Question about Frigidaire Dishwashers
We have a Frigidaire dishwasher there is a p/n: 154881401. Its only about 1 year old but all the light will light up when.pushed except the start and cancel button. Already tried cutting power.
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Denise, thanks for your post!
Based off what you have described your Frigidaire dishwasher will light up and will not start or cancel. This could be a possible problem with your keypad or control panel. In order to access which electrical component that could be causing the issue you would need to disassemble your dishwasher. This is not a simple DIY job and I would recommend having a professional technician for proper diagnosis and repair. This will help you avoid unnecessary part purchases. -Matt
Posted on Apr 17, 2015
SOURCE: Kenmore Ultra Wash Dishwasher LIghts are blinking....
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Posted on Mar 22, 2008
SOURCE: Clean light on dishwasher won't stop flashing
yust reset press heated dry-normal-heated dry normal-and it will work 100% remember that code it is reset code for wirpool quiet partner and many other models
Posted on Feb 19, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
SOURCE: Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Posted on Aug 24, 2009
SOURCE: Frigidaire Dishwasher FDB1050REC1 - Washing Indicator Light Blinking
Here is what happened, you pulled the door open without pressing cancel and allowing it to pump the water out, hence the "flooding in the bottom". This is just one reason why it maybe blinking, there is a water sensor in the bottom. If your dishwasher is hooked up properly to any decent garbage disposal, run the disposal for about 30 seconds to a minute. This should pump the water out, more like activate a light siphoning affect. It should work as normal. If you are not having luck with that, detach the DW drain get it low and let it siphon.
Posted on Apr 06, 2010
I try to start my GE Profile Dishwasher and nothing happens after I press start except for a click. Is my water pump busted? The dishwasher powers on ok.
Here is a list to trouble shoot your DW. Cross off each item as you go. If this is a new DW..... less than a year old..... it may be under installers warrantee and definitely is under a manufacturers warrantee. Keep that in mind as you go.
Look also at your owners manual for troubleshooting help.
Jan 11, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
The Clean light on my frigidaire gallery dishwasher is on continuously. The dishwasher will not start. Its over 10 years old.
the problem is in the pcb board which will have to be replaced and cost a few hundred dollars. considering that machine is only designed to last 7 years i would just replace the entire machine.
Sep 26, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
My frigidaire dishwasher model #fghd2433kf1
It is in a delay wash mode.
Disconnect power for 60 seconds.
Re-connect power.
Press the Cancel button.
Press the regular wash cycle and start the dw.
Jul 17, 2010 | Frigidaire Dishwashers
Frigidaire dishwasher had blinking lights then nothing
there is no fuse in the unit but u can unplug and plug into power 2 c if resets.
Aug 18, 2009 | Dishwashers
Can't find the model number on Frigidaire dishwasher
The nomenclature should be located on the left side on the inside of the tub right by the front when you open the door. It is most likely an fdb series example fdb1050. however the drain hose pn 154606701 is the factory replacement for most frigidaire dishwashers ten years or less.
Mar 31, 2009 | Frigidaire Professional Series 24 in....
Frigidaire Dishwasher Energy Star blinking lights.
Hmmm...don't know why this worked, but it did. When the lights were flashing when I tried to start my Frigidaire dishwasher model#FDB1500LF, nothing would happen...just blinking lights, so I went to the house electrical panel, found the switch for the dishwasher, turned off & on again, and now the dishwasher works.
Go figure.
Feb 16, 2009 | Frigidaire 24 in. PLD2560LCC Energy...
Fridgidaire FDB126RBS2 Won't Drain in Rinse Cycle
check the drain pump for foreign object in the pump if nothing is found replace the pump
Apr 25, 2008 | Frigidaire 24 in. FDB126RB Built-in...
Bad impelller on wash pump replace pump motor
Dec 30, 2007 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire Dishwasher GLDB957JS0 (built-in)
Door switch had to be replaced. Turn off circuit breaker first.
Feb 27, 2007 | Frigidaire 24 in. GLDB957A - Multiple...
Dishwashers Logo
451 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
