Question about Huffy Regatta 26" Womens Bike, Sea Foam
Just picked up my bike from Walmart. They installed the seat wrong. The stirrup part is pointing straight up. Can't even sit on it.
Can I easily fix it myself? Don't want to get hurt if it is not fixed right.
  • 1,631 Answers
Loosen the adjustment nut, and place into correct position.
Otherwise, take it right back and have them make the proper adjustment, free of charge - don't forget to take proof of payment / receipt.
Posted on Apr 10, 2015
I just bought a brand new iPhone 5s with straight
Are you using an activation number Wal-Mart is providing you or the IMEI # located on the box the iPhone came in?
Oct 21, 2014 | Apple iPhone Cell Phones
How to set the stirrups
you need to be a little more specific in your question, actual strir-up ajustments or how to make sure they are the right lenght for your leg.
Apr 03, 2014 | Circle Y 1179 Martha Josey Ultimate Cash...
Bike battery drains fast, bike seat & area below seat gets too hot to sit on
It sounds as though the seat pan might be coming into contact with the battery and thus causing the seat to heat up and drain the battery all at once. My question would be if the battery was recently replaced and an incorrect sized battery was used. If battery isn't under the seat pan itself, check for wires that might have insulation damage that could cause a short and draining the battery. Also some people have installed heated grips on their bikes, maybe the switch for that isn't off when not in use and causing a drain.
Apr 22, 2013 | 2003 Yamaha V Star Classic
Bicycle seat fell apart
If you don't have a local bike shop to reassemble your seat or sell you a new one, you can probably find one to fit at Walmart or Target. A good bike shop will often give you one of better quality than you can buy at a department store, because many cyclists replace the seat with one that fits their bottom when they buy a new bike.
Sep 15, 2012 | Raleigh Cycling
How do you put the seat together? The instruction book has instructions for three types of bikes but all three say to "insert the tapered end". This bike's seat rod doesn't have a tapered end! ...
A typical seat post will have a tapered end that slips into the seat clamp which grips the post and clamps the seat rails, all at the same time. If the seat post is not tapered at one end, then it must be a 22.2mm post. Loosen the seat clamp's nuts enough to install the saddle rails. The clamping area for the post should be under the "nose" of the seat. It should loosen enough to slip over the post without falling apart. Otherwise, you may have mis-matched parts.clmrt5000.jpg
Jan 06, 2011 | Cycling
I just noticed a slow leak on my 2003 deuce. What is the best way to deal with it?
Well, the first thing to do is to figure out where the leak is coming from. This is sometimes not as easily done as it sound. The wind while riding has a tendency to blow the oil back, up, and over and makes it look like the leak is coming from somewhere that it's not.
So, clean your bike completely even if it means using a pressure washer. Do not hold the pressure washer nozzle to closely to any part of the bike. If you hold it too closely to the steering head or the center of the hubs, you could force water into the bearings. I've taken transmissions apart and found water in them after they'd been pressure washed. So. just enough to make sure you get all the oil off your bike. Then, park the bike on a large piece of cardboard. Let it sit and watch where the oil drips onto the cardboard. The oil will drip straight down. This doesn't mean it went straight down to get to the drip point however. Once you fnd out where the oil is coming from, knowing how to fix it isn't a problem.
Good luck
Steve
Nov 03, 2010 | 2003 Harley Davidson FXSTD Softail Deuce
Where can I find a replacement seat for my daughter's 16" princess bike
Hello. Any Walmart or bike shop will have replacement seats. All bike seats are interchangeable. If you take the bike to a bike shop they will probably install the new seat for you. Otherwise you will need a crescent wrench ot set of socket wrenches to do the job. Regards, Joe
Dec 14, 2009 | Huffy Disney Princess 16 in. Girls Bicycle
I'm new to bike riding, it's only been a couple of months. I really don't know how to explain my problem, other than when I'm riding (downhill, uphill, anywhere), it feels like the bike is giving out when...
By "giving out" do you mean it feels like not all the power generated by your legs is getting to the rear wheel? This can be caused by a chain that need oiling, pedals that stick or don't turn easily, badly adjusted gear set (that doesn't have the chain riding in the middle of each gear, but off to one side or the other). Do you notice any chattering or scraping noises when you ride?
Also, make sure your seat is adjusted correctly. To get full power, you leg should be almost straight when you are sitting on the bike and the pedal is at the bottom of the stroke. If not, raise the seat until you can just touch the pavement when the bike is tilted (as at a stoplight). Also, make sure the tires are inflated correctly. Overly soft tires take more work to get to your destination.
Jul 07, 2009 | Schwinn Cycling
Not getting fire from coil
Do you have a manual? If you do can you send me a copy of the correct schematic for your bike. It will me help you if you can scan a copy in to send me. If you don't already have a basic voltmeter that measures resistance. You should pick one up at either WalMart or even better Harbor Freight has the best deal $4-$9 there. What year is your bike? You can start off by isolating the kill switches from the coil by unplugging the coil lead headed towards on/off switch and other safety switches. The idea here is to make sure you don't have a bad switch by disconnecting all kill switches to test for spark. If still no spark does the bike have cdi box or points fire ignition. CDI is capacitor discharge ignition often refered to as the black box. Points are mechanical switches that open and close riding on the crankshaft.
Please send year of bike so I can better assist you.
Thank you,
Todd
Apr 23, 2009 | Yamaha XS 650 C Motorcycles
Where do I put my foot
and am hoping to get some advice on foot position. What part of the foot should be resting on the peg? My bike has a relatively upright riding position and I can't really decide. Is the heel supposed to be directly on the peg or is the peg supposed to be in the arch of the foot (in front of the heel of the boot)? The bike is really comfortable overall but my right ankle has been sore because I can't seem to figure out what's comfortable. I know it's probably a matter of what is most comfortable for the rider, but does anyone have any suggestions?,I would not recommend putting your heel on the peg; it can easily slip off and you will have little ability to stand up on the pegs if needed. You will probably get differing views here, but I ride my standard bike much like I ride a horse; footpeg in the arch of my foot at some times just like a stirrup, and footpeg under the ball of my foot at other times; again just like in a stirrup. ,,,
Nov 10, 2008 | 2008 Highland Supermotard
Huffy Regatta 26" Womens Bike, Sea Foam Logo
394 people viewed this question
Top Huffy Cycling Experts
Michial Gueffroy
Charles T Nevin
Charles T Nevin
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
