Our Braun Aromatic KMM10 begins grinding but after 30 seconds it suddenly stops and will not grind again for at least an hour. What could be the problem and can it be repaired? We like this grinder because of the storage capacity it has for beans.
Soulds like a thermal overload breaker? I know you should not have to do this . Use an outlet that is not shared with any other item, if one is available and if there is a selector for different grinds see if changing it to a finer grind will help. A couarse gring takes more bean ion each pass and it may be too much load on a single extended grinding. One would think the bigger the bin the better the motor. But try this and if you will, let me know. please
Thank you for the suggestion. Hopefully this will resolve the issue.
