr 21, 2010 | 1989 Chevrolet C2500
2005 Chevrolet Silverado 1500HD 6.0 motor. I am getting a misfire code on ignition coil "D". Which coil pak is coil "D"?
Coil "D" should be Cylinder #4
Coil "A" = Cylinder #1
Coil "B" = Cylinder #2
Coil "C" = Cylinder #3.
Coil "D" = Cylinder #4
Coil "E" = Cylinder #5
Coil "F" = Cylinder #6
Coil "G" = Cylinder #7
Coil "H" = Cylinder #8
Firing Order for 6.0L
1-8-7-2-6-5-4-3
Cylinders:
(back of vehicle)
8----------7
6----------5
4----------3
2----------1
Ignition Coils are adjacent to the corresponding Cylinder
Let me know if this helped.
Feb 26, 2010 | 2002 Chevrolet Silverado 1500HD
Spark in yoke coil
Sir ,
I hav dismantle the whole yoke coil and now i am trying to wind that burnt coil myself, which may take couple of days
Tks
Khatri
Dec 31, 2008 | Panasonic WV-CM1020 Television
Bad miss
0900c1528008ee09.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 1: Ignition coil mounting-4.3L engines
To install:
0900c1528008ee0a.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 2: Ignition coil mounting-5.0 and 5.7L engines
0900c1528008ee0b.jpg enlarge_icon.gifenlarge_tooltip.gif Fig. Fig. 3: Ignition coil mounting-7.4L engines
  4. Hope this helps
    Lefty64
Dec 23, 2008 | 1988 Chevrolet C1500
Uniden expandable dect 6 0 cordless telephone with caller id-call waitin Logo
96 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
