Question about Homedics Heated Handheld Massager HHP-230
How do i get the electrical cord off to check for breaks init
What dose it mean when dispaly says bad cord
You may want to look at the cord where it connects to the range to see if it is loose or burnt. Check the whole cord to see if there are any breaks in it anywhere. The cords are not real costly so you can replace it yourself.
May 06, 2014 | GE Electric Smooth Top Range
Error codes 000070-001 and 00020-081 for iRC3180i
E020 Drum/Developer-related error
XX=01:Y XX=02:M XX=03:C XX=04:K XX=00:Any color
XX10 In INIT control of the initial setting,
SGNL is less than 62. Clean the ATR sensor window, Check on attachment of the developing unit, Check on a break
in the ATR sensor, Replace the ATR sensor
XX11 In INIT control of the initial setting,
REF is less than 62. Check on a break in the ATR sensor, Replace the ATR sensor
XX12 In INIT control of the initial setting,
SGNL is 960 or more. Check on a break in the ATR sensor, Check on operation of the shutter, Replace the ATR sensor
XX13 In INIT control of the initial setting,
REF is 960 or more. Check on a break in the ATR sensor, Replace the ATR sensor
XX50 When density data is computed using
SGNL value and REF value in ATR
control, REF becomes 0 due to backup
data corruption.
in the ATR sensor, Replace the ATR sensor,
Replace the DC controller PCB
XX51 When density data is computed using
control, the sensitivity coefficient
becomes 0 due to backup data
corruption.
XX81 P-SENS-P is less than 255 when a base
(drum face) of patch detection is read
out.
Clean the patch image reading sensor window
XX90 A computation result of patch reading in
patch detection is less than 16. Check on attachment of the developing unit, Replace the patch image reading sensor, Replace
the developing unit
XX91 A computation result of patch reading in
patch detection is 1008 or more. Check on toner leak from toner buffer in the developing unit, Replace the patch image reading
sensor
XX92 A computation result of patch reading in
patch detection is less than 42 for Y/M/
C and less than 73 for Bk 3 times in
succession.
the developing unit
X93 A computation result of patch reading in
patch detection is 522 or more for Y/M/
C and 543 or more for Bk 3 times in
succession.
sensor
XXA0 In ATR control, SGNL is less than 62. Clean the ATR sensor window, Check on
XXA1 In ATR control, REF is less than 62. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA2 In ATR control, SGNL is 960 or more. Check on a break in the ATR sensor, Check on
XXA3 In ATR control, REF is 960 or more. Check on a break in the ATR sensor, Replace the
ATR sensor
XXA8 In ATR control, the detected T/D ratio is
upper than its upper limit (13%) 10
times in succession.
developing unit, Replace the ATR sensor
XXA9 In ATR control, the detected T/D ratio is
lower than its lower limit (3%) 3 times
in succession.
and,
E070 ITB HP detection error
0001 HP of the ITB fails to be detected even
after the specific period of time.
Abnormality of the HP sensor,
Deviation of the belt from its position to
either edge, or soiling of the seal
Clean the HP detection seal, Clean/Replace the HP
sensor
...so, I pressume that something is broken, because you are getting these two error codes... call service, or write on emma.servis@gmail.com for service manual.
Hope that helps!
Aug 10, 2010 | Canon Office Equipment & Supplies
My bosch maxx laundry machine wont turn on
If you dont have power to the machine, your electric cord from machine to power point is broken. To check this turn on at power point and at machine hold cord in hand and shake if machine makes any noise you have a broken lead which can be cut at break and fixed,but better replacing with new cord Hope this helps
May 25, 2010 | Washing Machines
Canon3100 with code e000020-01a9 and -02a9 and -03a9, turned off. checked drum, fuser seems ok help
data corruption.
corruption.
out.
the developing unit
sensor
succession.
the developing unit
XX93 A computation result of patch reading in
succession.
sensor
ATR sensor
ATR sensor
in succession.
BUT FIRST: Check the ATR SENSOR, left from the developing rotor you have an "rail" with atr sensor - vacume it!!!!! Vacum all dev units, and copier
Apr 20, 2010 | Canon imageRUNNER C3200 Copier
It does not charge
We have found on these shaver the power cord breaks inside, this first thing I would check fore. broken or crack electrical cord.
Mar 28, 2010 | Norelco Quadra Action 7864XL Electric...
My saw is just making a clicking noise when i depress the lock off button and trigger switch,can't get it to work.
You either have a break in the cord or the switch is open (broken electrical circuit). Sometimes the cord will get pinched or wound and the wires inside will break. A quick way to test a cord is to crimp the cord in your hand the entire length from the plug to the handle while holding the switch in the on position. If there is a break somewhere crimping the cord should make contact for a couple of seconds and you will get some power to the saw. The best way to check is to use a multi meter to check the continuity of the cord. You will have to remove the switch from the housing and use your meter on the cord. Set your meter to the ohms function and test the continuity of the load and line wires. (Touch one lead of the meter to the blade and the other to the corresponding wire that goes into the switch. Hint the polarized blade side - wide side- is the white wire and the smaller blade is the black wire.) If you have continuity through the wire you can check the switch next. Locate where the cord wires go into the switch and the other two wires that come out. Test at these two points while depressing the switch. If you have continuity in the switch and the cord you need to check the carbon brushes to see if they are worn or broken. If you need any assistance please post back and I will help.
Sep 27, 2009 | Ryobi Circular Saw W/Dual Laser
What size breaker is reommended for electric dryer 220V?
Electric dryer uses a double pole 30 Amp breaker. Check for a loose electrical connection. Check that the screws holding the wires on the breaker itself are tight. Next, check the screws for the ground / neutral in the breaker box. Next, check all the connections in the dryer recepticle (where the dryer cord plugs into the wall) Finally, check the connections where the cord connects onto the dryer. If all connections listed were good tight connections, replace breaker.
Jan 13, 2009 | Whirlpool Dryers
Oven will not work
Follow these step for inital troubleshooting If your range/oven doesn't seem to work at all, check these:
1. Fuse/circuit breaker Check to see if power is getting to the range/oven. Does anything turn on--even a light? If not, check for a blown fuse or tripped circuit breaker.
2. Main wiring Often the main wiring connection from the house, at the range/oven, gets burned and so breaks the connection. Then you may have to replace the power cord to the range/oven, and the terminal block that the wire is attached to.
3. Range/oven wiring There may be a broken or burned wire at the back of the range/oven. If you repair any of the wires, use only proper appliance-grade wire and wire connectors.
Aug 12, 2008 | Stoves Kitchen Ranges
Monitor loses power randomly.
It could be the solder conections that go to the board . Open the init and check the solder thaere first. Go here for instructional videos on opening the unit.
http://www.lcdrepair.us/Installation.html
May 22, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Homedics Heated Handheld Massager HHP-230 Logo
584 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
