Question about Pool & Spa
Viking Destiny River 2013 hot tub led tub lights not working. Can hear relay engage when pressing lights on control panel. All not working.
  • 1,631 Answers
Not exactly sure of your question?
If you pressed 'Light' button on topside control, do any lights come on, some lights, or No lights? Does the light 'Icon' come on, on the topside?
if there is an indicator on the topside that comes on when you press the appropriate button, then the communication between the topside and circuit board have been completed, and that action should work, in your case, the light should come on. If no indicator, that means circuit board received no communication to power the light (s). So... you hear a click? So do you also an indicator that lights should be on, if so - no lights are working, wire to light fixture is either unplugged, or light or lights are burned out, or bad wire connection.
if no indicator on topside control panel = Bad/dead light 'Button', which means bad panel - since you can't repair a button on a topside control panel.
Posted on Apr 10, 2015
  • 1 more comment
  • Nicole Walker Apr 11, 2015
    No lights working. Relay clicking so interface working. Not getting proper voltage. Only reading 4.8 when should be 12. Thinking motherboard issue.
    No led lights in spa working. Control panel illuminates properly.
  • Mike Tellegen Apr 11, 2015
    12 volts is the common operating voltage for the light system, anything less could be bad circuit board... That is if there isn't an off board light transformer?
Sparform hot tub blower won't turn off
When an appliance will not turn off, no matter what you press on the control panel, you have either a non responding (dead button) topside control panel, or your topside panel did receive the message to turn it off and the circuit board is not responding.
  • If you have some kind of indicator light when you press your Jet/pump button, if the topside panel is operational and does actually receive your request to either turn on or off an appliance, an indicator will appear - either a light or icon.
    • If one does appear when button pressed, then dis-appears when pressed, that means your panel is good - as it is responding to the pressing of the associated button.
      • Bad circuit board
    • If nothing appears when you press the button, no lights or icons - indication of topside receiving your request, then you you have a dead button.
      • Bad Topside Control Panel
May 18, 2014 | Dream Maker Spas Dream Maker Ez Spa Hot...
Viking microwave has digital lights but will not turn on to cook?
Hi the problem will be with the touch panel membrane or the controller. if yoiu can hear a click when the start button is pressed then the touch panel is OK asnd you should look at the controller which can be replaced as a unit or if you are up to it it's probably the main cook relay that has failed.
Jan 29, 2009 | Viking DMOC205SS Microwave Oven
Viking oven won't turn on
I had same problem (twice) with my Viking dual fuel range. In my case a relay that supplies power to the oven heating elements failed. The convection fan would run. The elements were warm to the touch. If you have a free standing range, it may be that relay (part number PM010026) which is located in the front of the stove. Remove a long narrow stainless steel panel (1 screw each side) located under where the door hinges. You can hear the relay click when you turn up the oven thermostat. That will help you locate the relay.
Note: Viking does not sell parts. You have to find their parts distributor for your part of the country.
Sep 20, 2007 | Viking DEDO205 Stainless Steel Electric...
Pool & Spa Logo
274 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
