Question about Boating
What is a 1966 6hp boat motor worth - Boating
    Champion:
  • 254 Answers
Ebay has a 1968 for $300.00. If is has been in salt water, not much.
Posted on Apr 18, 2015
    New Friend:
It all depends on manufacturer, condition, how much use its had and all the variables. The question is; how much is it worth to YOU?
Posted on Apr 11, 2015
Testimonial: "Kiekhaefer .in good shape have not ran it in15 years"
What size motor for a 1970 15ft. seaswirl boat
outboard??? you could go all the way to 40 hp but id not recommend that much , but maybe a 20 hp would be just right !! its all about the condition/design of the transom and how you want the boat to sit in the water (weight) at rest ive seen motors as low as 10 hp on boats this size
Feb 29, 2016 | Boating
What do you think a 1997-1999 mariner 20 hp long shaft worth? I do have serial number. 06114522
out board motors suffer form internal corrosion in engine cooling system and sacrificial plate in the exhaust
if you wanted top dollar for it you would need to have some form of certificate of inspection from an accredited marine service center to offer to any buyer
otherwise advertise it with a figure on ti and sell on an as is where is basis
if it goes well and is still on the boat , the asking price may prove more acceptable it the buyer is taken for a test run
boat shops will be able to give to a ball park figure for a starting price that you can work with
Nov 14, 2015 | Boating
Where is the location of the carburetor screws and how do I adjust them?
I own a boat, I would not adjust with the carburettors myself. The dangers or making the mixture too lean and burning a hole in the pistons, or breaking down 6 miles out, are not worth the risk. I can get a full engine service which includes carb check and synch for $125.00
Oct 14, 2015 | Boating
Was told by a marine mechanic that put a camera into spark plug hole that lower piston is scored and motor is rusty
well scored pistons will run but have little to no power , depends on how rest of boat looks , well stocked boat yards can pull old engines out (they use same crane as picking up boats) then you can send it out to be rebuilt correctly as only then can a good decision be made to weather to scrap it or not when after a experienced engine builder has a look at it he makes the call
most mfg like perkins/.yanmarr and mercury do offer half blocks for retrofits as well could be way cheaper to go that way too
May 07, 2015 | Boating
What is a1966mercury 2 stroke boat motor worth
depends on the horsepower me thinks and if it runs or not .
Apr 11, 2015 | Boating
Install tilt and trim 75hp mercury
pending on how old your engine is coz the price of the full system is lots and mite be more than what your engines worth so check on price of engine with it fitted !
May 09, 2014 | Mercury Mark 75 Outboard Boat Motor...
Im looking for a workshop manual for a 1995 Honda 90 HP outboard motor any ideas Im working on the gearbox at present
We bought the Clymer Honda outboard shop manual (B757) which covers Honda 2-130 HP from 1979 to 1999.
It was $20 and worth every penny.
Hope this is helpful.
-Steve
Aug 03, 2012 | Light Outboard Motor Boat Bass Fishing...
I'm getting gas in my crankcase on my yamaha 2001 115 fourstroke outboard. What could cause this issue?
I am not exactly sure on your motor but 90% of the time if gas gets into the c/case,it's a diaphram in the fuel pump.This is only the case if it is a mechanically driven pump.It would be on the side of the block.This may not be your problem but would be worth a look.Hope this helps
Jul 23, 2010 | Light Outboard Motor Boat Bass Fishing...
Eska boat mortor value model number 1142-b serial number 32942 made in dubuque iowa want to know the value
LEARN TO SPELL \\\\\ does it motor run ? sad to say it's old and not worth much anymore . parts are unavailable to fix it needed .
Apr 21, 2010 | Boating
I have a johnson outboard motor that drips oil from the prop.why is this ?,maybe a seal is blown?
Yes the prop shaft seal needs to be replaced.Do this sooner than later as water will get into the lower g/box.Sometimes they wear out or fishing line is a bad culprit.Its not a big job but it really needs to be done.The oil will also need replacing.Hope this helps
Sep 09, 2009 | Light Outboard Motor Boat Bass Fishing...
Boating Logo
153 people viewed this question
Top Boating Experts
ray gallant
Bill Boyd
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
